    Software bundle 3.4.0 stable released!
    Firmware installation
    24
    52
    5.9k
    • StevenLundefined
      StevenL
      Failed up to Upgrade from 3.2.2 to 3.4.0
      Wifi card is stuck in Starting mode. no actual IP working.
      Help!
      Do I need to revert back to 3.2.2 or reset back to factory or what?
      Please advise
        Phaedrux Moderator @StevenL
        @stevenl said in Software bundle 3.4.0 stable released!:
        Help!
        Please advise
        You may need to reflash the wifi module. Try sending M997 S1 from the USB terminal.
        • ctilley79undefined
          ctilley79 @oliof
          @oliof I was hoping they would continue to work on input shaper implementation because I believe it still lags behind Klipper.
            dc42 administrators @ctilley79
            @ctilley79 said in Software bundle 3.4.0 stable released!:
            In what way? We are continuing work on the IS plugin to make it easier to use accelerometer data to tune IS.
            Argoundefined 1 Reply Last reply Reply Quote 0
            • Argoundefined
              Argo @dc42
              Differences I see compared to Klipper right now:
              • separate shaper frequency for each axis
              • automatic resonance testing (with a accelerometer): Klipper firmware generates vibrations from lower to higher frequencies and tests each shaper for it‘s effectiveness at each frequency. The results and recommendations are then displayed in a graph. It also recommends maximum acceleration values.
                Example:
              721e564d-2a11-405f-a5e4-4aaa59d925df-image.png https://www.klipper3d.org/img/calibrate-y.png
              dc42undefined 1 Reply Last reply Reply Quote 3
                dc42 administrators @Argo
                @argo separate shaper per axis is not only unnecessary (because the supported shapers cover frequency ranges of up to 3:1), it is a bad idea because if you use different shape on different axes then the motion of the axes will no longer be synchronised during acceleration and deceleration. This will result in print artefacts, for example on corners that are not aligned with the axes.
                I already said that we are continuing work on the input shaping plugin to make tuning IS easier.
                zaptaundefined 1 Reply Last reply Reply Quote 6
                • zaptaundefined
                  zapta @dc42
                  @dc42 said in Software bundle 3.4.0 stable released!:
                  How about a single input shaping that is direction dependent? That is, some interpolation for angles between X only and Y only?
                  (I don't know how input shaping works, just thinking loud).
                  • chrishammundefined
                    chrishamm administrators @zapta
                    @zapta Applying two different input shapers on two axes has certain downsides so we decided it would be better to support only a single input shaper for two axes to damp both ringing frequencies.
                    We have a first beta of a new input shaping plugin ready but we need to discuss a few more details internally before we eventually release it. I expect we'll publish it sometime this week.
                    Duet software engineer
                    samlogan87undefined zaptaundefined 2 Replies Last reply Reply Quote 2
                    • samlogan87undefined
                      samlogan87 @chrishamm
                      @chrishamm looking forward to this
                      Custom Core-XY
                      • zaptaundefined
                        zapta @chrishamm
                        @chrishamm said in Software bundle 3.4.0 stable released!:
                        I was thinking about a single input shaper but in direction of movement rather than direction of axises. Here is an example, let's say that you want to optimize a 45deg movement in a cartesian printer. You run the input shaping calibration process with moves in 45deg, analyze to determine frequencies and IS parameters, and then when you move in 45%, you use that input shaper. Now imagine that you test IS for direction in 45deg increment and when you move for example in direction of 50deg, you use some interpolation to determine the input shaping in that direction.
                        (I must say that I don't know how input shaping works but my understanding that it's some kind of modulation of the movement which can be applied for movements in any directions)
                        Does this make sense?
                          dc42 administrators @zapta
                          @zapta given that the input shapers supported by RRF have effective bandwidths of up to 3:1, it's not necessary to do anything as complex as that.
                          To get a 3:1 ratio of resonant frequencies on the X and Y axes, and assuming X and Y axes use belts of approximately equal width, length and tension, you would need a mass ratio of 9:1. That's higher than you are likely to get even in a large bed slinger.
                          zaptaundefined SputnikOC3dundefined 2 Replies Last reply Reply Quote 2
                          • zaptaundefined
                            zapta @dc42
                            @dc42, thanks for the explanation.
                            • SputnikOC3dundefined
                              SputnikOC3d @dc42
                              @dc42 - this release seems to be breaking my Nozzle Heater on the 1LC.
                              my lonely forum post
                              • damaged_goodsundefined
                                damaged_goods @dc42
                                @dc42 Hey David. Thanks to you and others for all the work you are putting into reprap.
                                As a Prusa user I am use to being spoon fed firmware and Slicer settings. Is there a Reprap Slicer that the community finds works best?
                                Thanks again.
                                BoAundefined zaptaundefined Stephen6309undefined 3 Replies Last reply Reply Quote 0
                                • BoAundefined
                                  BoA @damaged_goods
                                  @damaged_goods I use Prusa Slicer - it works perfectly fine.
                                  damaged_goodsundefined 1 Reply Last reply Reply Quote 0
                                  • zaptaundefined
                                    zapta @damaged_goods
                                    @damaged_goods said in Software bundle 3.4.0 stable released!:
                                    For what printer and what Duet board? Duet3d Mini5 on Prusa MK3?
                                    • Schickfusundefined
                                      Schickfus
                                      I have a MB6HC with a SBC-Rasbarry Pi 4.
                                      I am using the apt-get update / apt-get upgrade. It says that nothing to upgrade. But when I try the M115 command it says firmware 3.2.2
                                      Do I do something wrong?
                                      I have been following the documentation.
                                        damaged_goods @BoA
                                        @boa Thank you,
                                          damaged_goods @zapta
                                          @zapta It's a custom built very large printer with a duet 3 MB6HC.
                                            jay_s_uk @Schickfus
                                            @schickfus can you open a separate thread for your issue please
                                            Schickfusundefined 1 Reply Last reply Reply Quote 0
