    Software bundle 3.4.0 stable released!
    Firmware installation
    24
    52
    3460
      On behalf of the Duet3D team I am please to announce the release of RepRapFirmware, Duet Web Control and Duet Software Framework 3.4.0 stable.
      RepRapFirmware 3.4.0 brings more than 90 new and improved features and around 80 bug fixes. New features include:
      • Input shaping, to allow faster print speeds without exciting ringing
      • Thumbnail image display of print files in Duet Web Control and on PanelDue (requires a compatible slicer and PanelDue firmware 3.4.1-pre2
      • Heater feedforward, to maintain more even nozzle temperatures on high flow rate extruders
      • More flexible control of power supplies
      • More control over machine behaviour when heater faults, stepper driver warnings etc. occur
      • Support for the new Duet 3 MB6XD main board for use with external drivers, and the EXP1HCL closed loop stepper motor control board
      • Coordinate rotation in the XY plane
      Duet Web Control and Duet Software framework now provide:
      • Improved plugin support and new plugin guides for DWC and DSF
      • A new HTTP class library for remote control of Duets in standalone and SBC mode
      • 12864 display support in SBC mode
      Important! If you are upgrading from software 3.3 or earlier, read at least the upgrade notes section of the RRF 3.4.0 release notes to see what alterations if any you may need to make to your configuration and macro files. Users already running 3.4.0RC2 can instead check the abbreviated release notes.
      Upgrade instructions:
      • For Duet in standalone mode you can find the upgrade files here. Most users can just upload the Duet2and3Firmware-3.4.0.zip file.
      • For Duet with attached Single Board Computer, upgrade from the stable feed on the Duet3D package server using apt-get as usual.
      Please do not use this thread to report issues with this release that require a response; start a new thread for those instead.
      fcwilt damaged_goods 2 Replies Last reply Reply Quote 20
      • Pinned by  chrishamm chrishamm
      • fcwilt
        fcwilt @dc42 last edited by
        I have avoided 3.4.x to date - just too busy with other things.
        There are a LOT of things I now have to learn.
        Thanks for all the hard work.
        NightLonk42 1 Reply Last reply Reply Quote 0
        • NightLonk42
          NightLonk42 @fcwilt last edited by NightLonk42
          @dc42 Awesome!
          I'm not able to update currently but a couple questions.
          Is the Input Shaping plugin be installed by default? Also, will the Input Shaping page be updated to give more detail any time soon?
          Thanks!
          fcwilt zapta chrishamm 3 Replies Last reply Reply Quote 0
          • fcwilt
            fcwilt @NightLonk42 last edited by
            @nightlonk42 said in Software bundle 3.4.0 stable released!:
            @fcwilt
            Awesome!
            I'm not able to update currently but will the Input Shaping plugin be installed by default?
            Also, will the Input Shaping page be updated to give more detail?
            Thanks!
            I have no idea. I haven't yet worked up the courage to install 3.4.
            NightLonk42 1 Reply Last reply Reply Quote 1
            • NightLonk42
              This post is deleted!
              • zapta
                zapta @NightLonk42 last edited by zapta
                I found the one below. Not sure if it was installed by 3.4 or was there before. Also, IIRC there was another 'external' accelerometer plugin which doesn't seem to be installed. (The TrueImage popup is a system artifact, not related to DWC).
                • chrishamm
                  chrishamm administrators @NightLonk42 last edited by
                  @nightlonk42 @zapta You can find the plugins (except for the closed loop plugin beta that is still on its own repo) here: https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.4.0 You can expect more improvements for the input shaper tuning soon.
                  Duet software engineer
                  fractalengineer zapta 2 Replies Last reply Reply Quote 1
                  • bberger
                    bberger last edited by bberger
                    I'm already looking forward to 3.5 πŸ™‚ Been a happy 3.4 early adopter for quite some time now and Input Shaping brings so much to the table. Exciting times! Hopefully the IS Plugin gets to the point of comfort and ease-of-use as in Klipper!
                    Hopefully the trend to better motion planning continues, keep up the good work!
                    • fractalengineer
                      fractalengineer @chrishamm last edited by
                      @chrishamm those look neat, I can't seem to be able to install them though?
                      I get this error message:
                      InvalidOperationException in InstallPlugin: Cannot perform command because the plugin service is not started
                      Any tips?
                      Thanks!
