    Resume fails sometimes
    961
    • Duncanundefined
      Duncan
      I'm running with Duet 3 6HC, all Z motors (4) to the Duet mainboard and X and Y motors to external expansion boards.
      My problem is that like 90% of times, I can Pause, change filament and then resume and no problems at all, but 10% times when I resume printer doesn't keep the right coordinates and start printing somewhere else...
      Any ideas what is happening those times that fails?
      Thanks
      • T3P3Tonyundefined
        T3P3Tony administrators @Duncan
        @duncan please post your config.g, pause and resume macros (using the </> formatting command here to make them easy to read. When you have a resume that does not work as expected please send M122 and M122 Bn where the Bn is the expansion board addresses and post those here as well (using the same formatting point to make them east to read).
        www.duet3d.com
        Duncanundefined 1 Reply Last reply Reply Quote 0
        • Duncanundefined
          Duncan @T3P3Tony
          @t3p3tony hello, my files:
          M552 P0.0.0.0 S1                                        ; enable network and acquire dynamic address via DHCP
          M586 P0 S1                                              ; enable HTTP
          M586 P1 S0                                              ; disable FTP
          M586 P2 S0                                              ; disable Telnet
          M584 X40.0 Y41.0 Z1:2:4:5 E20.0				; J- configuramos los motores X, Y, Z y E en cada posición de la placa principal o placas externas.
          M671 X1115:1115:-15:-15 Y1360:-260:-260:1360 S0.5	; J- configuramos la posición de los husillos respecto el origen (0,0) de la cama (no de los finales de carrera)
          ;M584 X40.0						; set X driver
          ;M584 Y41.0 					; set Y driver
          ;M584 Z1:2:4:5 					; set Z driver
          ;M584 E20.0						; set E driver
          M569 P0 S0                                           ; physical drive 0.0 goes forwards
          M569 P1 S0                                           ; physical drive 0.1 goes forwards
          M569 P2 S0                                           ; physical drive 0.2 goes forwards
          M569 P3 S0                                           ; physical drive 0.3 goes forwards
          M569 P4 S0                                           ; physical drive 0.4 goes forwards
          M569 P5 S0										; physical drive 0.5 goes forwards
          G4 S1 													;wait for expansion boards to start
          M569 P40.0 S1 R0 ;T2.7	EJE X									; change enable polarity, active = disable drive
          M569 P41.0 S1 R0 ;T2.7  EJE Y
          M569 P20.0 S1
                            				; set drive mapping
          M350 X16 Y16 Z32 E16 I1                           			; configure microstepping with interpolation
          M92 X133.333 Y133.333 Z1280 E420.00	         			; set steps per mm
          M566 X900.00 Y900.00 Z12 E120.00			       		; set maximum instantaneous speed changes (mm/min)
          M203 X10000.00 Y10000.00 Z500 E1200.00					; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E250.00		    			; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z2800 E800 I30		                    		; set motor currents (mA) and motor idle factor in per cent
          G21 									; TRABAJO EN MM
          G90 									; TRABAJO EN CORDENADAS ABSOLUTAS
          M84 S30                                                 		; Set idle timeout
          M208 X-50 Y-24 Z0 S1                                       		; set axis minima
          M208 X1100 Y1100 Z1000 S0                                  		; set axis maxima
          M574 X1 S1 P"io0.in"                                ; configure active-high endstop for low end on X via pin io0.in
          M574 Y1 S1 P"io1.in"                                ; configure active-high endstop for low end on Y via pin io1.in
          M574 Z1 S1 P"io3.in+io4.in+io5.in+io6.in" 		    ; configuramos finales de carrera eje Z según orden de motores
          M950 S0 C"20.io0.out"                          			 ; create servo pin 0 for BLTouch
          M558 P9 C"^20.io0.in" H10 F120 H200 T6000         		 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-20 Y40 Z1.2                      			 ; set Z probe trigger value, offset and trigger height
          ;M557 X50:1040 Y40:1000 S500                 			 ; define mesh grid
          M308 S1 P"temp3" Y"thermistor" T100000 B4725 C7.06e-8 R2200            ; configure sensor 1 as thermistor on pin temp0
          M950 H0 C"out0" T1                                      ; create bed heater output on out0 and map it to sensor 1
          M307 H0 A340 C2745.9 D25 S1.00 B0
          ;M307 H0 B1 S1.00                                        ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                 ; map heated bed to heater 0
