    Extruder motor not working correctly after update
    939
    • GBusy24undefined
      GBusy24
      I spent forever getting updated to the current 3.3 from 2. something or other. Can't remember quite which it was. Anywho, my extruder motor (new) works, but not well enough to actually extrude filament. Seems like it's not getting enough current. I've played around w/ the current settings in the config.g, and report @800ma I get no movement while mounted in extruder assy. I have to turn the current to an unsafe level. i.e. 1100ma on a motor rated for 1.4 to get even partial operation. I need the groups help again. Let me know if you need me to share more info. Thanks
      No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @GBusy24
        @gbusy24
        People need you to:
        • Post your config.g
        • Tell us which Duet you have
        in order to be able to help at all.
        THEN I bet you'll get a bunch of friendly help.
        GBusy24undefined 1 Reply Last reply Reply Quote 0
        • GBusy24undefined
          GBusy24 @alankilian
          @alankilian I've have both a 1st gen board and a 2nd gen board. I've tried both with identical config.g's. Here is the config.g I'm using with both boards on a custom CoreXY machine. ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 24 2022 20:50:56 GMT-0500 (Eastern Standard Time)
          M550 P"CoreXY 1" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes forwards
          M569 P1 S0 ; physical drive 1 goes forwards
          M569 P2 S0 ; physical drive 2 goes forwards
          M569 P3 S0 ; physical drive 3 goes forwards
          M92 X80.00 Y80.00 Z400.00 E837.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z800.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X320 Y185 Z300 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
          M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
          M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
          ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          ;M557 X15:215 Y15:185 S20 ; define mesh grid
            alankilian @GBusy24
            @gbusy24
            OK, you were running firmware revision 2.something and it was working fine and you updated to firmware version 3.3 and now your extruder doesn't move much at all.
            And you changed nothing other than the firmware revision.
            Is that right?
            I don't suppose you have your old 2.x config.g do you?
            • GBusy24undefined
              GBusy24 @alankilian
              @alankilian Well, that's right in a way, but sooo many things changed going from 2.? to 3.0 and above. It wasn't a matter of simply copying everything over because of all the changes like the 'M' commands.
                When you say it won't work, is that with or without filament loaded?
                When you increase the current it does move? Is that when extruding plastic?
                Perhaps your thermistor values didn't get brought along and your temps are off?
                1100ma on a 1400ma board is still within the the 60-85% of rated, albeit at the high end.
                • GBusy24undefined
                  GBusy24 @Phaedrux
                  @phaedrux With filament loaded.Increase in current makes it move and extrude somewhat. DWC reports being at print temp. Yes, current that high concerns me. Really want to resolve this. I have a big project I'm ready to start
                  • deckingmanundefined
                    deckingman @GBusy24
                    @gbusy24 said in Extruder motor not working correctly after update:
                    As a general rule, needing to set high motor current to get an extruder to work is a sign that something else is amiss. That "something else" is a restriction to flow which might be caused a partial blockage or attempting to extrude at too low a temperature. Are you sure that the temperature reading is accurate? Have you tried raising the hot end temperature and if so what happens? Have you checked for any partial blockages, either in the nozzle or in the heat break area?
                    • GBusy24undefined
                      GBusy24 @deckingman
                      @deckingman Along with the update to 3.3, I also refurbished the hotend. New heater block, new thermistor, new heat break, new heat sink and nozzle also. New everything after 6 years of heavy use. I'm using the same filament I used for almost 4 yrs. Printing at same temp I always have with this filament. The extruder motor is brand new too. E3d 0.9 resolution pancake stepper.
                      OwenDundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                      • OwenDundefined
                        OwenD @GBusy24
                        Were you running the same motor before?
                        I am using an E3D pancake motor on my titan aero and found I needed fairly high currents to get the little motor to work reliably at higher feed rates.
                        I have no problems because the water cooled block also keeps the motor very cool.
                          deckingman @GBusy24
                          @gbusy24 Have you considered the possibility that the reason your extruder motor doesn't work after updating the firmware might be something to do with the miriad of other changes you made at the same time (including changing the motor itself), rather than a firmware issue?
                          GBusy24undefined 2 Replies Last reply Reply Quote 0
                          • GBusy24undefined
                            GBusy24 @deckingman
                            @deckingman Yes, but I've unfortunately been at all this for quite some time B4 I ever dreamed of posting my issues on the forum. That's just how I am. I go to great lengths to work things out on my own first. Therefor, I now cry out. LOL
                            • GBusy24undefined
                              GBusy24 @deckingman
                              @deckingman and OwenD, I threw caution to the wind and upped the current to 1200ma and things are working as I want now, that's 86%. Lotta current, but if it works......................
                              • GBusy24undefined
                                GBusy24 @OwenD
                                @owend What currents are you running?
                                • OwenDundefined
                                  OwenD @GBusy24
                                  @gbusy24
                                  I'm actually running 1400mA on that motor.
                                  I started at about 1100 and as the motor was stone cold when running, because of the liquid cooling, I eventually increased it up to the maximum rated current.
                                  It still runs cold and I've had no issues although I'm not a high volume user.
                                  I can't guarantee the same results for you, especially if you don't have a liquid cooled extruder system.
                                    deckingman @GBusy24
                                    @gbusy24 What diameter nozzle do you use? If it's 0.4mm consider using 0.5mm. You will arguably lose 0.1mm in resolution if you print small, highly detailed parts, but a 0.5mm nozzle has circa 50% more area than a 0.4mm nozzle and you'll find that you can extrude reliably using much less extruder pressure (motor torque).
                                    • GBusy24undefined
                                      GBusy24 @OwenD
                                      @owend Thanks for your reply.
                                      • GBusy24undefined
                                        GBusy24 @deckingman
                                        @deckingman I may give that a try. Thanks
                                          dc42 administrators @GBusy24
                                          @gbusy24 if you run:
                                          M98 P"config.g"
                                          are any errors reported?
                                          • GBusy24undefined
                                            GBusy24 @dc42
                                            @dc42 Hi, I just saw your message and ran the command. E-thing seems good to go. Here's the response: "M98 P"config.g"
                                            HTTP is enabled on port 80
                                            FTP is disabled
                                            TELNET is disabled
                                            I've come to terms that this smaller stepper needs higher current than normal sized steppers. I'm okay with that. I've used this motor for years on my setup and haven't had any problems. I am going to show it a lil' love tho with a nice heatsink that arrives tomorrow
