    Tool Board Heater Tuning Leading To Faults
    101
    5.2k
    • KevinMarundefined
      KevinMar
      I'm having serious problems auto tuning my E3D V6
      Some info: Hemera + copper block + 30w heater + PT1000
      Duet 3 6HC + Tool Board V1.1 on all tools, all with firmware V3.3
      The Hemera's have an overpowered part cooling fan, so I'm tuning using M303 T0 A30 F.40 S220
      The tuning runs fine, but when I paste the parameters into config.g, the resulting heater activation inevitably results in a fault before the tool reaches 120C, usually around 70-100C
      The parameters are: M307 H1 R1.635 C335.200:88.700 D5.20 S1.00 V23.8 B0
      dc42undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
        Do you have a silicone block sock?
        Can you adjust the duct to blow less on the nozzle area?
        KevinMarundefined 1 Reply Last reply Reply Quote 0
        • KevinMarundefined
          KevinMar @Phaedrux
          @phaedrux I have a silicone sock and have tried the tuning with and without it.
          I adjusted the F parameter to have the fan run at only 40%, and even tried tuning without the fan at all
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
          • DIY-O-Sphereundefined
            DIY-O-Sphere @KevinMar
            @kevinmar
            Do you use M501 in the config?
            (UTC+1)
              dc42 administrators @KevinMar
              @kevinmar please run M307 H1 with no other parameters, to check that it really is using the parameters that you found from tuning.
              • KevinMarundefined
                KevinMar @DIY-O-Sphere
                @diy-o-sphere Yes
                • KevinMarundefined
                  KevinMar @dc42
                  @dc42 Confirmed, it is using the parameters that I found from tuning
                  • fcwiltundefined
                    fcwilt @KevinMar
                    @kevinmar said in Tool Board Heater Tuning Leading To Faults:
                    Is the ambient temp really 30?
                    And what fault are you getting?
                      @kevinmar
                      Do you still have old parameters in the config-override.g?
                      But after you have checked the heater in the console it should actually fit.
                      (UTC+1)
                      • KevinMarundefined
                        KevinMar @fcwilt
                        @fcwilt Ambient is 26-30C
                        I am not getting a fault readout in the console
                        • KevinMarundefined
                          @diy-o-sphere No, old parameters are overwritten when a new set is generated and saved using M500
                          • fcwiltundefined
                            fcwilt @KevinMar
                            Wow. I gather it is hot were you live and you have no air conditioning?
                            You posted this where you said there was a fault.
                            • KevinMarundefined
                              KevinMar
                              I think it's faulting way too liberally. My heater and PT1000 are working, it's not like I'm experiencing thermal runaway.
                              Is there a way to change the sensitivity of the faults?
                              • fcwiltundefined
                                fcwilt @KevinMar
                                What fault are you getting?
                                • KevinMarundefined
                                  KevinMar @fcwilt
                                  @fcwilt Well, true ambient is about 24C, but the PT1000's always read about 27C as ambient.
                                  The heater faults, but there is no readout in the console.
                                  • fcwiltundefined
                                    fcwilt @KevinMar
                                    In what way does the heater fault?
                                    • KevinMarundefined
                                      KevinMar @fcwilt
                                      @fcwilt I wish I knew!
                                      • fcwiltundefined
                                        fcwilt @KevinMar
                                        What is happening that is evidence of a fault?
                                        • KevinMarundefined
                                          KevinMar @fcwilt
                                          DIY-O-Sphereundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                            @kevinmar
                                            Please post the config.g
                                            (UTC+1)
