    Another Predator
    204
    14.7k
      droftarts administrators @Carlo
      @Carlo Sorry this has been such a frustrating experience for you. When you swapped the original board back in, did you also put the original effector back on, or did it use the smart effector? If you used the original effector (and presumably original probe), can you try that with the Duet? This would at least narrow down if it's the effector or the Duet.
      If you didn't swap back the effector, the only thing that I can think of is to try a 'manual' probe setup. Replace the probe type in config.g with type 0 (eg M558 P0 H5 F120 T6000), then run through a bed calibration and start a print. It should ask you to manually step the Z down at each probe point, until it touches the bed (use a thin piece of paper, babystep the Z down until it just grabs the paper under the nozzle). You may want to reduce the number of probe points!
      Then proceed to run a print in the normal way. If you home and do G30 to set Z height, it should ask you to manually do that, too.
      Carloundefined 1 Reply Last reply Reply Quote 0
        dc42 administrators @Carlo
        @Carlo said in Another Predator:
        This is the result I think everyone looks and thinks it's too far from the bed but it's not actually completing the print move it's changing direction before it should in the picture you can see where the print does a U turn on it's self so it never joins the print together it just doesn't complete the move almost like the radius is wrong like the circle is smaller than it is I'm watching it and it does not complete the circles or arcs it never makes it to the end it changes direction and doesn't go back to finish it.
        If you are still having this problem, can you post a video of it printing, to show what you mean?
        What filament are you using, what is the bed surface, and what bed temperature?
        • Carloundefined
          Carlo @droftarts
          @droftarts
          Hi Ian,
          Not your fault I appreciate all the help everyone has offered ...still hoping its my fault.
          I did do a manual probe as suggested didn't make any difference.
          @dc42 said in Another Predator:
          Hi dc
          If you are still having this problem, can you post a video of it printing, to show what you mean?Yes still having the same problem.
          What filament are you using, what is the bed surface, and what bed temperature?Ultrabase PLA 70c.
          I have shot a video just now but error can't upload due to being over permitted size.
          Cheers
          C
            Phaedrux Moderator @Carlo
            Would need to host it on something like dropbox or google drive or even youtube or vimeo.
            • Carloundefined
              Carlo @Phaedrux
              @Phaedrux
              No worries thanks
              Link below
              https://drive.google.com/open?id=1rd_xZ5KSlHqUiM8DExCabhpIQD18Y5gk
              Cheers
              C
                It doesn't look like you're doing a single G30 before the start of the print. I'm not really familiar with the delta calibration to know if that's still required or not.
                • Danalundefined
                  Danal
                  It is not absolutely required; however, a G32 with a bed.g that does 6 or 8 factor calibration is a best practice.
                  My bed.g
                  ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                  ; 16 points, 8 factors, probing radius: 280, probe offset (0, 0)
                  G28
                  M106 P1 S0
                  G30 P0 X0.00 Y280.00 Z-99999 H0
                  G30 P1 X140.00 Y242.49 Z-99999 H0
                  G30 P2 X242.49 Y140.00 Z-99999 H0
                  G30 P3 X280.00 Y0.00 Z-99999 H0
                  G30 P4 X242.49 Y-140.00 Z-99999 H0
                  G30 P5 X140.00 Y-242.49 Z-99999 H0
                  G30 P6 X0.00 Y-280.00 Z-99999 H0
                  G30 P7 X-140.00 Y-242.49 Z-99999 H0
                  G30 P8 X-242.49 Y-140.00 Z-99999 H0
                  G30 P9 X-280.00 Y-0.00 Z-99999 H0
                  G30 P10 X-242.49 Y140.00 Z-99999 H0
                  G30 P11 X-140.00 Y242.49 Z-99999 H0
                  G30 P12 X0.00 Y140.00 Z-99999 H0
                  G30 P13 X121.24 Y-70.00 Z-99999 H0
                  G30 P14 X-121.24 Y-70.00 Z-99999 H0
                  G30 P15 X0 Y0 Z-99999 S8
                  G29 S1
                  M106 P1 S1 I0 F500 H1 T40
                  The M106 turn the hot end fan off and back on. It shakes too much and false triggers the smart effector, if it runs during probing.
