    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.4k
    • Gost101undefined
      Gost101 @Veti
      @Veti Do you mean the config code?
      • Gost101undefined
        Gost101 @Veti
        @Veti I dont have any start code.
        • Vetiundefined
          Veti @Gost101
          @Gost101
          post the start of a g code where the print has been slow
          • Gost101undefined
            Gost101
            ;FLAVOR:RepRap
            ;TIME:13024
            ;Filament used: 5.97829m
            ;Layer height: 0.12
            ;MINX:209.345
            ;MINY:227.132
            ;MINZ:0.144
            ;MAXX:279.794
            ;MAXY:272.866
            ;MAXZ:48.914
            ;Generated with Cura_SteamEngine 4.4.1
            T0
            M190 S50
            M104 S210
            M109 S210
            M82 ;absolute extrusion mode
            M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
            M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
            M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
            M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
            M220 S100 ;Reset Feedrate
            M221 S100 ;Reset Flowrate
            G28 ;Home
            G92 E0 ;Reset Extruder
            G1 Z2.0 F3000 ;Move Z Axis up
            G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
            G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
            G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
            G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
            M83 ;relative extrusion mode
            ;LAYER_COUNT:400
            ;LAYER:-6
            • Gost101undefined
              Gost101
              Regardless of infill, wall thickness and layer height it prints extremely slow.
              • Vetiundefined
                Veti
                @Gost101 said in CR-10S5 Firmware:
                those lines must be in the start g code of your slicer. thats why the print is slow.
                remove them
                • Gost101undefined
                  Gost101
                  @Veti said in CR-10S5 Firmware:It seems to be moving faster but how do I compensate for the extrusion factor? Lines are becoming to small and separating multiple times in one movement.
                  • Vetiundefined
                    Veti @Gost101
                    is your thermistor set up correctly? are your e steps set up correctly?
                    • Gost101undefined
                      Gost101
                      @Veti Yes they are, just got back to my benchy test print ive been gone for almost 6 hours and cura said that it was a 3 hour print. Turns out the printer is not fast still. What should do?
                      • Gost101undefined
                        Gost101
                        • Vetiundefined
                          Veti
                          did you restart the printer after you made those changes? anytime you are printing an old file you will revert the settings and need to reboot.
                          Gost101undefined 1 Reply Last reply Reply Quote 0
                          • PaulHewundefined
                            PaulHew
                            FYI I think the start code Veti is referring to is in your slicer.
                            If it is Cura.
                            Settings - Printers - manage printers
                            Select your printer and click 'Machine Settings'
                            On that page at the bottom there is a window with Start G-Code
                            Remove the lines you have been asked to remove.
                            HTH
                            Paul.
                              Phaedrux Moderator @Gost101
                              Your screen shot shows the top speed as 8.4mm/s which is basically 500mm/min. So I think you still haven't removed the limiting start gcode from cura. Follow the directions that @PaulHew has given.
                              Once that change is made it will only apply to newly sliced files. All your previously sliced files will have the slow limits set.
                              • Gost101undefined
                                Gost101 @Veti
                                @Veti I did reboot it. I did find that in cura and deleted it. lol
                                • Gost101undefined
                                  Gost101
                                  @Phaedrux @PaulHew @Veti Great confusion this printer has caused me, yet more to learn I must. Sorry I have been watching to much star wars. lol.
                                  • Gost101undefined
                                    Gost101
                                    START
                                    G28 ;Home
                                    STOP
                                    G91 ;Relative positioning
                                    G1 E-2 F2700 ;Retract a bit
                                    G1 E-2 Z0.2 F2400 ;Retract and raise Z
                                    G1 X5 Y5 F3000 ;Wipe out
                                    G1 Z10 ;Raise Z more
                                    G90 ;Absolute positionning
                                    G1 X0 Y{machine_depth} ;Present print
                                    M106 S0 ;Turn-off fan
                                    M104 S0 ;Turn-off hotend
                                    M140 S0 ;Turn-off bed
                                    M84 X Y E ;Disable all steppers but Z
                                      And what speeds are set in cura for printing moves?
                                      • Gost101undefined
                                        Gost101
                                        @Phaedrux For this profile it is:PrintSpeedCapture.PNG
                                        • Gost101undefined
                                          Gost101
                                          @Phaedrux Regardless of any adjustments to this, it still takes a long time to print. Even after the changes made.
                                            Can you post a gcode file somewhere for us to see? And perhaps your current config.g file as it is right now?
