    Z setting ??
    Config Tool
    591
    • Robertoundefined
      Roberto
      Hello everyone,
      I have a problem with the tray adjustment. I changed the extrusion head and now the platen is too low in relation to the head. I do the all home, I get to 10mm, I go down 10mm, then I can go down another 0.5mm but when I want to go lower, it refuses.
      I changed the configuration but it doesn't change anything.
      Do you have a solution?
      Thank you.
      • oliofundefined
        oliof @Roberto
        @roberto how do you home Z? mechanical endstop or Z probe? If you use a mechanical endstop you'll need to adjust that. To move Z bezond Z=0 adjust M208 for the Z minimum; this of course only works when your movement system allows for that.
        Robertoundefined 1 Reply Last reply Reply Quote 0
        • Robertoundefined
          Roberto @oliof
          @oliof Hello, I use a BL Touch
          • oliofundefined
            oliof @Roberto
            @roberto then you will need to readjust the z offset for your probe.
            • Robertoundefined
              Roberto @oliof
              @oliof I put M208. It refuses to go lower than Z-0.5mm. I don't understand why?
              • Robertoundefined
                Roberto @Roberto
                @roberto I can't get the bed up near the nozzel
                • oliofundefined
                  oliof @Roberto
                  @roberto Set Z minimum to -1 or -4 for adjustment. But be careful to not break your mechanics.
                  • Robertoundefined
                    Roberto @oliof
                    @oliof Once I get to -0.5, the engines don't run anymore when I ask it to go to -1
                    • Robertoundefined
                      Roberto @Roberto
                      @roberto Do I have to raise the plate manually?
                      • oliofundefined
                        oliof @Roberto
                        @roberto when you adjust the Z axis parameter, it should move via GCode, provided it's mechanically possible.
                        • Robertoundefined
                          Roberto @oliof
                          @oliof I move the Z axis with the dashboard move command.
                          But, at Z-0.5mm, the motors don't respond anymore?
                          And the plate does not go up anymore. When I manually put the bed against the head, once I do the Z home, the bed goes back too far from the head. And even when I lower manually the tray voluntarily too much. I make the Zhome and again it comes to put itself with the same spacing with the head
                          • Robertoundefined
                            Roberto @Roberto
                            @roberto he writes:
                            Error: Z probe already triggered at start of probing move Error: G0/G1 : insufficient axes homed
                              Can you share your config.g and homeall.g and homez.g files as well as what firmware version you're using?
                              @oliof said in Z setting ??:
                              @Roberto Can the bed physically move higher or is it hitting an endstop or part of the frame preventing it from getting closer to the nozzle?
                              • Robertoundefined
                                Roberto @Phaedrux
                                @phaedrux Hello,
                                I did some more tests.When I do the homes, I can't get it to go lower than -0.5. But with the baby stepping, I can get the tray up to the nozzel.
                                I go into the config and make the change.
                                Then when I do the homes, the plate goes back too low and again from -0.5 I can't make it go up.
                                Here are the settings.
                                I think that it is the BL-Touch that is out of adjustment.
                                How can I recalibrate the BL-Touch?
                                Thanks for the help.
                                SYSTEME.docx
                                  Phaedrux Moderator @Roberto
                                  @roberto said in Z setting ??:
                                  Yes it sounds like you need to re-measure your bltouch offset and or ensure it's mounted in the right height.
                                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                  • Robertoundefined
                                    Roberto @Phaedrux
                                    @phaedrux Ok! I will check the calibration of the BLTouch.
                                    Thanks for the info.