          M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
          M308 S0 P"20.temp0" Y"thermistor" B4725 C7.06e-8        ; configure sensor 0 as thermistor on pin temp1
          M950 H1 C"20.out0" T0                                      ; create nozzle heater output on out1 and map it to sensor 0
          M307 H0 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
          M950 F0 C"20.out1" Q500                                    ; create fan 0 on pin out7 and set its frequency
          M950 F1 C"20.out2" Q500
          M106 P0 S255 H0 T50
          M106 P0 S0; Herramienta 2 PCF
          M563 P0 D0 H1 F0                                        ; define tool 0
          G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
          G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
          M591 D0 P1 C"20.io1.in" S2  ; filament monitor connected to E0_stop
          ;M591 D0
          ;M556 S100 X0 Y0 Z0 ; Put your axis compensation here
          ;M912 P9 S0 ; Put your CPU temperature sensor correction here
          ;M501 ; Run config-override.g
          ;T0 ; Select the first head
          M575 P1 S1 B57600                                       ; enable support for PanelDue
          M564 H0
          M302 P1
          ; pause.g
          ; called when a print from SD card is paused
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 31 2020 15:45:57 GMT+0800 (中国标准时间)
          M83            ; relative extruder moves
          G1 E-10 F3600  ; retract 10mm of filament
          G91            ; relative positioning
          G1 Z5 F360     ; lift Z by 5mm
          G90            ; absolute positioning
          G1 X0 Y0 F6000 ; go to X=0 Y=0
          USUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUS
          Wow, I didn't notice until now that resume.g has this code inside, why is that? I didn't change it and it was working before
          At the moment I have to print some pieces and can't test pause-resume until a few days, but I'll put something if I get the error again
          T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • T3P3Tonyundefined
            @duncan yes that is obviously not what should be in resume.g!
            www.duet3d.com
            • Duncanundefined
              Duncan @T3P3Tony
              @t3p3tony
              This one should work?
              ; resume.g
              ; called before a print from SD card is resumed
              ; generated by RepRapFirmware Configuration Tool v3.3.5 on Tue Nov 23 2021 11:54:18 GMT+0100 (hora estándar de Europa central)
              G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
              G1 R1 X0 Y0 Z0       ; go back to the last print move
              G1 E10 F3600         ; extrude 10mm of filament
              • T3P3Tonyundefined
                @duncan it looks better.
                www.duet3d.com
                • Duncanundefined
                  Duncan @T3P3Tony
                  @t3p3tony I try and first was try and error, here the M122 results
                  M122
                  RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                  Board ID: 08DJM-9P63L-DJ3S0-7JTD4-3S86P-9AJM9
                  Used output buffers: 1 of 40 (22 max)
                  Static ram: 150904
                  Dynamic ram: 92144 of which 0 recycled
                  Never used RAM 108288, free system stack 142 words
                  Tasks: NETWORK(ready,47.1%,224) ETHERNET(notifyWait,7.2%,117) HEAT(delaying,1.4%,325) Move(notifyWait,12.5%,247) CanReceiv(notifyWait,1.6%,774) CanSender(notifyWait,1.0%,362) CanClock(delaying,0.7%,339) TMC(notifyWait,132.8%,59) MAIN(running,49.8%,1092) IDLE(ready,0.0%,29), total 254.3%
                  Owned mutexes:
                  Last reset 117:09:14 ago, cause: power up
                  Last software reset details not available
                  Error status: 0x10
                  Aux0 errors 0,0,31
                  Step timer max interval 159
                  MCU temperature: min 35.3, current 45.4, max 48.9
                  Supply voltage: min 23.3, current 23.7, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
                  Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/180/168, gc cycles 0
                  Driver 0: position 57128, standstill, reads 34586, writes 11 timeouts 0, SG min/max 0/0
                  Driver 1: position 19315, standstill, reads 34520, writes 77 timeouts 0, SG min/max 0/516
                  Driver 2: position 4736, standstill, reads 34520, writes 77 timeouts 0, SG min/max 0/537
                  Driver 3: position 0, standstill, reads 34587, writes 11 timeouts 0, SG min/max 0/0
                  Driver 4: position 0, standstill, reads 34521, writes 77 timeouts 0, SG min/max 0/544
                  Driver 5: position 0, standstill, reads 34521, writes 77 timeouts 0, SG min/max 0/528