                  My start Gcode (in the slicer)
                  G28 ;Home
                  G32
                  G1 Z15.0 F6000 ;Move the platform down 15mm
                  ;Prime the extruder
                  G92 E0
                  G1 F200 E3
                  G92 E0
                  • boldnutsundefined
                    boldnuts
                    Based on the video it looks to me that your nozzle is still slightly to high and your printing your first layer to fast, your print moves also seem quite jerky. Have you lubricated the haydn magball ends as he recommends ? https://www.magballarms.com/
                    • Carloundefined
                      Carlo @boldnuts
                      Yes they are well lubricated with a similar dry product which is Teflon based, The trigger height during the video was/is currently
                      0.05.
                      I will add slicer settings later once it completes a layer out of interest what trigger height do you suggest ?...as I've tried a few in 0.01 increments
                      I don't seem to get any false triggers during travel when probing but i'll disconnect the fan during a probe and post again.
                      I did a G29 S2, G28 then G32 prior to the print.
                      My bed has G29 S2 added to it and is currently Factor 6 I've tried Factor 8 no benefit/visible effect.
                      ; 10 points, 6 factors, probing radius: 170, probe offset (0, 0)
                      G30 P0 X0.00 Y170.00 Z-99999 H0
                      G30 P1 X147.22 Y85.00 Z-99999 H0
                      G30 P2 X147.22 Y-85.00 Z-99999 H0
                      G30 P3 X0.00 Y-170.00 Z-99999 H0
                      G30 P4 X-147.22 Y-85.00 Z-99999 H0
                      G30 P5 X-147.22 Y85.00 Z-99999 H0
                      G30 P6 X0.00 Y85.00 Z-99999 H0
                      G30 P7 X73.61 Y-42.50 Z-99999 H0
                      G30 P8 X-73.61 Y-42.50 Z-99999 H0
                      G30 P9 X0 Y0 Z-99999 S6
                      G29 S2
                      I'll go and move the fan to another socket so I can control it add the M106 and try some more settings again.
                      So the height will make it complete the arcs which it doesn't at the moment.
                      So it's just 2 settings move the fan and find a new height .Oh and use the file sliced by another forum user cool...that second one may be a bit trickier now I'm thinking about it ! but hey once more in to the breach
                      As always big THANKS for the help it really is appreciated I know you don't have to help yet you do.
                      NexxCatundefined 1 Reply Last reply Reply Quote 0
                      • NexxCatundefined
                        NexxCat @Carlo
                        @Carlo
                        Try using this macro to configure your Z-probe offset. I wrote it and use it across multiple machines. Make sure to heat both the bed and nozzle. I use 60C on the bed and 130C on the nozzle:
                        ;calibrate_z_probe_offset.g
                        G31 P100 X0 Y0 Z0			; Reset Z trigger height to 0mm
                        M290 R0 S0				; Reset babystepping
                        G29 S2					; Clear bed mesh
                        G28					; Home the effector
                        G1 X0 Y0 Z20 F6000			; Move close to the bed
                        G30					; Probe to find a rough Z 0mm
                        G1 X0 Y0 Z1 F3000			; Move the nozzle to Z 1mm slowly
                        G92 Z3.0				; Set the Z height to 3mm, allowing moves below 0
                        M291 P"Lower the nozzle to until it grips a piece of paper. Click to continue." S2 Z1
                        G92 Z0					; Define this point as 0mm
                        G1 X0 Y0 Z20				; Move the probe to Z 20mm
                        G30 S-3					; Probe and set the trigger height
                        G1 Z20					; Raise Z to 20mm
                        It will report your trigger height back, which you can then put into config.g
                        Carloundefined bbergerundefined 3 Replies Last reply Reply Quote 0
                        • Carloundefined
                          Carlo @NexxCat
                          @NexxCat
                          Thanks I'll try that right now.
                          Really appreciated.
