Prusa upgraded to duet, weird extrusion
@Murloc992 not sure when Back EMF kicks in? See https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Back_emf_due_to_rotation
@droftarts said in Prusa upgraded to duet, weird extrusion:
Not sure...
Would toying around with CHOPCONF values help here?
@Murloc992 said in Prusa upgraded to duet, weird extrusion:
no but increasing voltage helps
@Veti said in Prusa upgraded to duet, weird extrusion:
I literally spent a ton of money on the upgrade.. Just thinking about spending even more on a 24V setup hurts me inside.
@Murloc992
i dont think you are gonna reach any speed where the emf becomes a problem with the extruder. -
Then what do you mean
Aren't you talking about the main PSU? Or Stepper voltage?
@Murloc992
i dont think you are gonna reach any speed where the emf becomes a problem with the extruder.Thats really the only option left to test why the 0.9 steppers produce that pattern.
24v PSU are not that expensive. i got my meanwell‘s used on ebay for 24€ -
@NitroFreak said in Prusa upgraded to duet, weird extrusion:
@Murloc992
24v PSU are not that expensive. i got my meanwell‘s used on ebay for 24€Yeah, I mean for testing the stepper only. Because I am crap out of luck for other components.
24v heater cartridges are not that expensive and 24v silicone heated pads are also not that expensive. the 12v fans can be driven by the 24v duet by means of a buck converter
@Murloc992 As 1mm/s (I guess that’s X/Y federate?) seems to be the problem, and you’re unlikely to print at that speed normally, what happens if you print the box but set the speed multiplier to 200% or higher?
Thinking about it, what you might be seeing is the effect of running the extruder so slowly, you’re seeing individual steps, and the motor has to stop between each step, which causes a lack of continuity of movement, hence the stuttering. Try setting extruder to x256 microstepping, or turn off interpolation.
@droftarts 1mm/s was my test extrusion rate, not printing.
Nothing.
I will try that in the morning.
@T3P3Tony Maybe you looked at my oscilloscope phase readings? Does this depict shortage of driver voltage?
@Murloc992 100th post! This is surprising. Sorry, we usually get these sorted a bit quicker. I don’t know much about oscilloscope readings, so can’t help there. But hopefully someone will! We'll get it sorted!
@droftarts In fact, the faster I print, the less artifacts I get. 15mm/s perimeter speed was in the previous pictures. 30mm/s perimeters give me less artifacts, 45mm/s feels like they don't really exist, 60mm/s erases them completely.
"Just don't print small things until you have 24V"?
@Murloc992 those are some conservative speeds. Seen a track width of 0.45 mentioned. Are you running a normal 0.4mm nozzle? Layer thickness? E3D V6 with 0.4mm nozzle passing PLA at 210-230C can do 100mm/sec at 0.25mm layers and 0.48 track width.
Big thread, excuse me if those questions have been covered.
@DocTrucker said in Prusa upgraded to duet, weird extrusion:
Usually I print at 60-100mm/s using PETG. My hotend is genuine E3DV6 with 0.45 extrusion width. Right now I am experimenting with 200% speed modifier applied to my profile. The printer is literally flying and I can't see anything wrong with the print right now. 27 minute print seems to be completed in just 16.
@Murloc992 what layer thickness are you using?