                      Railcore II ZL
                      chrishamm 1 Reply Last reply Reply Quote 0
                      • zapta
                        zapta @chrishamm last edited by zapta
                        @chrishamm, do the extra plug-ins work with stand alone duet? (Asking because they have DSF in their path)
                        jay_s_uk 1 Reply Last reply Reply Quote 1
                        • jay_s_uk
                          jay_s_uk @zapta last edited by
                          @zapta only the motion one is SBC only
                          • Mike3D
                            Mike3D last edited by
                            Thanks for this update.
                            I can see the thumbnails on the pc using webcontrol.
                            But i see no thumbnails on the PanelDue.
                            On the PanelDeu is the latest firmware 3.4.1-pre2.
                            The slicer i have is Prusaslicer and thumbnails are 160x160.
                            jjude dc42 2 Replies Last reply Reply Quote 0
                            • jjude
                              jjude @Mike3D last edited by
                              @mike3d note: PanelDue can only use QOI format. PrusaSlicer 2.4.1 not creating yet QOI.
                                dc42 administrators @Mike3D last edited by dc42
                                @mike3d you can get Windows and Mac binaries of a fork of Prusa Slicer that supports QOI format from https://github.com/n8bot/PrusaSlicer/releases/tag/version_2.5.0-alpha0%2Bn8-release1. This version also has the option to retrieve the machine parameters from the Duet via http, if you have configured it for upload via http. Thanks to user @bot for implementing all of this.
                                bberger 1 Reply Last reply Reply Quote 3
                                • chrishamm
                                  chrishamm administrators @fractalengineer last edited by
                                  @fractalengineer Have a look at the DSF upgrade notes for v3.3, it sounds like you missed them.
                                  • bberger
                                    bberger @dc42 last edited by
                                    @dc42 said in Software bundle 3.4.0 stable released!:
                                    This is big news. Especially on the Duet integration part.
                                    bot 1 Reply Last reply Reply Quote 0
                                    • zapta
                                      Thanks @chrishamm, I was able to install the external input shaping plugin. Next will figure out how to use it.
                                      BTW, if most of the external plugins are not DSF specific, maybe remove DSF from their path on github?
                                      • bot
                                        bot @bberger last edited by
                                        @bberger I have submitted a Pull Request to PrusaSlicer to include those integrations: https://github.com/prusa3d/PrusaSlicer/pull/8087
                                        n8bot created this issue in prusa3d/PrusaSlicer
                                        open Fix RRF Time Estimates and Add "Get Machine Limits" button for Duet printer hosts #8087
                                        *not actually a robot
                                        1 Reply Last reply Reply Quote 6
                                        • ctilley79
                                          ctilley79 last edited by
                                          Is there a roadmap for RRF 3.5 available? What will be its focus?
                                          oliof 1 Reply Last reply Reply Quote 1
                                          • oliof
                                            oliof @ctilley79 last edited by
                                            @ctilley79 Looking at the Github commit history, independent gcode streams seems to be the main feature being developed right now.
                                            <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
                                            ctilley79 1 Reply Last reply Reply Quote 0
                                            • StevenL
                                              StevenL last edited by
                                              Failed up to Upgrade from 3.2.2 to 3.4.0
                                              Wifi card is stuck in Starting mode. no actual IP working.
                                              Help!
                                              Do I need to revert back to 3.2.2 or reset back to factory or what?
                                              Please advise
                                                Phaedrux Moderator @StevenL last edited by
                                                @stevenl said in Software bundle 3.4.0 stable released!:
                                                Help!
                                                Please advise
                                                You may need to reflash the wifi module. Try sending M997 S1 from the USB terminal.
                                                • ctilley79
                                                  ctilley79 @oliof last edited by
                                                  @oliof I was hoping they would continue to work on input shaper implementation because I believe it still lags behind Klipper.
                                                    dc42 administrators @ctilley79 last edited by
                                                    @ctilley79 said in Software bundle 3.4.0 stable released!:
                                                    In what way? We are continuing work on the IS plugin to make it easier to use accelerometer data to tune IS.
                                                    Argo 1 Reply Last reply Reply Quote 0
                                                    • Argo
                                                      Argo @dc42 last edited by
                                                      Differences I see compared to Klipper right now:
                                                      • separate shaper frequency for each axis
                                                      • automatic resonance testing (with a accelerometer): Klipper firmware generates vibrations from lower to higher frequencies and tests each shaper for itβ€˜s effectiveness at each frequency. The results and recommendations are then displayed in a graph. It also recommends maximum acceleration values.
                                                        Example:
                                                      721e564d-2a11-405f-a5e4-4aaa59d925df-image.png https://www.klipper3d.org/img/calibrate-y.png
                                                      dc42 1 Reply Last reply Reply Quote 3
