    Another Predator
    204
    14.7k
    • Carloundefined
      Carlo @boldnuts
      Yes they are well lubricated with a similar dry product which is Teflon based, The trigger height during the video was/is currently
      0.05.
      I will add slicer settings later once it completes a layer out of interest what trigger height do you suggest ?...as I've tried a few in 0.01 increments
      I don't seem to get any false triggers during travel when probing but i'll disconnect the fan during a probe and post again.
      I did a G29 S2, G28 then G32 prior to the print.
      My bed has G29 S2 added to it and is currently Factor 6 I've tried Factor 8 no benefit/visible effect.
      ; bed.g file for RepRapFirmware, generated by Escher3D calculator
      ; 10 points, 6 factors, probing radius: 170, probe offset (0, 0)
      G30 P0 X0.00 Y170.00 Z-99999 H0
      G30 P1 X147.22 Y85.00 Z-99999 H0
      G30 P2 X147.22 Y-85.00 Z-99999 H0
      G30 P3 X0.00 Y-170.00 Z-99999 H0
      G30 P4 X-147.22 Y-85.00 Z-99999 H0
      G30 P5 X-147.22 Y85.00 Z-99999 H0
      G30 P6 X0.00 Y85.00 Z-99999 H0
      G30 P7 X73.61 Y-42.50 Z-99999 H0
      G30 P8 X-73.61 Y-42.50 Z-99999 H0
      G30 P9 X0 Y0 Z-99999 S6
      G29 S2
      I'll go and move the fan to another socket so I can control it add the M106 and try some more settings again.
      So the height will make it complete the arcs which it doesn't at the moment.
      So it's just 2 settings move the fan and find a new height .Oh and use the file sliced by another forum user cool...that second one may be a bit trickier now I'm thinking about it ! but hey once more in to the breach
      As always big THANKS for the help it really is appreciated I know you don't have to help yet you do.
      NexxCatundefined 1 Reply Last reply Reply Quote 0
      • NexxCatundefined
        NexxCat @Carlo
        @Carlo
        Try using this macro to configure your Z-probe offset. I wrote it and use it across multiple machines. Make sure to heat both the bed and nozzle. I use 60C on the bed and 130C on the nozzle:
        ;calibrate_z_probe_offset.g
        G31 P100 X0 Y0 Z0			; Reset Z trigger height to 0mm
        M290 R0 S0				; Reset babystepping
        G29 S2					; Clear bed mesh
        G28					; Home the effector
        G1 X0 Y0 Z20 F6000			; Move close to the bed
        G30					; Probe to find a rough Z 0mm
        G1 X0 Y0 Z1 F3000			; Move the nozzle to Z 1mm slowly
        G92 Z3.0				; Set the Z height to 3mm, allowing moves below 0
        M291 P"Lower the nozzle to until it grips a piece of paper. Click to continue." S2 Z1
        G92 Z0					; Define this point as 0mm
        G1 X0 Y0 Z20				; Move the probe to Z 20mm
        G30 S-3					; Probe and set the trigger height
        G1 Z20					; Raise Z to 20mm
        It will report your trigger height back, which you can then put into config.g
        Carloundefined bbergerundefined 3 Replies Last reply Reply Quote 0
        • Carloundefined
          Carlo @NexxCat
          @NexxCat
          Thanks I'll try that right now.
          Really appreciated.
          Thanks C
          • Carloundefined
            Carlo @NexxCat
            @NexxCat
            I ran the macro thanks for that results are:
            1st
            M98 P"0:/macros/Z probe report"
            Z probe trigger height set to -0.084 mm
            2nd
            Z probe trigger height set to -0.146 mm
            3rd
            Z probe trigger height set to -0.159 mm
            4th
            5th
            6th
            So not sure what to set it to ... I know -0.159 I thought 3 out of 6 gotta be the one ....Its not the one.
            Thanks for the help oops guys or Ladies really appreciated PC correction
              I can't remember if this has been asked already, but has the bed been PID tuned?
              Carloundefined 1 Reply Last reply Reply Quote 0
              • Carloundefined
                Carlo @Phaedrux
                @Phaedrux
                Hiya,
                Yeah both H0/H1 have and they are in the config.
                I'm calling it now..... I'm done off to research a replacement.
                Really appreciate all the help from everyone big THANK YOU!
                • NexxCatundefined
                  NexxCat @Carlo
                  @Carlo
                  Did you use a single sheet of paper when it asked, just regular printer paper? Alternatively, if you have some feeler gauges, you can use a 0.10mm gauge.
