    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.4k
    • Gost101undefined
      Gost101
      I have already switched over to the included nozzle and have had much better prints, and it doesn't clog. But it has a lot of stringing and prints very slow. Regardless of retraction distance and speed, plus z hop, I cannot stop stringing. It takes a normal bench on from cura at 15% infill with triangles internal support. I'm negating to mention the height and width, plus a couple of other factors because I forget what they were and my laptop is being repaired by razer. A couple of hours long print takes 12 hours to actually print.
      • JamesMundefined
        JamesM
        Looking at your config from your post, some of your values are rather low... This is what I have on my Ender 3 which should be similar for you. I think you need to up your speed, accel and jerk(instantaneous speed) on your extruder.
        M92 X80.00 Y80.00 Z400.00 E408.30 ; Set steps per mm
        M566 X500.00 Y500.00 Z30.00 E1500.00 ; Set maximum instantaneous speed changes (mm/min)
        M203 X10800.00 Y9000.00 Z300.00 E3000.00 ; Set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z500.00 E3000.00 ; Set accelerations (mm/s^2)
        M906 X950.00 Y950.00 Z850.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        • Gost101undefined
          Gost101
          @JamesM said in CR-10S5 Firmware: It still prints very slow.
          In addition the nozzle will not retract in the helps of stopping blobs.
          • Vetiundefined
            Veti
            if you are using cura please post the start g code
            Gost101undefined 2 Replies Last reply Reply Quote 0
            • Gost101undefined
              Gost101 @Veti
              @Veti Do you mean the config code?
              • Gost101undefined
                Gost101 @Veti
                @Veti I dont have any start code.
                • Vetiundefined
                  Veti @Gost101
                  @Gost101
                  post the start of a g code where the print has been slow
                  • Gost101undefined
                    Gost101
                    ;FLAVOR:RepRap
                    ;TIME:13024
                    ;Filament used: 5.97829m
                    ;Layer height: 0.12
                    ;MINX:209.345
                    ;MINY:227.132
                    ;MINZ:0.144
                    ;MAXX:279.794
                    ;MAXY:272.866
                    ;MAXZ:48.914
                    ;Generated with Cura_SteamEngine 4.4.1
                    T0
                    M190 S50
                    M104 S210
                    M109 S210
                    M82 ;absolute extrusion mode
                    M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                    M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                    M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                    M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                    M220 S100 ;Reset Feedrate
                    M221 S100 ;Reset Flowrate
                    G28 ;Home
                    G92 E0 ;Reset Extruder
                    G1 Z2.0 F3000 ;Move Z Axis up
                    G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                    G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                    G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                    G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                    M83 ;relative extrusion mode
                    ;LAYER_COUNT:400
                    ;LAYER:-6
                    • Gost101undefined
                      Gost101
                      Regardless of infill, wall thickness and layer height it prints extremely slow.
                      • Vetiundefined
                        Veti
                        @Gost101 said in CR-10S5 Firmware:
                        those lines must be in the start g code of your slicer. thats why the print is slow.
                        remove them
                        • Gost101undefined
                          Gost101
                          @Veti said in CR-10S5 Firmware:It seems to be moving faster but how do I compensate for the extrusion factor? Lines are becoming to small and separating multiple times in one movement.
                          • Vetiundefined
                            Veti @Gost101
                            is your thermistor set up correctly? are your e steps set up correctly?
                            • Gost101undefined
                              Gost101
                              @Veti Yes they are, just got back to my benchy test print ive been gone for almost 6 hours and cura said that it was a 3 hour print. Turns out the printer is not fast still. What should do?
                              • Gost101undefined
                                Gost101
                                • Vetiundefined
                                  Veti
                                  did you restart the printer after you made those changes? anytime you are printing an old file you will revert the settings and need to reboot.
                                  Gost101undefined 1 Reply Last reply Reply Quote 0
                                  • PaulHewundefined
                                    PaulHew
                                    FYI I think the start code Veti is referring to is in your slicer.
                                    If it is Cura.
                                    Settings - Printers - manage printers
                                    Select your printer and click 'Machine Settings'
                                    On that page at the bottom there is a window with Start G-Code
                                    Remove the lines you have been asked to remove.
                                    HTH
                                    Paul.
                                      Phaedrux Moderator @Gost101
                                      Your screen shot shows the top speed as 8.4mm/s which is basically 500mm/min. So I think you still haven't removed the limiting start gcode from cura. Follow the directions that @PaulHew has given.
                                      Once that change is made it will only apply to newly sliced files. All your previously sliced files will have the slow limits set.
                                      • Gost101undefined
                                        Gost101 @Veti
                                        @Veti I did reboot it. I did find that in cura and deleted it. lol
                                        • Gost101undefined
                                          Gost101
                                          @Phaedrux @PaulHew @Veti Great confusion this printer has caused me, yet more to learn I must. Sorry I have been watching to much star wars. lol.
                                          • Gost101undefined
                                            Gost101
                                            START
                                            G28 ;Home
                                            STOP
                                            G91 ;Relative positioning
                                            G1 E-2 F2700 ;Retract a bit
                                            G1 E-2 Z0.2 F2400 ;Retract and raise Z
                                            G1 X5 Y5 F3000 ;Wipe out
                                            G1 Z10 ;Raise Z more
                                            G90 ;Absolute positionning
                                            G1 X0 Y{machine_depth} ;Present print
                                            M106 S0 ;Turn-off fan
                                            M104 S0 ;Turn-off hotend
                                            M140 S0 ;Turn-off bed
                                            M84 X Y E ;Disable all steppers but Z