                  Date/time: 2021-11-24 17:02:06
                  Slowest loop: 244.06ms; fastest: 0.03ms
                  === Storage ===
                  Free file entries: 9
                  SD card 0 detected, interface speed: 25.0MBytes/sec
                  SD card longest read time 1.1ms, write time 799.9ms, max retries 0
                  DMs created 125, maxWait 26493523ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  Scheduled moves 5107, completed moves 5103, hiccups 0, stepErrors 0, LaErrors 0, Underruns [143, 23, 33], CDDA state 3
                  === AuxDDARing ===
                  Heater 0 is on, I-accum = 0.0
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 1
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is doing "G1 X506.026 Y244.066 E49.3093" in state(s) 0
                  USB is idle in state(s) 0
                  Aux is assembling a command in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty.
                  === Filament sensors ===
                  Extruder 0 sensor: no filament
                  === CAN ===
                  Messages queued 12407519, received 5272477, lost 0, longest wait 1ms for reply type 6042, peak Tx sync delay 699, free buffers 49 (min 17), ts 2108775/2108774/0
                  Tx timeouts 0,0,0,0,0,0
                  === Network ===
                  Slowest loop: 800.86ms; fastest: 0.02ms
                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
                  HTTP sessions: 1 of 8
                  - Ethernet -
                  State: active
                  Error counts: 0 0 1 0 0
                  Socket states: 5 2 2 2 2 0 0 0
                  M122 40
                  Used output buffers: 1 of 40 (25 max)
                  Static ram: 150904
                  Tasks: NETWORK(ready,28.5%,224) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,325) Move(notifyWait,0.1%,247) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,339) TMC(notifyWait,8.0%,59) MAIN(running,63.3%,1092) IDLE(ready,0.0%,29), total 100.0%
                  Owned mutexes: HTTP(MAIN)
                  Last reset 117:10:02 ago, cause: power up
                  Error status: 0x10
                  Aux0 errors 0,0,0
                  Step timer max interval 129
                  MCU temperature: min 45.0, current 45.2, max 45.5
                  Supply voltage: min 23.5, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                  Driver 0: position 58154, standstill, reads 3028, writes 0 timeouts 0, SG min/max not available
                  Driver 1: position 19467, standstill, reads 3028, writes 0 timeouts 0, SG min/max 0/501
                  Driver 2: position 4736, standstill, reads 3027, writes 0 timeouts 0, SG min/max 0/512
                  Driver 3: position 0, standstill, reads 3027, writes 0 timeouts 0, SG min/max not available
                  Driver 4: position 0, standstill, reads 3027, writes 0 timeouts 0, SG min/max 0/526
                  Driver 5: position 0, standstill, reads 3027, writes 0 timeouts 0, SG min/max 0/511
                  Date/time: 2021-11-24 17:02:54
                  Slowest loop: 3.09ms; fastest: 0.05ms
                  === Storage ===
                  SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  Scheduled moves 5355, completed moves 5341, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                  === AuxDDARing ===
                  Segments left: 1
                  HTTP is ready with "M122 40" in state(s) 0
                  File is doing "G1 X415.098 Y205.787 E0.4560 F4800" in state(s) 0
                  === CAN ===
                  Messages queued 1118, received 603, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 127, free buffers 49 (min 40), ts 240/240/0
                  === Network ===
                  Slowest loop: 3.44ms; fastest: 0.02ms
                  - Ethernet -
                  State: active
                  M122 41
                  Static ram: 150904
                  Tasks: NETWORK(ready,28.4%,224) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,325) Move(notifyWait,0.1%,247) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,339) TMC(notifyWait,8.1%,59) MAIN(running,63.2%,1092) IDLE(ready,0.0%,29), total 100.0%
                  Last reset 117:10:07 ago, cause: power up
                  Error status: 0x10
                  Aux0 errors 0,0,0
                  Step timer max interval 125
                  MCU temperature: min 44.9, current 45.0, max 45.2
                  Supply voltage: min 23.4, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 60177, standstill, reads 25223, writes 0 timeouts 0, SG min/max not available
                  Driver 1: position 18579, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/496
                  Driver 2: position 4736, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/506
