    Dave's so proud
    47
    4.8k
    • sjason1377undefined
      sjason1377 Banned
      i did but thats what board is reporting
      fcwiltundefined Danalundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @sjason1377
        @sjason1377 said in Dave's so proud:
        So that tells you that the firmware did not get updated.
        Double check you are trying to upload the 2.01 version and try again.
          sjason1377 Banned
          RepRapFirmware for Duet 2 WiFi/Ethernet
          Firmware Electronics: Duet Ethernet 1.02 or later
          Firmware Version: 2.01(RTOS) (2018-07-26b2)
          Web Interface Version: 1.21.2-dc42
          ok guess what probe doesn't work still
            sjason1377 Banned
            M574 X1 Y1 S1 ; Set active low endstops
            M574 Z0
            M558 P9 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
            G31 P600 X0 Y12 Z.96; Set Z probe trigger value, offset and trigger height
            M557 X52:300 Y60:335 S40 ; Define mesh grid
            • deckingmanundefined
              deckingman
              This post is deleted!
              • Danalundefined
                Danal @sjason1377
                  sjason1377 Banned
                    sjason1377 Banned
                    M574 Z0
                    correct version and correct wording in config.g probe is unresponsive. a year of flawless performance under build 1.19.1 and now nothing.
                    fcwiltundefined 2 Replies Last reply Reply Quote 0
                    • Danalundefined
                      Danal
                      • fcwiltundefined
                        fcwilt @sjason1377
                        M574 Z0
                        The current docs for M558 report that the X, Y and Z parameters are obsolete.
                        Perhaps that is causing some sort of problem?
                          sjason1377 Banned
                          I would never had upgraded except for those false heater faults he said was a bug from the old version. Now he's got no support for this problem because he won't admit there is one. That my issue. It take many failures from many user before he responds. History proves I was not at fault before. I'm not now either.
                            sjason1377 Banned
                            I'm not proud I'm not saying I have any answers. I know my spelling sucks. But I'm no liar. We depend on him to help with these issue. But where does that leave us when he won't help.
                            • botundefined
                              bot
                              Do you expect David to drop everything in his real life to help one of the rudest users ever to come on these boards?
                              You need to learn to be patient, and/or how to resolve issues yourself.
                              *not actually a robot
                              • Danalundefined
                                Danal
                                Ooops... just read the whole thread from the top.
                                BYE.
                                You want support from the community, you need a whole different attitude.
                                • fcwiltundefined
                                  fcwilt @sjason1377
                                  M574 Z0
                                  Do you have a Z endstop in addition to the Z probe?
                                  In the M574 Z0 there is no S parameter - which indicates an active high endstop - is that correct?
                                    sjason1377 Banned
                                    yes that's correct. I went back to p7 and it works now
                                    fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      sjason1377 Banned @deckingman
                                      @deckingman eat my load!
                                      • fcwiltundefined
                                        fcwilt @sjason1377
                                        Did you try the latest version after removing the obsolete parameters from M558?
                                        And you do have a Z endstop in addtion to the Z probe?
                                          deckingman
                                          @sjason1377 Thanks for this chat message
                                          "hey decking eat my nut load bitch"
                                          Like I said, I'd like to help you but only a qualified psychiatrist could do that.
                                          • T3P3Tonyundefined
                                            T3P3Tony administrators
                                            Following an email where I asked sjason1377 to stop abusing/attacking people on the forum he continued with this behaviour so I have banned him.
                                            www.duet3d.com
                                            1 Reply Last reply Reply Quote 5
