    Guide for posting requests for help
    7.4k
    • T3P3Tonyundefined
      T3P3Tony administrators
      Please help everyone to help you by including the following information in a post for assistance with Firmware, Hardware etc on the forum.
      • Please be civil, we are trying to help!
      • Mention which versions of RepRapFirmware, Webserver (if applicable) and Duet Web Control you are using.
      • Mention which hardware you are using (e.g. Duet 3 Mainboard 6HC, Duet 3 Mini 5+ Wifi or Ethernet, Duet 3 Toolboard 1LC, Duet 2 WiFi, Smart Effector, Duex5 etc) and what architecture your printer has (Cartesian, CoreXY, Delta etc.). Also if it is an issue with a specific piece of hardware post in the relevant forum.
      • Provide links to your config.g (and other .g files like homeing, bed etc, if they are relavant to the issue). These files can be attached to the forum post using the "Upload File" button: Upload File icon or the text can be posted within code tags, using the "Code" button: Code icon
      • If it is a question about specific hardware other than Duet3D (e.g. a specific stepper motor) provide a link to the datasheet.
      • If it is an issue since you updated the firmware, please make sure you have read the "Changelog" for all the releases in between your old and new firmware versions.
      • Please have a search for other threads where people have had the same/similar issues. Do note however that RepRapFirmware gets updated frequently so if its an old thread treat with caution.
      • If possible describe exactly how to recreate the problem.
      • some times uploading a screen shot of the issue or a picture of how things are connected helps if that applies to your issue.
      • If you are getting an error message, include the exact error message in your post. Text can usually be copied from DWC and pasted into your reply.
      • Keep your issue contained to a single thread, that way all your information is in one place and it's easier to track.
      • When that issue is resolved, if you have another unrelated issue, start a new thread for it.
      • When your issue gets resolved mark it solved for others to find in the future.
      www.duet3d.com
      1 Reply Last reply Reply Quote 6
      • T3P3Tonyundefined
        Please only reply to this post with other constructive things forum users should do before asking for help.
        www.duet3d.com
        keyz182undefined 1 Reply Last reply Reply Quote 0
        • v0i9viperundefined
          v0i9viper
          If possible describe exactly how to recreate the problem. If they can see it happen a quick fix is much more likely.
            Also please state what architecture your printer has (Cartesian, CoreXY, Delta etc.) if it may be relevant.
              Sometimes a photo says 1000 words and doesn't require translation.
              • keyz182undefined
                keyz182 @T3P3Tony
                @t3p3tony said in Guide for posting requests for help:
                • Be civil
                deckingmanundefined 1 Reply Last reply Reply Quote 2
                • deckingmanundefined
                  deckingman @keyz182
                  @keyz182 said in Guide for posting requests for help:
                  • Be civil
                      Try and keep your issue contained to a single thread, that way all your information is in one place and it's easier to track. If your issue gets resolved mark it solved for others to find in the future.
                        dc42 administrators @Phaedrux
                        ...and when that issue is resolved, if you have another unrelated issue, start a new thread for it.
                        • droftartsundefined droftarts referenced this topic
                        • elmoretundefined elmoret referenced this topic
                        • Phaedruxundefined Phaedrux referenced this topic
                        • deckingmanundefined deckingman referenced this topic
                        • Rushmere3Dundefined Rushmere3D referenced this topic
                        • alankilianundefined alankilian referenced this topic
                        • jay_s_ukundefined jay_s_uk referenced this topic
                        • bricorundefined bricor referenced this topic
                        • engikeneerundefined engikeneer referenced this topic
                        • OwenDundefined OwenD referenced this topic
                        • T3P3Tonyundefined T3P3Tony referenced this topic