                  Carloundefined 2 Replies Last reply Reply Quote 0
                    droftarts administrators @Carlo
                    @Carlo From my earlier post: When you swapped the original board back in, did you also put the original effector back on, or did it use the smart effector? If you used the original effector (and presumably original probe), can you try that with the Duet? This would at least narrow down if it's the effector or the Duet.
                    • Carloundefined
                      Carlo @NexxCat
                      @NexxCat
                      Hi NexxCat
                      I used the back off a sticker which is 0.1mm on my calipers.
                      Just found my gauges !
                      Thanks
                      • Carloundefined
                        Carlo @NexxCat
                        @NexxCat
                        So I used the well 0.102 feeler gauge though it is .10 with my calipers and 3 times got 3 heights.
                        I did video the whole process but that won't help me
                        The numbers don't actually help because they are not accurate though one of them is:
                        I don't think it's the effector because it does what it is supposed to do and no matter what trigger height I put in G31 line its the same outcome and the effector does return the same probe heights all be it not one after the other 🙂
                        maybe the drivers are not calculating correctly I don't know but it is what it is and that is not usable.
                        Cheers for your help.
                        C
                        • NexxCatundefined
                          NexxCat @Carlo
                          @Carlo
                          Ok, last thing I can think of, just to double check if the actual positioning is being repeatable. Run these commands one at a time, or save it as a macro:
                          ; Disable any baby-stepping and the bed mesh
                          M290 R0 S0
                          G29 S2
                          ; Home the effector
                          G28
                          ; Heat bed to 60C & nozzle to 130C
                          M104 S130 T0
                          M190 S60 T0
                          M109 S130 T0
                          ; Run delta calibration
                          G32
                          ; Move the effector to 0,0,Max height
                          G1 X0 Y0 F4500
                          G1 Z500 F4500
                          ; Move the effector back to 10mm off the bed
                          G1 Z10 F4500
                          ; Slowly move down to 0.1mm
                          G1 Z0.1 F600
                          When the macro is finished, the nozzle is at 0.1 on the Z axis. Use the paper or a 0.1mm feeler gauge and see if the nozzle truly is at 0.1mm
                          Carloundefined 2 Replies Last reply Reply Quote 1
                          • Carloundefined
                            Carlo @droftarts
                            @droftarts
                            Hi Ian,
                            I used the original effector with the mag arms (printed the adapters) whats funny is I didn't even try to get anything level or square I literally slapped it together set the offset 1 level and it just worked.
                            I have the effector still wired I can carefully attach it to the Duet2 and try it i cant fit the effector to the other board it's locked down
                            but I've written this thing off now I don't expect this to ever work with duet but after spending all this time I do want to know whats wrong maybe it will help someone else some day...probably not
                            I post a video of it once its fitted
                            Thanks
                            C
                            • Carloundefined
                              Carlo @NexxCat
                              @NexxCat
                              I'll do that now.
                              Cheers
                              C
                              • Carloundefined
                                Carlo @NexxCat
                                @NexxCat
                                Hi NexxCat,
                                No its 0.1mm to high
                                • NexxCatundefined
                                  NexxCat @Carlo
                                  @Carlo
                                  What is your current Z probe offset?
                                  • Carloundefined
                                    Carlo @NexxCat
                                    @NexxCat
                                    G31 P100 X0 Y0 Z-0.159
                                    • NexxCatundefined
                                      NexxCat @Carlo
                                      @Carlo
                                      I can't remember offhand which way to adjust the offset to bring it closer, but try both of these, one will certainly be too high, but the other, does that give you a 0.1mm gap when running the macro I posted?
                                      G31 P100 X0 Y0 Z-0.059
                                      G31 P100 X0 Y0 Z-0.259
                                      Carloundefined 1 Reply Last reply Reply Quote 1
                                      • Carloundefined
                                        Carlo @NexxCat
                                        @NexxCat
                                        They have all been tried
                                        it's 0.05 to bring it closer dc42 suggested 0.05 so I've tried all the -0. possible infact the video I posted is -0.05
                                        • NexxCatundefined
                                          NexxCat @Carlo
                                          @Carlo
                                          I know you've tried them whilst printing, but try -0.059 and run the macro. Is the gap 0.1mm?
                                          • Carloundefined
                                            Carlo @NexxCat
                                            @NexxCat
                                            Doing it now
                                            Bang on
