    Another Predator
    204
    14.7k
    • Carloundefined
      Carlo @Phaedrux
      @Phaedrux
      No worries thanks
      Link below
      https://drive.google.com/open?id=1rd_xZ5KSlHqUiM8DExCabhpIQD18Y5gk
      Cheers
      C
        It doesn't look like you're doing a single G30 before the start of the print. I'm not really familiar with the delta calibration to know if that's still required or not.
        • Danalundefined
          Danal
          It is not absolutely required; however, a G32 with a bed.g that does 6 or 8 factor calibration is a best practice.
          My bed.g
          ; bed.g file for RepRapFirmware, generated by Escher3D calculator
          ; 16 points, 8 factors, probing radius: 280, probe offset (0, 0)
          G28
          M106 P1 S0
          G30 P0 X0.00 Y280.00 Z-99999 H0
          G30 P1 X140.00 Y242.49 Z-99999 H0
          G30 P2 X242.49 Y140.00 Z-99999 H0
          G30 P3 X280.00 Y0.00 Z-99999 H0
          G30 P4 X242.49 Y-140.00 Z-99999 H0
          G30 P5 X140.00 Y-242.49 Z-99999 H0
          G30 P6 X0.00 Y-280.00 Z-99999 H0
          G30 P7 X-140.00 Y-242.49 Z-99999 H0
          G30 P8 X-242.49 Y-140.00 Z-99999 H0
          G30 P9 X-280.00 Y-0.00 Z-99999 H0
          G30 P10 X-242.49 Y140.00 Z-99999 H0
          G30 P11 X-140.00 Y242.49 Z-99999 H0
          G30 P12 X0.00 Y140.00 Z-99999 H0
          G30 P13 X121.24 Y-70.00 Z-99999 H0
          G30 P14 X-121.24 Y-70.00 Z-99999 H0
          G30 P15 X0 Y0 Z-99999 S8
          G29 S1
          M106 P1 S1 I0 F500 H1 T40
          The M106 turn the hot end fan off and back on. It shakes too much and false triggers the smart effector, if it runs during probing.
          My start Gcode (in the slicer)
          G28 ;Home
          G32
          G1 Z15.0 F6000 ;Move the platform down 15mm
          ;Prime the extruder
          G92 E0
          G1 F200 E3
          G92 E0
          • boldnutsundefined
            boldnuts
            Based on the video it looks to me that your nozzle is still slightly to high and your printing your first layer to fast, your print moves also seem quite jerky. Have you lubricated the haydn magball ends as he recommends ? https://www.magballarms.com/
            Carloundefined 1 Reply Last reply Reply Quote 0
            • Carloundefined
              Carlo @boldnuts
              Yes they are well lubricated with a similar dry product which is Teflon based, The trigger height during the video was/is currently
              0.05.
              I will add slicer settings later once it completes a layer out of interest what trigger height do you suggest ?...as I've tried a few in 0.01 increments
              I don't seem to get any false triggers during travel when probing but i'll disconnect the fan during a probe and post again.
              I did a G29 S2, G28 then G32 prior to the print.
              My bed has G29 S2 added to it and is currently Factor 6 I've tried Factor 8 no benefit/visible effect.
              ; 10 points, 6 factors, probing radius: 170, probe offset (0, 0)
              G30 P0 X0.00 Y170.00 Z-99999 H0
              G30 P1 X147.22 Y85.00 Z-99999 H0
              G30 P2 X147.22 Y-85.00 Z-99999 H0
              G30 P3 X0.00 Y-170.00 Z-99999 H0
              G30 P4 X-147.22 Y-85.00 Z-99999 H0
              G30 P5 X-147.22 Y85.00 Z-99999 H0
              G30 P6 X0.00 Y85.00 Z-99999 H0
              G30 P7 X73.61 Y-42.50 Z-99999 H0
              G30 P8 X-73.61 Y-42.50 Z-99999 H0
              G30 P9 X0 Y0 Z-99999 S6
              G29 S2
              I'll go and move the fan to another socket so I can control it add the M106 and try some more settings again.
              So the height will make it complete the arcs which it doesn't at the moment.
              So it's just 2 settings move the fan and find a new height .Oh and use the file sliced by another forum user cool...that second one may be a bit trickier now I'm thinking about it ! but hey once more in to the breach
              As always big THANKS for the help it really is appreciated I know you don't have to help yet you do.
              NexxCatundefined 1 Reply Last reply Reply Quote 0
              • NexxCatundefined
                NexxCat @Carlo
                @Carlo
                Try using this macro to configure your Z-probe offset. I wrote it and use it across multiple machines. Make sure to heat both the bed and nozzle. I use 60C on the bed and 130C on the nozzle:
                ;calibrate_z_probe_offset.g
                G31 P100 X0 Y0 Z0			; Reset Z trigger height to 0mm
                M290 R0 S0				; Reset babystepping
                G29 S2					; Clear bed mesh
                G28					; Home the effector
                G1 X0 Y0 Z20 F6000			; Move close to the bed
                G30					; Probe to find a rough Z 0mm
                G1 X0 Y0 Z1 F3000			; Move the nozzle to Z 1mm slowly
                G92 Z3.0				; Set the Z height to 3mm, allowing moves below 0
                M291 P"Lower the nozzle to until it grips a piece of paper. Click to continue." S2 Z1
                G92 Z0					; Define this point as 0mm
                G1 X0 Y0 Z20				; Move the probe to Z 20mm
                G30 S-3					; Probe and set the trigger height
                G1 Z20					; Raise Z to 20mm
                It will report your trigger height back, which you can then put into config.g
                Carloundefined bbergerundefined 3 Replies Last reply Reply Quote 0
                • Carloundefined
                  Carlo @NexxCat
                  @NexxCat
                  Thanks I'll try that right now.
