    Software bundle 3.4.0 stable released!
    Firmware installation
    24
    52
    5.9k
    • Schickfusundefined
      Schickfus @jay_s_uk
      @jay_s_uk ok
      • Stephen6309undefined
        Stephen6309 @damaged_goods
        @damaged_goods I use SuperSlicer. https://github.com/supermerill/SuperSlicer/releases
        It has thumbnails compatible with the PanelDue.
        • chrishammundefined chrishamm unpinned this topic
        • tfjieldundefined
          tfjield
          @dc42 said in Software bundle 3.4.0 stable released!:
          Thumbnail
          Anyone know how to get thumbnail generation in Cura?
          • oliofundefined
            oliof @tfjield
            @tfjield Install the RRF plugin for Cura.
              @tfjield said in Software bundle 3.4.0 stable released!:
              https://github.com/Kriechi/Cura-DuetRRFPlugin/releases/tag/v1.2.5
              tfjieldundefined 1 Reply Last reply Reply Quote 0
              • tfjieldundefined
                tfjield @dc42
                @dc42 @oliof
                I installed it, and all I see is that it's asking me to link my printer...
                Does this require me to send the file to the printer directly? Or can I just save the gcode with the image embedded?
                Phaedruxundefined oliofundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @tfjield
                  @tfjield That plugin allows you to send the gcode files directly to the printer, yes, and also will embed the thumbnail. I believe you can also save the gcode file locally.
                  • oliofundefined
                    oliof @tfjield
                    @tfjield it will ask you to link to a printer, but after you sliced a file you will see a little caret on the blue "Send to ..." button where you can choose to save the file locally.
                    tfjieldundefined 2 Replies Last reply Reply Quote 1
                    • tfjieldundefined
                      tfjield @oliof
                      @oliof @Phaedrux Thank you!
                      • tfjieldundefined
                        tfjield @oliof
                        @oliof
                        After I installed it, I now have 4 options after slicing:
                        • Simulate on xxx
                        • Print on xxx
                        • Upload to xxx
                        • Save to Disk
                        If I choose Save to Disk, it looks like the plugin is bypassed and the thumbnail isn't generated. All of the other 3 options appear to require my printer to be online.
                        Is this correct, or am I doing something wrong?
                        oliofundefined resamundefined 2 Replies Last reply Reply Quote 0
                        • oliofundefined
                          oliof @tfjield
                          @tfjield its probably worth to open a separate thread for this discussion so we can drag in @resam who is the plugin author.
                          • resamundefined
                            resam @tfjield
                            @tfjield short answer: the "Save to Disk" option is from plain Cura - not my plugin. If you want a dedicated "Save to Disk with thumbnails"-like option, let's move the conversation to a new thread.
                            • tfjieldundefined tfjield referenced this topic
