    Duet3 mini voron gantry level problem
    voron2.4 gantry level problem
    1.7k
    • jamaicarastaundefined
      jamaicarasta @jay_s_uk
      @jay_s_uk
      ok thanks i thought i have to start at p1 because my 4z motors are plugged into 1,2,3,4.
      I will Try it in a few Hours when I'm back at the printer.
      I'll let you know 👍🤝
      It's amazing how quickly you get an answer here.
        jamaicarasta @jumpedwithbothfeet
        @jumpedwithbothfeet
        where do i have 2 times x? don't quite understand. I gave correct points 4 times in my opinion.
        Thanks
        jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
          @jay_s_uk
          and one more question if i may. it does not go to my specified coordinates exactly. X15 stays at X40 on rehearsal. but if I drive normally with g1 then it drives exactly to x15. only at g32 is it off by 25.
            jay_s_uk @jamaicarasta
            @jamaicarasta it applies the G31 offsets to that, so if your probe is -25 in X, the nozzle has to be at 40 for the probe to be at 15
            jamaicarastaundefined 1 Reply Last reply Reply Quote 0
              @jay_s_uk
              ok i will check that i took a config from the internet from the beginning and maybe the value there is wrong for my probe
                @jay_s_uk
                So the error is gone, now I have the next error. is that something in the config file?
                G32
                Error: This kinematics does not support auto-calibration
                Config:
                General preferences -------------------------------------------------------
                M550 P"Duet Voron" ; set printer name
                M669 K1 ; select CoreXY mode
                ; Network --------------------------------------------------------------------
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                ; Drives ---------------------------------------------------------------------
                ; ----+---- Z-Drives
                ; | 2 | 3 |
                ; | 1 | 4 |
                ; Front
                M584 X5 Y6 Z1:2:3:4 E0 ; motor bindings
                M569 P0 S1 ; extruder motor direction
                M569 P1 S1 ; Z1 motor direction
                M569 P2 S0 ; Z2 motor direction
                M569 P3 S1 ; Z3 motor direction
                M569 P4 S0 ; Z4 motor direction
                M569 P5 S1 ; X motor direction
                M569 P6 S1 ; Y motor direction
                M350 X16 Y16 Z16 E16 I1 ; set microstepping
                M92 X80 Y80 Z400 E426 ; set microsteps per mm
                M566 X16000.00 Y16000.00 Z18000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X24000.00 Y24000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                M201 X6000.00 Y6000.00 Z3000.00 E1500.00 ; set accelerations (mm/s^2)
                M906 X800 Y800 Z800 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                ; thermal section ------------------------------------------------------------
                M308 S3 Y"mcu-temp" A"Board" ; Board thermal sensor
                M912 P0 S-2 ; MCU tempurature sensor correction (subtract 2°K)
                ; Axis Limits ----------------------------------------------------------------
                M208 X350 Y350 Z340 S0 ; set axis maxima
                ; Endstops -------------------------------------------------------------------
                M574 X2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io3.in
                M574 Y2 S1 P"io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
                M574 Z1 S2 "io1.in" ; configure switch-type (e.g. Probe) endstop for low end on Z via pin io1.in
                ; Z-Probe --------------------------------------------------------------------
                M558 K0 P8 A2 S0.05 C"^io1.in" H5 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
                G31 P500 X0 Y10 Z1.590 ; set Z probe trigger value, offset and trigger height
                M557 X15:335 Y15:335 S20 ; define mesh grid
                ; Heaters --------------------------------------------------------------------
                M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                M143 H1 S300 ; set temperature limit for heater 1 to 300C
                ; Fans -----------------------------------------------------------------------
                M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
                M106 P0 S1 H1 T60 ; set fan 0 value. Thermostatic control is turned on
                M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
                M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
                M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
                M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
                M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off
                ; Tools ----------------------------------------------------------------------
                ; Custom settings are not defined --------------------------------------------
                M501
                  @jamaicarasta You need an M671 to set the pivot points of the gantry.