                          Thanks C
                          • Carloundefined
                            Carlo @NexxCat
                            @NexxCat
                            I ran the macro thanks for that results are:
                            1st
                            M98 P"0:/macros/Z probe report"
                            Z probe trigger height set to -0.084 mm
                            2nd
                            Z probe trigger height set to -0.146 mm
                            3rd
                            Z probe trigger height set to -0.159 mm
                            4th
                            5th
                            6th
                            So not sure what to set it to ... I know -0.159 I thought 3 out of 6 gotta be the one ....Its not the one.
                            Thanks for the help oops guys or Ladies really appreciated PC correction
                              I can't remember if this has been asked already, but has the bed been PID tuned?
                              • Carloundefined
                                Carlo @Phaedrux
                                @Phaedrux
                                Hiya,
                                Yeah both H0/H1 have and they are in the config.
                                I'm calling it now..... I'm done off to research a replacement.
                                Really appreciate all the help from everyone big THANK YOU!
                                • NexxCatundefined
                                  NexxCat @Carlo
                                  @Carlo
                                  Did you use a single sheet of paper when it asked, just regular printer paper? Alternatively, if you have some feeler gauges, you can use a 0.10mm gauge.
                                  Carloundefined 2 Replies Last reply Reply Quote 0
                                    @Carlo From my earlier post: When you swapped the original board back in, did you also put the original effector back on, or did it use the smart effector? If you used the original effector (and presumably original probe), can you try that with the Duet? This would at least narrow down if it's the effector or the Duet.
                                    • Carloundefined
                                      Carlo @NexxCat
                                      @NexxCat
                                      Hi NexxCat
                                      I used the back off a sticker which is 0.1mm on my calipers.
                                      Just found my gauges !
                                      Thanks
                                      • Carloundefined
                                        Carlo @NexxCat
                                        @NexxCat
                                        So I used the well 0.102 feeler gauge though it is .10 with my calipers and 3 times got 3 heights.
                                        I did video the whole process but that won't help me
                                        The numbers don't actually help because they are not accurate though one of them is:
                                        I don't think it's the effector because it does what it is supposed to do and no matter what trigger height I put in G31 line its the same outcome and the effector does return the same probe heights all be it not one after the other 🙂
                                        maybe the drivers are not calculating correctly I don't know but it is what it is and that is not usable.
                                        Cheers for your help.
                                        C
                                        • NexxCatundefined
                                          NexxCat @Carlo
                                          @Carlo
                                          Ok, last thing I can think of, just to double check if the actual positioning is being repeatable. Run these commands one at a time, or save it as a macro:
                                          ; Disable any baby-stepping and the bed mesh
                                          M290 R0 S0
                                          G29 S2
                                          ; Home the effector
                                          G28
                                          ; Heat bed to 60C & nozzle to 130C
                                          M104 S130 T0
                                          M190 S60 T0
                                          M109 S130 T0
                                          ; Run delta calibration
                                          G32
                                          ; Move the effector to 0,0,Max height
                                          G1 X0 Y0 F4500
                                          G1 Z500 F4500
                                          ; Move the effector back to 10mm off the bed
                                          G1 Z10 F4500
                                          ; Slowly move down to 0.1mm
                                          G1 Z0.1 F600
                                          When the macro is finished, the nozzle is at 0.1 on the Z axis. Use the paper or a 0.1mm feeler gauge and see if the nozzle truly is at 0.1mm
                                          Carloundefined 2 Replies Last reply Reply Quote 1
                                          • Carloundefined
                                            Carlo @droftarts
                                            @droftarts
                                            Hi Ian,
                                            I used the original effector with the mag arms (printed the adapters) whats funny is I didn't even try to get anything level or square I literally slapped it together set the offset 1 level and it just worked.
                                            I have the effector still wired I can carefully attach it to the Duet2 and try it i cant fit the effector to the other board it's locked down
                                            but I've written this thing off now I don't expect this to ever work with duet but after spending all this time I do want to know whats wrong maybe it will help someone else some day...probably not
                                            I post a video of it once its fitted
                                            Thanks
                                            C
