    ONE PING ONLY --- M42
    Using Duet Controllers
    797
    • tecnoundefined
      tecno
      How can I get M42 to give one shot and wait for next trigpoint?
      ;Camera trigger
      M950 P0 C"io1.out" Q1
      M42 P0 S1
      Contious triggering of the camera.
        jay_s_uk @tecno
        @tecno whats your method of triggering it now?
        I would suggest using a custom gcode e.g. M5000 and creating a file called M5000.g in sys.
        The contents could then be
        M42 P0 S1
        G4 P500
        M42 P0 S0
        That would turn the output high for 0.5 seconds whenever M5000 is called
        tecnoundefined 1 Reply Last reply Reply Quote 1
        • tecnoundefined
          tecno @jay_s_uk
          @jay_s_uk said in ONE PING ONLY --- M42:
          M42 P0 S1 G4 P500 M42 P0 S0
          Still continious, so question is if my M950 needs editing?
            jay_s_uk @tecno
            @tecno what do you mean its still continuous?
            Are you using M42 in your config.g?
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @jay_s_uk
              @jay_s_uk
              No M42 in config.g
              M950 in config.g
              M5000.g in sys
              Console command M5000
              It triggers but does it coninously instead of one shot
                jay_s_uk @tecno
                @tecno maybe 0.5s is too long, try reducing to P100
                Otherwise it sounds like you might need to add something to pull it back down to ground once released?
                • tecnoundefined
                  tecno @jay_s_uk
                  @jay_s_uk
                  Tested that still same issue
                  • tecnoundefined
                    tecno @tecno
                    Take away the 1K serial resistor on output?
                      jay_s_uk @tecno
                      @tecno dunno, i'm not really an electronics guy
                      • tecnoundefined
                        tecno @jay_s_uk
                        Tested = same issue 😉
                        Hopefully sombody else chimes in ta advice what to try next.
                        Thanks !
                        • fcwiltundefined
                          fcwilt @tecno
                          @tecno
                          What are the specs on the device you have connected to that output?
                          What does it expect to see in the way of signal voltage and duration?
                          • tecnoundefined
                            tecno @fcwilt
                            @fcwilt said in ONE PING ONLY --- M42:
                            @tecno
                            The IO output goes go GND to trigger camera ( switch is NO and swithes to ground )
                            https://forum.duet3d.com/topic/23976/mini5-bt-dongle-for-transmit/19
                              jay_s_uk @tecno
                              @tecno can you change the M950 to
                              M950 P0 C"^io1.out" Q1
                              • tecnoundefined
                                tecno @jay_s_uk
                                Tried that still same issue with serial 1K, will test with no serial 1K
                                • tecnoundefined
                                  tecno @tecno
                                  @fcwilt @jay_s_uk
                                  IT WORKS NOW !!!
                                  ;Camera trigger
                                  M950 P0 C"!io1.out" Q1
                                  Thank you guys, this forum is so helpful !
                                  fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 4
                                  • fcwiltundefined
                                    fcwilt @tecno
                                    @tecno said in ONE PING ONLY --- M42:
                                    @fcwilt @jay_s_uk
                                    IT WORKS NOW !!!
                                    ;Camera trigger
                                    Glad to hear you got it working.
                                    Do you understand why you needed that ! character?
                                    • alankilianundefined
                                      alankilian @tecno
                                      @tecno
                                      Excellent.
                                      I did say:
                                      I would put a series resistor inline.
                                      Maybe 100 Ohms to 1,000 Ohms and try it.
                                      So I was already thinking 1,000 Ohms might be too large.
                                      I'm glad you stuck with the experiments and got it working!
                                      • tecnoundefined
                                        tecno @fcwilt
                                        @fcwilt @jay_s_uk
                                        IT WORKS NOW !!!
                                        ;Camera trigger
                                        This inverts the signal and by that the level rises above the trigg point in the BT circuit, right?
                                        • tecnoundefined
                                          tecno @alankilian
                                          @alankilian said in ONE PING ONLY --- M42:
                                          @tecno
                                          Excellent.
                                          I did say:
                                          Experiments are always good as long one tries to follow good practis, in my case ask questions frequently.
                                          Thanks for guidance!
                                          • fcwiltundefined
                                            fcwilt @tecno
                                            @fcwilt @jay_s_uk
                                            IT WORKS NOW !!!
                                            ;Camera trigger
                                            Correct.
                                            Without that ! character the normal state of the output is low which is the state that triggers the camera. Adding that ! character makes the normal state of the output high.
