InputShaping-Plugin-0.2.0-pre7 released
Hey,
next version released. I still didn't leave the experimental realm, so be careful and don't be to wild with switch tabs and clicking while something is being processed.
Please read the release notes and the howto first!!!
release notes for inputshaping plugin 0.2.0-pre7
This work is based on the original acceleration plugin. Input shaping plugin tries to take
the input shaping calibration to a next level.The current state is still EXPERIMENTAL!!!
Although it's experimental it brings already some handy features which is why i
am doing this release. Therefore please comment, give feedback, report bugs and share your
ideas.requirements
- Duet Web Control 3.4.0-b6
- RepRap Firmware 3.4.0-b6
features
- restructre plugin to use vue components
- added test configuration component
- added recorder component
- added chart component
- use object model to determine status of test
- added add/delete of algorithm configurations
- added add/delete/select of records
- added add/delete/select of sessions
- display test parameters in chart component
- allow records with differing samples rates of up to 1%
- cleaned up debugging output
- added localization
- home device only if not homed
- improved ui layout
- added component to manage multiple sessions
- added more parameter validation for test and algorithm
- disable tab record tab when no algorithms defined
- disable tab chart when no records available
- improved error reporting
- localized date-timestamps
- added integrals for each axis
- skip algorithm test which already have test record (speed improvement, easier understanding)
- improved editing note in configuration tab
- cleaned input fields (ids or not editable but only names)
- added recommendation support
- make deletion of accelerometer files configurable
bugs
- fixed initial filtering of records by axis
- fixed session cleanup when session is deleted
- fixed data handling when swapping sessions
- fixed can address handling (needs more testing)
- fixed record integrity when referenced algorithm is changed
- fixed CAN address handling when address is null
- fixed one-time homing for some machines
known issues
- parameter validation doesn't cover every situation
downloads
howto
initialize session
- switch to tab "initialize"
- create a new session or
- select an available session
configure session
- switch to tab "configure"
- configure your session session
- configure test parameters
- add as many input shaping algorithm configurations as you like
- more than one per algorithm are allowed
- this is good to compare different input shaping configuration of the same algorithm
- CAUTION: once a record in a session exists test parameters can't be changed anymore.
record profiles
- switch to tab "record profiles"
- press "run" button and wait until recording is done
frequency analysis
- switch to tab "frequency analysis"
- in "acceleration records" section you see a list of profiles recorded
- clicking on the entry DELETEs it form the session!!! (it is lost!!!)
- in "filter" section the show/hidden graphs are displayed
- un-checking an axis will hide or show all charts of an axis group
- in chart section
- individual graphs can be shown or hidden by pressing the colour next to the name
- press "FFT" button to show FFT representation of the graph
- press "Time" button to show time representation of the graph
recommendations
- switch to tab "recommend"
- select a record of type "none" from the first table
- run recommendations, thism might take a while...
- sort second table with recommendations by integral
- ideally the record with the smallest integral should be provide the best configuration
- add configuration to session
- switch to tab "configure" to review added configurations
- see section "configure session"
limitations
- currently no data is stored permanently!!!
- everything is volatile so avoid hitting browser's reload
what's next?
Potential next steps are
- store session in a local file or in browser's local storage or
- load session from local file or browser's local storage
- recommend input shaping parameters
- improve input validation
- add translations
Nice job. Works great. The recommendations section is particularly interesting.
Hi All,
I'm getting Error: M956: Response timeout: CAN addr 123, req type 4014, RID=6.Any thoughts on what this is related too? It used to work with pre6.
I think it could be related to I'm measuring a polar printer bed and I now have limits on bed acceleration and rotation speed since the bug was fixed in M669.
Any thought would be much appreciated.
Cheers
Barry M -
Should it be possible to add more than one axis to a single session?
I have tried adding tests for X and Y axis to a single session and then when recording, all tests are run, but only along the axis which was selected for the last configured test.thanks!
@cncmodeller said in InputShaping-Plugin-0.2.0-pre7 released:
Hi All,
Cheers
Barry MUpdate, I've increased bed speed and Accel limits by an order of magnitude and the bed now behaves as in pre6 but I'm still getting the error.
Good updates all around!
My only report is removing algorithm run data from the current selection resets the chart view to the 'Time' plot - this is in contrast to removing axis data, which keeps the chart (time or FFT) active.
