    Scanning Z probe support in RRF 3.5
    Beta Firmware
    23
    128
    10.1k
    • oliofundefined
      oliof @samlogan87
      @samlogan87 dc42 wrote upstream
      For the future, we are considering making a dedicated CAN-connected board to support the LDC1612 as well as tool board variants with this chip on board.
      samlogan87undefined 1 Reply Last reply Reply Quote 2
      • lparnell34undefined
        lparnell34
        @dc42 I was trying to test z probe scanning but it seems the probe is reading wrong. It says 22768239 under z probe on dwc dashboard. When I run G29 K1 it scans the bed but the max deviation is 1256mm and after it's done scanning it keeps lowering the Z axis until it bottoms out and grinds.
          dc42 administrators @lparnell34
          @lparnell34 you may need to adjust the drive level of the sensor. Run M122 B# where # is the address of the tool board and look at the LDC1612 status at the end. It should report the drive level but it may also report "amplitude error". If you run M122 again it should report a new drive level and no error. After that the sensor should work properly. This is best done with the sensor as close to the bed as you expect it to get during scanning. I set a nominal Z height of 3mm as the trigger height in G31 and I don't expect more than 1mm of error, so I did this at 2mm Z height.
          • samlogan87undefined
            samlogan87 @oliof
            @oliof missed that. Thanks for pointing that out 👍
            Custom Core-XY
            • jay_s_ukundefined jay_s_uk referenced this topic
            • JoergS5undefined
              JoergS5 @dc42
              This post is deleted!
              • gringoundefined
                gringo
                Z-Probe scanning
                Here is another sensor.
                • A Former User?
                  A Former User @gringo
                    droftarts administrators @A Former User
                    @Herve_Smith I should imagine the one @gringo linked is a clone of the Beacon probe. But it does seem to be permanently attached, and has a couple of interesting 'extras' in the video: fast manual bed levelling (just set the probe above the bed at a corner/leadscrew and adjust the bed to the probe) and adjusting the nozzle in real time during the print (though I guess this only works on the first few layers, and with a metal sheet bed). I don't know if Beacon has shown this functionality before?
                      dc42 administrators @droftarts
                      I think the one that @gringo linked to may pre-date the Beacon. It claims to be supported by Marlin since August 2022 and its Github repo goes back to May 2022.
                      • A Former User?
                        A Former User @dc42
                          @Herve_Smith Link to doc should be: https://github.com/markniu/Bed_Distance_sensor/wiki/Data-Protocol
                          • A Former User?
                            A Former User @droftarts
                              @Herve_Smith said in Scanning Z probe support in RRF 3.5:
                              I thought i already had linked to it.
                              You did, but the link didn't work. I posted the correct link. You have since edited your original post, with the correct link. You can see the post edit history by clicking on the small square icon next to the post date.
                              • A Former User?
                                • martin7404undefined
                                  martin7404
                                  I am sorry to write on old tread but I have a lamer question is this going ot support duet 2 wifi
                                  Muldex IDEX Duet2+Duex5
                                  Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                                  Sapphire Pro with Duet2, with closed-loop motors
                                  custom high temp E3D tool changer with Duet2+Duex
                                  • T3P3Tonyundefined
                                    T3P3Tony administrators @martin7404
                                    @martin7404 our implementation will use a CAN-FD based sensor board so only compatible with Duet 3.
                                    www.duet3d.com
                                    • flyschaundefined
                                      flyscha @dc42
                                      Any chance you have an update to what these codes should be, with the production SZP?
                                      I've tried using these codes and adjusting accordingly, but there seems to be a disconnect when it comes to at least calling out the C"xxxx" you used in the M558 line. I'm using the CAN1_L & CAN1_H pins, but when I try to call them out while using the CAN address assigned to the SZP, I'm getting an error of "expansion boards do not support Z probe output ports".
                                      Also, I'm getting another error of "Invalid Z probe index" for the G31 line, but I'm not sure if it's a problem stemming from the M558 line.
                                      Any help is appreciated.
                                      Thanks!
                                        dc42 administrators @flyscha
                                        @flyscha use C"120.i2c.ldc1612" assuming it is at the default CAN address 120.
                                        flyschaundefined 1 Reply Last reply Reply Quote 0
                                        • flyschaundefined
                                          flyscha @dc42
                                          @dc42 That worked, thank you so much!
                                          Is there somewhere where this type of information is listed within the docs, where odd pin names that aren't called out on the board pinout diagrams are talked about? Or maybe I just didn't search in the proper place?
                                            @flyscha I think it's been omitted from the documentation. We will correct it.
