Slow all the time at 2000% speed
21
1.2k
  • undefined
    Jbourns
    I've cranked my max accel and speeds up and nothing its just staying at 24mm/s
    Important Info.
    Duet wifi
    Firmware 2.05
    DWC 2 something " I dont have remote access to check right now"
    https://youtu.be/QPU4l37tXkc
    ; generated by RepRapFirmware Configuration Tool v3.3.2 on Sun Sep 19 2021 14:10:08 GMT-0700 (Pacific Daylight Time)
    M550 P"Castle" ; set printer name
    M669 K1 ; select CoreXY mode
    M550 PCaslte ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S1 ; Enable FTP
    M586 P2 S0 ; Disable Telnet
    M587 S"RI-Wireless" P"Ridgeview8648" ; disable Telnet
    M350 X32 Y32 I0 ; configure microstepping without interpolation
    M350 Z16 E16 I1 ; configure microstepping with interpolation
    M92 X325.00 Y325.00 Z1080.00 E700.00 ; set steps per mm
    M566 X1900.00 Y1900.00 Z90.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X10000.00 Y10000.00 Z280.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X1900.00 Y1900.00 Z50.00 E250.00 ; set accelerations (mm/s^2)
    M906 X1100 Y1100 Z1500 E350 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X343 Y325 Z750 S0 ; set axis maxima
    M574 Z1 S1 ; set active high endstops
    M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
    M558 P5 H2 F295 T6000 ; set Z probe type to switch and the dive height + speeds
    G31 P500 X-24 Y0 Z3.361 ; set Z probe trigger value, offset and trigger height
    M557 X5:350 Y15:335 S38 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for BED heater 0
    M305 P1 X200 ; configure PT100 for heater 1
    M143 H1 S280 ; Set thermistor + ADC parameters for heater bed?
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"Volcano" D0 H1 F0 ; define tool 0
    ;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
    ;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
    T0 ; select first tool
    undefined 1 Reply Last reply 10 Oct 2021, 20:56 Reply Quote 0
    • undefined
      oliof @Jbourns
      @jbourns if you use Cura, disable acceleration control. It uses mm/sec for acceleration and speed as Marlon does, but RepRapFirmware uses mm/min.
      undefined 1 Reply Last reply 10 Oct 2021, 21:00 Reply Quote 0
      • undefined
        Jbourns @oliof
        this is what i have in the speed settings.
        • undefined
          jens55
          How do you test maximum speed? do you just run a model? If you run a model, what are the slicer settings for max speed, acceleration and jerk.
          You could take the slicer variable out of the equation and just use a quick hand written macro such as :
          G1 X000 Y000 F50000
          G1 X000 Y300
          G1 X300 Y300
          G1 X300 Y000
          Adjust the F parameter to suit what you want the machine to do
          Adjust the coordinates based on what your printer bed size is.
          undefined 1 Reply Last reply 10 Oct 2021, 21:06 Reply Quote 0
          • undefined
            Jbourns @jens55
            @jens55 By printing things usually dialing up with macros. But nothing is increasing the speed at all, it'll go slower.
            right now i dont care for setting the proper speeds. I just want to go faster than 25mm/s 2000% speed should have done something.
            Should the print speed in dwc override what the slicer?
            undefined 1 Reply Last reply 10 Oct 2021, 21:43 Reply Quote 0
            • undefined
              engikeneer @Jbourns
              @jbourns what firmware flavour do you have set in PrusaSlicer? Should be Reprap.
              If you leave it in Marlin, it puts a bunch of max speed commands in the start code in the Marlin units, so you end up 60x too slow
              i3 clone with a bunch of mods
              undefined 1 Reply Last reply 10 Oct 2021, 21:51 Reply Quote 0
              • undefined
                Jbourns @engikeneer
                @engikeneer Its set to reprap/sprinter
                • undefined
                  PaulHew
                  How big and what are you trying to print?