@ajdtreyd I agree, it would be nice to nice to run different axis tests under a single 'configuration' session. The axis setup & bounds could fall under each algorithm you add.
Found a bug!
I used -75 and 75 as my start positions for the initial config of my sessions. After doing record and running recommendations, I selected a couple of algorithms and added them to the session. All good. But when I went back to the CONFIGURE tab the start positions had reverted to the defaults of -115 and 41.
I figured this was just a GUI issue and ran the recordings, but the newly added algos used the default start positions.Another "nice to have" (but not a bug) is to reset the Input Shaping mode to it's original state when 1) the recording phase has finished AND 2) when the recommendations have completed. Currently M593 mode is left with whatever setting was last used by the plugin.
I have this in my bed.g so probing uses very low accel/jerk and then the original values are reset:; -- set accel/jerk vars to current values var x_accel=move.axes[0].acceleration ;set variable to current acceleration var x_jerk=move.axes[0].jerk ;set variable to current jerk var y_accel=move.axes[1].acceleration ;set variable to current acceleration var y_jerk=move.axes[1].jerk ;set variable to current jerk var z_accel=move.axes[2].acceleration ;set variable to current acceleration var z_jerk=move.axes[2].jerk ;set variable to current jerk . . . M201 X{var.x_accel} Y{var.y_accel} Z{var.z_accel} ;restore orig accel M566 X{var.x_jerk} Y{var.y_jerk} Z{var.z_jerk} ;restore orig jerk
Overall the plugin is working really nicely!
Thanks! -
That indicates that board 123 is not responding to a CAN command. It's probably not running the correct firmware version.
@ajdtreyd said in InputShaping-Plugin-0.2.0-pre7 released:
Right now you have exactly one test movement per session. This helps to keep things separated. When you start to mix all different test you loose pretty fast the overview. So it makes sense to me to keep things separated.
But there might be some further changes in future.
A suggestion would be to add a Z position, this is mainly an issue with Delta as the recording will fail if we don’t move down the effector after having homed the printer.
I'm having a lot of crashes when I try to launch the recording, the Duet 2 Wifi just seems to reboot - I didn't see any error.
It doesn't appears to be related to the algorithm selected (happen even with none) or the number of recordings.
I will try to spend more time to see if I can find anything that could help to figure out what could be the reason.Let me know if there is anything I can do to help trouble shooting this issue.
These recommendations seem wrong to me - I’m not an expert so I can be wrong.
I ran without compensation
All recommendations are on the frequency 10.82Hz; I feel it would be better to compensate something between 64 and 72Hz.
The spike at 102Hz is not generated by any movement, it exists when doing recording without a move. -
@fred-y said in InputShaping-Plugin-0.2.0-pre7 released:
Please post a M122 report taken after one of those reboots.
@dc42 I did a lot of tests yesterday but I have not been able to reproduce the issue (reboot) I had.
I'm unsure what caused it I haven't changed anything: same config and wiring ... the board is a few years old maybe something starts to wear.I'm planning to do more testing within the next few days and I will report back with a log if it is happening again.
Good morning, I've been able to make my accelerometer to work! I'm trying the plugin but (again) there's something I'm missing, I'm afraid.