                  Really appreciated.
                  Thanks C
                  • Carloundefined
                    Carlo @NexxCat
                    @NexxCat
                    I ran the macro thanks for that results are:
                    1st
                    M98 P"0:/macros/Z probe report"
                    Z probe trigger height set to -0.084 mm
                    2nd
                    Z probe trigger height set to -0.146 mm
                    3rd
                    Z probe trigger height set to -0.159 mm
                    4th
                    5th
                    6th
                    So not sure what to set it to ... I know -0.159 I thought 3 out of 6 gotta be the one ....Its not the one.
                    Thanks for the help oops guys or Ladies really appreciated PC correction
                      I can't remember if this has been asked already, but has the bed been PID tuned?
                      • Carloundefined
                        Carlo @Phaedrux
                        @Phaedrux
                        Hiya,
                        Yeah both H0/H1 have and they are in the config.
                        I'm calling it now..... I'm done off to research a replacement.
                        Really appreciate all the help from everyone big THANK YOU!
                        • NexxCatundefined
                          NexxCat @Carlo
                          @Carlo
                          Did you use a single sheet of paper when it asked, just regular printer paper? Alternatively, if you have some feeler gauges, you can use a 0.10mm gauge.
                          Carloundefined 2 Replies Last reply Reply Quote 0
                            droftarts administrators @Carlo
                            @Carlo From my earlier post: When you swapped the original board back in, did you also put the original effector back on, or did it use the smart effector? If you used the original effector (and presumably original probe), can you try that with the Duet? This would at least narrow down if it's the effector or the Duet.
                            • Carloundefined
                              Carlo @NexxCat
                              @NexxCat
                              Hi NexxCat
                              I used the back off a sticker which is 0.1mm on my calipers.
                              Just found my gauges !
                              Thanks
                              • Carloundefined
                                Carlo @NexxCat
                                @NexxCat
                                So I used the well 0.102 feeler gauge though it is .10 with my calipers and 3 times got 3 heights.
                                I did video the whole process but that won't help me
                                The numbers don't actually help because they are not accurate though one of them is:
                                I don't think it's the effector because it does what it is supposed to do and no matter what trigger height I put in G31 line its the same outcome and the effector does return the same probe heights all be it not one after the other 🙂
                                maybe the drivers are not calculating correctly I don't know but it is what it is and that is not usable.
                                Cheers for your help.
                                C
                                • NexxCatundefined
                                  NexxCat @Carlo
                                  @Carlo
                                  Ok, last thing I can think of, just to double check if the actual positioning is being repeatable. Run these commands one at a time, or save it as a macro:
                                  ; Disable any baby-stepping and the bed mesh
                                  M290 R0 S0
                                  G29 S2
                                  ; Home the effector
                                  G28
                                  ; Heat bed to 60C & nozzle to 130C
                                  M104 S130 T0
                                  M190 S60 T0
                                  M109 S130 T0
                                  ; Run delta calibration
                                  G32
                                  ; Move the effector to 0,0,Max height
                                  G1 X0 Y0 F4500
                                  G1 Z500 F4500
                                  ; Move the effector back to 10mm off the bed
                                  G1 Z10 F4500
                                  ; Slowly move down to 0.1mm
                                  G1 Z0.1 F600
                                  When the macro is finished, the nozzle is at 0.1 on the Z axis. Use the paper or a 0.1mm feeler gauge and see if the nozzle truly is at 0.1mm
                                  Carloundefined 2 Replies Last reply Reply Quote 1
                                  • Carloundefined
                                    Carlo @droftarts
                                    @droftarts
                                    Hi Ian,
                                    I used the original effector with the mag arms (printed the adapters) whats funny is I didn't even try to get anything level or square I literally slapped it together set the offset 1 level and it just worked.
                                    I have the effector still wired I can carefully attach it to the Duet2 and try it i cant fit the effector to the other board it's locked down
                                    but I've written this thing off now I don't expect this to ever work with duet but after spending all this time I do want to know whats wrong maybe it will help someone else some day...probably not
                                    I post a video of it once its fitted
                                    Thanks
                                    C
                                    • Carloundefined
                                      Carlo @NexxCat
                                      @NexxCat
                                      I'll do that now.
                                      Cheers
                                      C
                                      • Carloundefined
                                        Carlo @NexxCat
                                        @NexxCat
                                        Hi NexxCat,
                                        No its 0.1mm to high
                                        • NexxCatundefined
                                          NexxCat @Carlo
                                          @Carlo
                                          What is your current Z probe offset?
                                          • Carloundefined
                                            Carlo @NexxCat
                                            @NexxCat
                                            G31 P100 X0 Y0 Z-0.159
