    Prusa upgraded to duet, weird extrusion
    109
    5.8k
    • NitroFreakundefined
      NitroFreak
      thats because of the firmware minimum speed of 1.5mm/s iirc?
        droftarts administrators @NitroFreak
        @NitroFreak said in Prusa upgraded to duet, weird extrusion:
        It’s 0.5mm/s. from Gcode dictionary in G1 definition:
        For CNC users especially: RRF has a default minimum movement speed of 0.5mm/sec. In firmware 2.03 and later this can be changed using the I ('i') parameter of the M203 command.
          droftarts administrators @Murloc992
          @Murloc992 not sure when Back EMF kicks in? See https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Back_emf_due_to_rotation
          Murloc992undefined 1 Reply Last reply Reply Quote 0
          • Murloc992undefined
            Murloc992 @droftarts
            @droftarts said in Prusa upgraded to duet, weird extrusion:
            Not sure...
            Would toying around with CHOPCONF values help here?
            "Prusa Bear" : Full Bear frame, Bear X-Axis and Extruder. Duet 2 WiFi with RRF 3.2.2.
            • Vetiundefined
              Veti @Murloc992
              @Murloc992 said in Prusa upgraded to duet, weird extrusion:
              no but increasing voltage helps
                Murloc992 @Veti
                @Veti said in Prusa upgraded to duet, weird extrusion:
                I literally spent a ton of money on the upgrade.. Just thinking about spending even more on a 24V setup hurts me inside. 😞
                • Vetiundefined
                  Veti @Murloc992
                  @Murloc992
                  i dont think you are gonna reach any speed where the emf becomes a problem with the extruder.
                  Murloc992undefined NitroFreakundefined 2 Replies Last reply Reply Quote 0
                    Murloc992 @Veti
                    @Veti
                    Then what do you mean
                    Aren't you talking about the main PSU? Or Stepper voltage?
                      NitroFreak @Veti
                      @Murloc992
                      Thats really the only option left to test why the 0.9 steppers produce that pattern.
                      24v PSU are not that expensive. i got my meanwell‘s used on ebay for 24€
                        Murloc992 @NitroFreak
                        @Murloc992
                        Yeah, I mean for testing the stepper only. Because I am crap out of luck for other components. 😅
                          NitroFreak
                          24v heater cartridges are not that expensive and 24v silicone heated pads are also not that expensive. the 12v fans can be driven by the 24v duet by means of a buck converter
                            @Murloc992 As 1mm/s (I guess that’s X/Y federate?) seems to be the problem, and you’re unlikely to print at that speed normally, what happens if you print the box but set the speed multiplier to 200% or higher?
                              Thinking about it, what you might be seeing is the effect of running the extruder so slowly, you’re seeing individual steps, and the motor has to stop between each step, which causes a lack of continuity of movement, hence the stuttering. Try setting extruder to x256 microstepping, or turn off interpolation.
                                Murloc992
                                So I took some oscilloscope readings at same speeds, just different stepper currents (old one at 800mA, new one at 1200mA)
                                Old motor retracting at 30mm/s:
                                New motor retracting at 30mm/s:
                                (seems very noisy and sharp?)
                                Old motor retracting at 5mm/s:
                                New motor retracting at 5mm/s:
                                  @droftarts 1mm/s was my test extrusion rate, not printing. 🙂
                                    Nothing.
                                    I will try that in the morning. 😄
                                      Murloc992
                                      @T3P3Tony Maybe you looked at my oscilloscope phase readings? Does this depict shortage of driver voltage?
                                        @Murloc992 100th post! This is surprising. Sorry, we usually get these sorted a bit quicker. I don’t know much about oscilloscope readings, so can’t help there. But hopefully someone will! We'll get it sorted!
                                        Murloc992undefined 1 Reply Last reply Reply Quote 1
                                          @droftarts In fact, the faster I print, the less artifacts I get. 15mm/s perimeter speed was in the previous pictures. 30mm/s perimeters give me less artifacts, 45mm/s feels like they don't really exist, 60mm/s erases them completely.
                                          "Just don't print small things until you have 24V"? 😆
                                          • DocTruckerundefined
                                            DocTrucker @Murloc992
                                            @Murloc992 those are some conservative speeds. Seen a track width of 0.45 mentioned. Are you running a normal 0.4mm nozzle? Layer thickness? E3D V6 with 0.4mm nozzle passing PLA at 210-230C can do 100mm/sec at 0.25mm layers and 0.48 track width.
                                            Big thread, excuse me if those questions have been covered.
