    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.2k
    • Vetiundefined
      Veti
      if you are using cura please post the start g code
      Gost101undefined 2 Replies Last reply Reply Quote 0
      • Gost101undefined
        Gost101 @Veti
        @Veti Do you mean the config code?
        • Gost101undefined
          Gost101 @Veti
          @Veti I dont have any start code.
          • Vetiundefined
            Veti @Gost101
            @Gost101
            post the start of a g code where the print has been slow
            • Gost101undefined
              Gost101
              ;FLAVOR:RepRap
              ;TIME:13024
              ;Filament used: 5.97829m
              ;Layer height: 0.12
              ;MINX:209.345
              ;MINY:227.132
              ;MINZ:0.144
              ;MAXX:279.794
              ;MAXY:272.866
              ;MAXZ:48.914
              ;Generated with Cura_SteamEngine 4.4.1
              T0
              M190 S50
              M104 S210
              M109 S210
              M82 ;absolute extrusion mode
              M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
              M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
              M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
              M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
              M220 S100 ;Reset Feedrate
              M221 S100 ;Reset Flowrate
              G28 ;Home
              G92 E0 ;Reset Extruder
              G1 Z2.0 F3000 ;Move Z Axis up
              G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
              G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
              G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
              G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
              M83 ;relative extrusion mode
              ;LAYER_COUNT:400
              ;LAYER:-6
              • Gost101undefined
                Gost101
                Regardless of infill, wall thickness and layer height it prints extremely slow.
                • Vetiundefined
                  Veti
                  @Gost101 said in CR-10S5 Firmware:
                  those lines must be in the start g code of your slicer. thats why the print is slow.
                  remove them
                  • Gost101undefined
                    Gost101
                    @Veti said in CR-10S5 Firmware:It seems to be moving faster but how do I compensate for the extrusion factor? Lines are becoming to small and separating multiple times in one movement.
                    • Vetiundefined
                      Veti @Gost101
                      is your thermistor set up correctly? are your e steps set up correctly?
                      • Gost101undefined
                        Gost101
                        @Veti Yes they are, just got back to my benchy test print ive been gone for almost 6 hours and cura said that it was a 3 hour print. Turns out the printer is not fast still. What should do?
                        • Gost101undefined
                          Gost101
                          • Vetiundefined
                            Veti
                            did you restart the printer after you made those changes? anytime you are printing an old file you will revert the settings and need to reboot.
                            Gost101undefined 1 Reply Last reply Reply Quote 0
                            • PaulHewundefined
                              PaulHew
                              FYI I think the start code Veti is referring to is in your slicer.
                              If it is Cura.
                              Settings - Printers - manage printers
                              Select your printer and click 'Machine Settings'
                              On that page at the bottom there is a window with Start G-Code
                              Remove the lines you have been asked to remove.
                              HTH
                              Paul.
                                Phaedrux Moderator @Gost101
                                Your screen shot shows the top speed as 8.4mm/s which is basically 500mm/min. So I think you still haven't removed the limiting start gcode from cura. Follow the directions that @PaulHew has given.
                                Once that change is made it will only apply to newly sliced files. All your previously sliced files will have the slow limits set.
                                • Gost101undefined
                                  Gost101 @Veti
                                  @Veti I did reboot it. I did find that in cura and deleted it. lol
                                  • Gost101undefined
                                    Gost101
                                    @Phaedrux @PaulHew @Veti Great confusion this printer has caused me, yet more to learn I must. Sorry I have been watching to much star wars. lol.
                                    • Gost101undefined
                                      Gost101
                                      START
                                      G28 ;Home
                                      STOP
                                      G91 ;Relative positioning
                                      G1 E-2 F2700 ;Retract a bit
                                      G1 E-2 Z0.2 F2400 ;Retract and raise Z
                                      G1 X5 Y5 F3000 ;Wipe out
                                      G1 Z10 ;Raise Z more
                                      G90 ;Absolute positionning
                                      G1 X0 Y{machine_depth} ;Present print
                                      M106 S0 ;Turn-off fan
                                      M104 S0 ;Turn-off hotend
                                      M140 S0 ;Turn-off bed
                                      M84 X Y E ;Disable all steppers but Z
                                        And what speeds are set in cura for printing moves?
                                        • Gost101undefined
                                          Gost101
                                          @Phaedrux For this profile it is:PrintSpeedCapture.PNG
                                          • Gost101undefined
                                            Gost101
                                            @Phaedrux Regardless of any adjustments to this, it still takes a long time to print. Even after the changes made.