                  If it is small and complex it might not be able to get up to speed.
                  When I print Pi cases my infill is going at 130mm/s. 3 perim, 3 top and bottom.
                  Got an stl?
                  RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                  Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                  undefined 1 Reply Last reply 10 Oct 2021, 23:43 Reply Quote 0
                  • undefined
                    Jbourns @PaulHew
                    @paulhew Its 38 x 45mm. I just don' t get why it wont increase in speed at all from DWC. I've always been able to crank it up to suit my needs. Now I'm stuck with a 6 hour print when it should have been done in 20min
                    fixture.stl
                    undefined 1 Reply Last reply 10 Oct 2021, 23:49 Reply Quote 0
                    • undefined
                      PaulHew @Jbourns
                      @jbourns This is my speeds config for a RailCore
                      M92 X200.00 Y200.00 ; set steps per mm
                      M92 Z1600 ; set steps per mm Z Axis
                      M92 E412 ; set steps per mm Extruder
                      M566 X600.00 Y600.00 Z200.00 E3600.00 ; set maximum instantaneous speed changes (mm/min)
                      M203 X18000.00 Y18000.00 Z900.00 E3600.00 ; set maximum speeds (mm/min)
                      M201 X1500.00 Y1500.00 Z250.00 E1500.00 ; set accelerations (mm/s^2)
                      M906 X1280 Y1280 Z1220 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
                      My E speeds are higher.
                      I run a BMG Extruder with a mosquito hotend.
                      I will give you part a run later, nearly 1am here in the UK.
                      undefined 1 Reply Last reply 10 Oct 2021, 23:55 Reply Quote 0
                      • undefined
                        PaulHew
                        Also, in PS, filament tab, what is your max volumetric speed?
                        That can play a major part in speed.
                        undefined 2 Replies Last reply 10 Oct 2021, 23:57 Reply Quote 0
                        • undefined
                          Jbourns @PaulHew
                          @paulhew I'll give those a go, Thanks for the help. I'll be testing them in the next hour once this part is printed.
                          undefined 1 Reply Last reply 10 Oct 2021, 23:56 Reply Quote 0
                          • undefined
                            PaulHew @Jbourns
                            @jbourns 👍
                            • undefined
                              Jbourns @PaulHew
                              @paulhew It's at 0 which is default so I assume that's off?
                              undefined 1 Reply Last reply 11 Oct 2021, 00:05 Reply Quote 0
                              • undefined
                                PaulHew @Jbourns
                                @jbourns I found this for calculating Volumetric speed.
                                https://docs.google.com/spreadsheets/d/1ZHSRzTm2AR_sXnLSSOq2NSmx0UYtF5bJKHUSFWiDscA/edit#gid=0
                                undefined 1 Reply Last reply 11 Oct 2021, 00:17 Reply Quote 0
                                • undefined
                                  Jbourns @PaulHew
                                  @paulhew 10mm/3 seems like a good middle ground for the volcano
                                  • undefined
                                    Jbourns @PaulHew
                                    @paulhew The only explanation is that im a daft prick. I think i fugged up my E speeds ands acceleration at some point. Doesn't explain why I couldn't just override it.
                                    https://youtu.be/tr7fGtmQUk8
                                    alankilianundefined 1 Reply Last reply 11 Oct 2021, 14:04 Reply Quote 1
                                      @jbourns the speed multiplier will override the speeds requested in the F parameter of G1/2/3/4 commands, but not the machine speed limits set by M203.
                                      • alankilianundefined
                                        alankilian @Jbourns
                                        @jbourns YEAH!!!
                                        Thanks for keeping us in the loop and letting us know when you figured it out.
                                        • undefined
                                          Jbourns
                                          It was either volumetric flow in prusa slicer or max speed in the config
                                          undefined 1 Reply Last reply 12 Oct 2021, 06:52 Reply Quote 1
                                          1 out of 21