                  Driver 3: position 0, standstill, reads 25223, writes 0 timeouts 0, SG min/max not available
                  Driver 4: position 0, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/513
                  Driver 5: position 0, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/506
                  Date/time: 2021-11-24 17:02:59
                  Slowest loop: 0.48ms; fastest: 0.05ms
                  === Storage ===
                  SD card longest read time 0.4ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  Scheduled moves 5374, completed moves 5366, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                  === AuxDDARing ===
                  Segments left: 1
                  HTTP is ready with "M122 41" in state(s) 0
                  File is doing "G1 X415.097 Y237.788 E2.3978" in state(s) 0
                  === CAN ===
                  Messages queued 99, received 56, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 5, free buffers 49 (min 44), ts 23/23/0
                  === Network ===
                  Slowest loop: 2.43ms; fastest: 0.02ms
                  - Ethernet -
                  State: active
                    Phaedrux Moderator @Duncan
                    @duncan said in Resume fails sometimes:
                    definitely something sus about this one.... 🤔
                    • Duncanundefined
                      Duncan
                      Now it seems to be failing all times I try to resume, any ideas?
                        Would you be willing to try the 3.4 betas to see if there is a difference in behaviour?
                        Can you upload your config.g and other macros homing, pause, etc as files so that we can see if there is something odd going on?
                        • Duncanundefined
                          Duncan @Phaedrux
                          @phaedrux
                          I have to finish some work in the machine and don't think can try new firmware on beta until 9th of December at least...
                          About my files, they are on my previous replys to @T3P3Tony all of them, config, pause and the new resume I updated after see the one that was wrong.
                            I mean can you upload them as actual files, that way all characters are preserved incase there is a bad hidden character or something.
                            • Duncanundefined
                              Duncan @Phaedrux
                              @phaedrux sorry, didn't understand what you were asking. Here they are.resume.g pause.g config.g
                                I don't see anything strange in there. Can you send M98 P"config.g" and see if any errors come up?
                                I look forward to seeing if the 3.4 release makes a difference here.
                                Duncanundefined 2 Replies Last reply Reply Quote 0
                                • Duncanundefined
                                  Duncan @Phaedrux
                                  @phaedrux I get this error:
                                  Error: Setting not available for external drivers
                                  Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                                  • Duncanundefined
                                    Duncan @Phaedrux
                                    @phaedrux any ideas? reading other issues of this error I think it's for the M350 and M906 that define X and Y motors that are with the external boards and drivers, but that can cause the problem of the resume?
                                    Is this a known error in 3.3 version? that's why you're suggesting trying 3.4 beta?
                                      There are many fixes between 3.3 and 3.4 so it would be helpful to know if those fixes have already solved your problem, or if it remains and requires further digging. Using the most recent code base makes that a bit easier.
                                      • Duncanundefined
                                        Duncan @Phaedrux
                                        @phaedrux I test this morning and it's very strange.
                                        If I use M600 and send the GCODE, the machine pause, and then I can use the resume button and works fine.
                                        But if I use the Pause button always fails...
                                        any ideas?
                                          Is that after updating to 3.4 beta 6?
                                          • Duncanundefined
                                            Duncan @Phaedrux
                                            @phaedrux no, still on 3.3.
                                            I don't know if I upgrade to beta if I can fix one thing and break a couple more...
