    Software bundle 3.5.0rc.4 now available
    Firmware installation
    16
    41
    1.9k
    • Exerqtorundefined
      Exerqtor @dc42
      It's been working flawlessly without issues (other than my self imposed ones) on my Duet 3 Mini & 1LC in standalone mode 🤟
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
      • T3P3Tonyundefined
        T3P3Tony administrators @Exerqtor
        @Exerqtor thanks for the feedback!
        www.duet3d.com
        • BlitzRegundefined
          BlitzReg
          3.5rc4
          I'm getting H1 Heater faults which I had no issues with my hypercube. I have to clear out the faults and then H1 heats up and I have no problems during print. The faults only happen when I try try to prewarm the bed and extruder. I ran M303 on both the bed and the extruder. No problem on the extruder but I do get a yellow warning on the bed. I even tried tuning at a lower temp and same thing on the bed. When I updated my firmware the wifi quit working and I had to use the terminal software with cable to get it working again. when I watch the graph during print the temps are staying in a straight line.
          • gloomyandyundefined
            gloomyandy @BlitzReg
            @BlitzReg What version of RRF (and the WiFi firmware) did you have installed before this upgrade?
            • CrazyCreatorundefined
              CrazyCreator
              Today i try to Update my Board.
              But:
              Now i only can connect with ssh.
              No connect per LAN or WLAN possible.
              How can i restart the update prozess?
              On DWC i see this:
              http://www.crazycreatorcube.com
              • chrishammundefined
                chrishamm administrators @CrazyCreator
                @CrazyCreator see here
                Duet software engineer
                CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                  CrazyCreator @chrishamm
                  @chrishamm omg ... really? the hard way?
                    @CrazyCreator I don't know why your update failed (DCS stopped in the background for some reason?) but yes, with an invalid firmware image you need to use bossa. It's already preinstalled on the SBC, too.
                      @chrishamm
                      Unfortunately, I can't find how to flash the firmware from the Pi onto the board. Can access the Pi via VNC...
                      And next strange problem. In the Docu is writing:
                      Erase the firmware on the Duet by either:
                      Pressing the Erase button (next to the reset button on older Duets); or Jumpering the erase jumper
                      Remove the erase jumper once the Diag LED lights up.
                      But i can't find this Pins for jumper it.
                      Maybe this is the reason for this:
                      But what's much stranger is that when I connect the board to the USB on the PC, nothing happens.
                      Neither on the Mac nor on the Windows PC... The board does not appear.
                      Do I have to disconnect all cables (Motor, Endstops, heater etc) beforehand and only the USB cable can be plugged in?
                      All other cables are of course without power, the main switch of the printer is turned off.
                        droftarts administrators @CrazyCreator
                        @CrazyCreator I expect the firmware flash got part way through and failed. Using the erase jumper should get it back to a state where it will be recognised and firmware can be flashed via USB. This can be done from the Raspberry Pi, usually by sending the command:
                        ~/BOSSA/bin/bossac -e -w -v -b /opt/dsf/sd/firmware/Duet3Firmware_MB6HC.bin
                        Erase jumper is here:
                        CrazyCreatorundefined 1 Reply Last reply Reply Quote 1
                          CrazyCreator @droftarts
                          @droftarts Mhhhh ... Thanks all for the helping, but i don't have a erase jumper 😞
                            jay_s_uk @CrazyCreator
                            @CrazyCreator looks like a cloned board. best ask Fysetc...
                              CrazyCreator @jay_s_uk
                              @jay_s_uk The board came with the printer... No idea if it's a clone or not. But the clones are also made according to the specifications, aren't they?
                                @CrazyCreator well its black, so its a clone.
                                And I know some Fysetc "clones" don't 100% match duet boards
                                  @jay_s_uk
                                  What kind of rubbish is that?
                                  Well then I'll try to bridge the two pins.
                                  If the board wears out, then at least an original one comes in 😉
                                  btw
                                  Here is a picture of a board from Filafarm (official seller in Germany), there is no erase jumper at this position. However, that is a 0.6 board in the picture.
                                  infiniteloopundefined 1 Reply Last reply Reply Quote 1
                                  • infiniteloopundefined
                                    infiniteloop @CrazyCreator
                                    @CrazyCreator
                                    Here you are:
                                      CrazyCreator @infiniteloop
                                      @infiniteloop
                                      I know... I saw that.
                                      I just wanted to show that there are also duet boards where the jumper is in a different place. So it's quite possible that this is the case on my board too.
                                        @CrazyCreator clones are based on the v1, not the 0.6
                                          @jay_s_uk
                                          But ... My Erase Button is on Position from v0.6 and on the Board itself is writing v1.01 ... it's a little bit funnny 😉
                                            3.5 is now released
                                            https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0
                                            • Phaedruxundefined Phaedrux locked this topic
