    For anyone still using endstop switches...
    66
    6.8k
    • zaptaundefined
      zapta @A Former User
      @bearer, let's say that the lever is perfect and the core switch has repeatability error X, doesn't that error multiplied by leverage ratio of the lever?
        A Former User @zapta
        @zapta hm, maybe I read the chart up there wrong, but seemed omrom with lever was less accurate and crouzet was more accurate - as such I assumed it had more to do with the quality of the lever than the lever itself. (could be wrong ofc)
        • arhiundefined
          arhi
          1. lever must be stiff, normally on these switches lever is springy intentionally as accuracy is not really important
          2. you want to probe with SHORT end of the lever, normally these switches probe with long end of the lever, again, accuracy is not important for normal use and long lever reduce force required to press the spring
          so what you need to do is reverse it, use stiff lever and use a lever that's short on the probe side and long on the trigger side, this way you increase force required to press the lever (not a problem on our gear) and increase precision
          • mrehorstdmdundefined
            mrehorstdmd
            Before I made the differential screw/optical endstop for the Z axis, I used a lever and cam to bump a microswitch. The lever position effectively reduced movement of the adjuster screw by about 1:8 and gave me approximately 100 um/turn of the screw similar to the differential screw. The difference is that the cam was not linear or very predictable, where the differential screw is.
            You can see the adjuster on the far right side of this picture:
            One reason I wanted to switch to an optical endstop was that the printed plastic lever/cam eventually got damaged by bumping the switch too hard.
            It would probably still be OK if it were made of metal, or it might have broken the switch mount. Putting limit switches in direct opposition to the motion is generally a bad idea.
            • zaptaundefined
              zapta @mrehorstdmd
              For resume after power outage I wonder is a completely different approach would work.
              1. When detecting power outage printer move itself to closest full step.
              2. Printer writes its position to a non volatile memory.
              3. On resume from power outage, printer energizes steppers at a full step and read the last stepper location from non volatile memory.
              4. (optional) Printer sanity check the resumed location by homing using a non accurate switch/sensor.
              5. Printer is now accurately resumed without using an accurate sensor.
              • Danalundefined
                Danal
                Only if the printer doesn't move when the motors are de-energized. Some don't. Many do.
                • fcwiltundefined
                  fcwilt
                  I have both a optical Z axis end stop sensor and a BLTouch.
                  I use the end stop sensor to do a high speed homing to within 5mm (appx) of the bed.
                  Later I set Z=0 using the BLTouch.
                  • 3DPMicroundefined
                    3DPMicro
                    i use these proximity sensors https://www.ia.omron.com/product/item/1017/ on my micro mill and one of my printers. Havent checked the printer but the mill repeats within .003-.006mm. Far more accurate than a printer needs but better is good. Aside from being very repeatable I like the small, 3mm diameter sensor and the remote amp with LED indicator. They do have other models with a larger, threaded sensor. Cheap too. Never paid more than $15 for one and recently bought 5 for $40 with free shipping. All new.
                    Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
                    • fcwiltundefined
                      fcwilt @3DPMicro
                      @3DPMicro said in For anyone still using endstop switches...:
                      Cheap too. Never paid more than $15 for one...
                      Where are you seeing those prices?
                      I did a few quick checks with my normal suppliers and am seeing prices in the $130-$160 range.
                      3DPMicroundefined 1 Reply Last reply Reply Quote 0
                      • 3DPMicroundefined
                        3DPMicro @fcwilt
                        @fcwilt ebay. You may have to wait for the right deal but it will come.
                        Edit #2- Don't know about posting (US) eBay links here so I won't but I just checked and the seller I bought from is still selling them for $8.01 each. New.
                          Phaedrux Moderator @3DPMicro
                          Go for it. It's in context.
                          • JoergS5undefined
                            JoergS5
                            I'm thinking about building one myself like a 3d probe, but the long rod 90 degree angled like:
                            This should be very precise.
                            • 3DPMicroundefined
                              3DPMicro @Phaedrux
                              https://www.ebay.com/itm/1Pcs-New-Omron-Proximity-Switch-E2EC-CR5C1-E2ECCR5C1-rg/263671185856?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                              • fcwiltundefined
                                fcwilt @3DPMicro
                                @3DPMicro
                                Have you seen any of the units that are normally closed for sale?
                                  mrehorstdmd @JoergS5
                                  @JoergS5 What is that?
                                  • JoergS5undefined
                                    JoergS5 @mrehorstdmd
                                    @mrehorstdmd Something like https://www.youtube.com/watch?v=prb60JoxQSQ but as endstop. The three red pairs (often steel balls) are electrically connected with the shaft, a small movement lifts the shaft, disconnecting. I find it interesting because it doesn't bend anything at contact, should be repeatable.
                                    • 3DPMicroundefined
                                      3DPMicro @fcwilt
                                      @fcwilt I have not. Might look on Omrons site, see if they offer one and then check eBay.
                                      • AJ Quickundefined
                                        AJ Quick
                                        Have any similar tests been done on the Prusa i3 MK3 with the layer shift detection and homing, without using any limit switches?
                                        (I'm in favor of limit switches, but think it is pretty cool if it works without them!)
                                        • imrjundefined
                                          imrj
                                          wouldnt optical anything be a problem given we usually dont have printers in a super clean area? I mean mine isnt dirty, but sure not dust free....
                                          my home water treatment system used an optical sensor for something (forgot what it was) but it used to go out like once every 6 months....it uses something else now.....
                                          • laelundefined
                                            lael
                                            @mrehorstdmd - I'm looking at your optical end stop video where you test and show the repeatability. Very impressive! Are you taking the Z axis to home, and then dropping down 5mm or so? Is that your homing routine, or just for the video?