I've created two analysis, the first for the X axis and the second for the Y axis, these are the results:X axis:
Y axis:
Why does the plugin suggest me 10,87/88Hz as frequence? Particullary for the Y axis the spike is at 67.8 Hz wich is about where I expected it to be....what's wrong? CoreXY printer, here my M122:
13/11/2021, 07:52:25 M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later Board ID: 08DLM-996RU-N85T0-6JKFJ-3SD6R-9SSHN Used output buffers: 3 of 24 (24 max) === RTOS === Static ram: 23772 Dynamic ram: 79576 of which 12 recycled Never used RAM 5408, free system stack 118 words Tasks: NETWORK(ready,16.6%,234) ACCEL(notifyWait,0.1%,244) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,283) MAIN(running,83.2%,440) IDLE(ready,0.2%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:09:52 ago, cause: software Last software reset at 2021-11-13 07:42, reason: User, GCodes spinning, available RAM 5408, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x0c Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.6, current 33.2, max 33.9 Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/10, heap memory allocated/used/recyclable 2048/672/472, gc cycles 0 Driver 0: pos 74214, standstill, SG min 0 Driver 1: pos -21546, standstill, SG min 0 Driver 2: pos 6345, standstill, SG min 29 Driver 3: pos 0, standstill, SG min n/a Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0 Driver 6: pos 0 Driver 7: pos 0 Driver 8: pos 0 Driver 9: pos 0 Driver 10: pos 0 Driver 11: pos 0 Date/time: 2021-11-13 07:52:23 Cache data hit count 4294967295 Slowest loop: 50.36ms; fastest: 0.09ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.4ms, write time 39.6ms, max retries 0 === Move === DMs created 83, segments created 19, maxWait 118823ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 19, completed 19, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0: pos 0.00, errs: frame 1 parity 0 ovrun 0 pol 0 ovdue 0 Extruder 1: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === Network === Slowest loop: 80.25ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1), 1 sessions HTTP sessions: 2 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 84:0d:8e:b3:bc:96 WiFi Vcc 3.45, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25264 WiFi IP address 192.168.1.7 WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 2 4 0 0 0 0 0 0
Thanks!
@thedragonlord You really need to run a base line test for each axis (so set the input shaper to "none") and then use that as the input to the recommendation stage. However I suspect that this will still select too low a frequency (as reported by Fred-Y above and I see the same thing). However by having the base results (with no input shaper), you may be able to judge for yourself what other tests to run and what frequency will work best for you. Remember that at the moment RRF only supports a single shaper for X and Y so you will need to select on that basis.
@mfs12 Are there any plans to change the way that the recommendations selects the target frequency? At the moment it always seems to select something that is too low.
@thedragonlord You might find the thread I started on input shaping of interest: https://forum.duet3d.com/topic/25931/input-shaping-testing-and-thoughts
Its a good idea to move your effector down at the end of homedelta.g to a position where any XY commands that are valid will not crash the carriages at the top of the endstops.
+1 for this
Also, to take this a bit further, it would be nice to be able to specify test moves by XYZ coordinates. On deltas (mine, at least) the resonances vary a lot based on effector position and direction of travel. Currently I do this using the Accelerometer plugin, but that has no way to overlay FFT graphs of multiple recordings and it takes a long time to do comparisons.
Hehehe ... sounds like I'm complaining, but this tuning process is soooo much better than it was in 3.3!
@t3p3tony Actually the firmware has been properly coded to handle this situation as it prevents these moves.
But I like your recommendation to move down the effector at the end of the homedelta file, I know some slicers (at least IdeaMaker) starts to move the effector on X/Y before moving down the effector causing an error.
@gloomyandy said in InputShaping-Plugin-0.2.0-pre7 released:
Ok, but it's not clear, after using the recomendation, how to choose the frequency to set in the M593....all the recomendation displays the same frequency....is this a plugin's bug? I know it's my fault due to my ignorance but except for the analysis I really can't understand how to use this plugin..
@thedragonlord Yes, it looks like the frequency chosen is not correct and it is probably a bug (which is why I was asking @mfs12 about it). Remember that this is all new software (and still not a final release), so there are likely to be problems.
Sure, I'm a programmer and I know well what it means to deliver a new software! I was asking just to be sure that I did understand how the plugin was supposed to work...for the fix we'll wait, no problem at all
I second this, I'm also working with software dev so I'm fully aware of the iteration cycles. Happy that someone is spending their time implementing this functionality.
The reason I started my thread, unaware of others though I spend too much time reading stuff here, was that I found it unclear wether this was a bug or something intentional.
So far the plugin is still experimental, I am having trouble doing the calculation of the response. Apparently it's dead simple according to an excel-sheet i have. But i wasn't able to reproduce this reliable in javascript. Until then this plugin is a little useless.
So far it's just useful to record and review shaper configurations.
Are there any experts here willing to support implementing the suggestion mechanism?
Hello everyone, I've now also tested the plugin. So far it works really well! I like it very much!
I have another suggestion or request. Would it be possible that when homing, if no axis is referenced, the Z-axis would not be referenced.
I have e.g. the accelerometer is attached to the bottom of the heating block, and in that case there would be a crash when homing.
Just as a suggestion. Home X and Y should be enough for the purpose ...Chrisitan from CR-3D
