CR-10S5 Firmware
Firmware installation
15
145
8.2k
    Gost101
    Here is the video link: Print Video
      Can you post your current config.g and a sample sliced gcode file?
        alansrobotlab @Gost101
        Hey @Gost101, I can't think of anything that would clog a volcano, but here are the things that I'd check (in case you haven't already)
        • kinked tube, obstruction in filament path
        • vastly oversized filament
        • burr or debris in the nozzle
        • insufficient stepper current or other mechanical cold end issue
        I was seeing an irregular print surface on one side, I pulled the nozzle off, used a propane torch to clean it out, and a 5/64" drill bit by hand to check the barrel for burrs and other obstructions.
          Gost101
          I have already switched over to the included nozzle and have had much better prints, and it doesn't clog. But it has a lot of stringing and prints very slow. Regardless of retraction distance and speed, plus z hop, I cannot stop stringing. It takes a normal bench on from cura at 15% infill with triangles internal support. I'm negating to mention the height and width, plus a couple of other factors because I forget what they were and my laptop is being repaired by razer. A couple of hours long print takes 12 hours to actually print.
            JamesM
            Looking at your config from your post, some of your values are rather low... This is what I have on my Ender 3 which should be similar for you. I think you need to up your speed, accel and jerk(instantaneous speed) on your extruder.
            M92 X80.00 Y80.00 Z400.00 E408.30 ; Set steps per mm
            M566 X500.00 Y500.00 Z30.00 E1500.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X10800.00 Y9000.00 Z300.00 E3000.00 ; Set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z500.00 E3000.00 ; Set accelerations (mm/s^2)
            M906 X950.00 Y950.00 Z850.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
              Gost101
              @JamesM said in CR-10S5 Firmware: It still prints very slow.
              In addition the nozzle will not retract in the helps of stopping blobs.
                Veti
                if you are using cura please post the start g code
                undefined 2 Replies Last reply 17 Jan 2020, 12:29 Reply Quote 0
                  Gost101 @Veti
                  @Veti Do you mean the config code?
                    Gost101 @Veti
                    @Veti I dont have any start code.
                    undefined 1 Reply Last reply 17 Jan 2020, 12:32 Reply Quote 0
                      Veti @Gost101
                      @Gost101
                      post the start of a g code where the print has been slow
                        Gost101
                        ;FLAVOR:RepRap
                        ;TIME:13024
                        ;Filament used: 5.97829m
                        ;Layer height: 0.12
                        ;MINX:209.345
                        ;MINY:227.132
                        ;MINZ:0.144
                        ;MAXX:279.794
                        ;MAXY:272.866
                        ;MAXZ:48.914
                        ;Generated with Cura_SteamEngine 4.4.1
                        T0
                        M190 S50
                        M104 S210
                        M109 S210
                        M82 ;absolute extrusion mode
                        M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                        M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                        M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                        M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                        M220 S100 ;Reset Feedrate
                        M221 S100 ;Reset Flowrate
                        G28 ;Home
                        G92 E0 ;Reset Extruder
                        G1 Z2.0 F3000 ;Move Z Axis up
                        G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                        G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                        G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                        G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                        M83 ;relative extrusion mode
                        ;LAYER_COUNT:400
                        ;LAYER:-6
                        undefined 1 Reply Last reply 17 Jan 2020, 19:52 Reply Quote 0
                          Gost101
                          Regardless of infill, wall thickness and layer height it prints extremely slow.
                            Veti
                            @Gost101 said in CR-10S5 Firmware:
                            those lines must be in the start g code of your slicer. thats why the print is slow.
                            remove them
                              Gost101
                              @Veti said in CR-10S5 Firmware:It seems to be moving faster but how do I compensate for the extrusion factor? Lines are becoming to small and separating multiple times in one movement.
                              undefined 1 Reply Last reply 17 Jan 2020, 13:47 Reply Quote 0
                                Veti @Gost101
                                is your thermistor set up correctly? are your e steps set up correctly?
                                  Gost101
                                  @Veti Yes they are, just got back to my benchy test print ive been gone for almost 6 hours and cura said that it was a 3 hour print. Turns out the printer is not fast still. What should do?
                                    Gost101
                                      Veti
                                      did you restart the printer after you made those changes? anytime you are printing an old file you will revert the settings and need to reboot.
                                      undefined 1 Reply Last reply 17 Jan 2020, 20:03 Reply Quote 0
                                      • PaulHewundefined
                                        PaulHew
                                        FYI I think the start code Veti is referring to is in your slicer.
                                        If it is Cura.
                                        Settings - Printers - manage printers
                                        Select your printer and click 'Machine Settings'
                                        On that page at the bottom there is a window with Start G-Code
                                        Remove the lines you have been asked to remove.
                                        HTH
                                        Paul.
                                          Phaedrux Moderator @Gost101
                                          Your screen shot shows the top speed as 8.4mm/s which is basically 500mm/min. So I think you still haven't removed the limiting start gcode from cura. Follow the directions that @PaulHew has given.
                                          Once that change is made it will only apply to newly sliced files. All your previously sliced files will have the slow limits set.