                  I would probably go with the point where it the belts attach
                  jamaicarastaundefined 1 Reply Last reply Reply Quote 1
                    @jay_s_uk
                    ok m671… 😤 i forgot it. I read that yesterday. So measure again from the corner of the bed X0 Y0 and enter the minus value there?
                      @jamaicarasta yea, each one would typically sit outside the print area. the M671 should be in the order the Z motors are declared
                      jamaicarastaundefined 2 Replies Last reply Reply Quote 0
                        @jay_s_uk
                        Ah ok. Xmotor1:motor2:motor3:motor4 Ymotor1:motor2:motor3:motor4
                        You are my hero 🙏
                        I hope I can ask you a few more questions in the near future. I still have a few things I don't quite understand.
                          @jay_s_uk
                          I measured and found the values. Should I measure the values ​​from the probe points or simply add them to the entire coordinate system? Example X0Y0 as bett end x-55y-25 from bett end to my middle belt. Or measured from the probe coordinates I gave him.
                            @jamaicarasta the locations are in relation to X0 Y0
                              @jay_s_uk
                              Ok perfect 👍
                              it works great now. Is there once enough or should he do it several times before printing. It's a very good probe now, I'm only asking because the red probe that came with it always took 4 rounds or more. I exchanged it because it melted at 285 degrees carbon printing defies cork and polyimide tape...
                              • jumpedwithbothfeetundefined
                                jumpedwithbothfeet @jamaicarasta
                                @jamaicarasta you had the X listed twice in each line instead of one X and one Y
                                6 G30 P1 X15 X5 z-99999
                                however I suspect @jay_s_uk hit the nail on the head with the probe numbering being the actual issue and flagging up the warning 🙂
                                6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                                jamaicarastaundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                  @jumpedwithbothfeet
                                  Sorry that was a old file 😅
                                  I don’t saw this. Now is not x and x in one line 👊🏻
                                    jay_s_uk @jumpedwithbothfeet
                                    @jumpedwithbothfeet you can get it to run until for so many iterations until a set value is obtained.
                                    we have an example here https://teamgloomy.github.io/useful_macros.html#bedg-file-for-g32 that can ne used with 4 locations as well
                                      @jay_s_uk
                                      Thanks for the tip bro.
                                      Now I will make my mesh.g file.
                                      with an error: Push(): stack overflow
                                      ; mesh.g
                                      ; called to perform automatic bedmesh via G29
                                      M561 ; clear any bed...
                                      G29 ; bed mesh
                                      G1 X175 Y175 Z50 F20000 ; go to bed middle
                                      ; bed.g
                                      G30 P0 X15 Y20 Z-99999 ; Probe links vorne
                                      G30 P1 X15 Y315 Z-99999 ; Probe links hinten
                                      G30 P2 X335 Y315 Z-99999 ; Probe rechts hinten
                                      G30 P3 X335 Y20 Z-99999 S4 ; Probe rechts vorne
                                      G1 X175 Y175 Z5 F20000
                                      ; homeall.g
                                      ; called to home all axes
                                      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Feb 11 2022 17:57:25 GMT+0100 (Mitteleuropäische Normalzeit)
                                      G91 ; relative positioning
                                      G1 H1 X355 F6000 ; home X axis
                                      G1 X-5 F6000 ; go back a few mm
                                      G1 H1 X355 F360 ; move slowly to X axis endstop
                                      G1 H1 Y355 F6000 ; home y axis
                                      G1 Y-5 F6000 ; go back a few mm
                                      G1 H1 Y355 F360 ; move slowly to Y axis endstop
                                      G90 ; absolute positioning
                                      G1 X175 Y175 F20000 ; go to first probe point (Bettmitte)
                                      M558 K0 P8 A2 S0.05 C"^io1.in" H2 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
                                      G31 P500 X0 Y20 Z1.590 ; set Z probe trigger value, offset and trigger height
                                      M557 X15:335 Y35:315 S10 ; define mesh grid
                                      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                        @jamaicarasta not sure why you would receive a stack overflow. can you post an output of m122?
                                          @jay_s_uk What do you mean?
                                            @jamaicarasta send M122 on the console tab ans post here whats spat out
