    Duet 3 Mini 5+ : Initial announcement
    288
    32.2k
    • piperswundefined
      pipersw @dc42
      @dc42 There is a big difference of speed between wifi and ethernet speed ?
        dc42 administrators @pipersw
        @pipersw said in Duet 3 Mini 5+ : Initial announcement:
        No, the Ethernet is currently only about 20% faster than the WiFi, although there is more scope for improvement with Ethernet.
        • Traveler0612undefined
          Traveler0612
          I already have a Duet 2 Wifi. I would love to test this on my Delta, and Folgertech FT-5, that is likely going to be converted to corexy.
          • jallen810undefined
            jallen810
            This looks awesome! I am especially interested in being able to use my 24v PS and then use 12v fans as they're so much easier to get ahold of!
            Was the rumor I heard that Duet3 Mini will have both Ethernet and WiFi, true as well?
              dc42 administrators @jallen810
              There will be separate Ethernet and WiFi versions.
              • Vetiundefined
                Veti
                this is a very nice evolution.
                any news on when it will be available?
                  T3P3Tony administrators @Veti
                  @Veti I expect we will have some availability for normal purchase in November.
                  We have to iterate on the prototype and then conduct more CE and FCC testing before we put it on general sale.
                  cabal2000undefined 1 Reply Last reply Reply Quote 1
                  • DIY-O-Sphereundefined
                    DIY-O-Sphere
                    @T3P3Tony said in Duet 3 Mini 5+ : Initial announcement:
                    We are excited to officially announce a new Duet Mainboard:
                    The Duet 3 Mini 5+ is an evolution of the Duet 2 Maestro
                    Have you also plans to bring Duet2 WiFI/Ethernet to the next level?
                    For the next project I need 9 -12 steppers....
                    As a user of a Maestro the Duet 3 Mini 5+ would fulfill all my requirements...except the count of steppers...
                    Are there any options to get 9 steppers working ???
                    (UTC+1)
                    dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                      dc42 administrators @DIY-O-Sphere
                      @DIY-O-Sphere said in Duet 3 Mini 5+ : Initial announcement:
                      The Duet 3 Mini is intended to fit in the medium price and performance segment, so the microcontroller doesn't have enough I/O pins for 9 drivers. However, we're looking at adding CAN bus expansion to the Mini 5+, which would allow tool boards etc. to be connected.
                        T3P3Tony administrators @DIY-O-Sphere
                        @DIY-O-Sphere also, you can use 12 steppers on the Duet 2!
                        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                          DIY-O-Sphere @T3P3Tony
                          @T3P3Tony
                          I know...that was an option I was thinking about.
                          I will build the machine in autum. If I'm able to realise a working tool lock mechanism driven by a servo, the Mini 5+ is still an option.
                          Locking at the IO Pin table it should be possible to drive additional servos.
                          (UTC+1)
                            @DIY-O-Sphere you can drive small hobby servos from the IO conenctors
                            • cabal2000undefined
                              cabal2000 @T3P3Tony
                              @T3P3Tony Fantastic!!! Will the new board be available for pre-order same as Maestro?
                              • piperswundefined
                                pipersw
                                Have you some thermal picture like for duet3d ?
                                  I am pleased to report that the first prototypes of the Duet 3 Mini 5+ are working well. However, we've made a few changes to the specification for the second prototype boards, mainly to improve versatility, but with an eye to controlling cost too.
                                  We have reduced the stepper driver support from 5+3 to 5+2. This has allowed us to eliminate 3 chips and to improve the speed and efficiency of stall detection. We think that few users buying a mid-priced board would need 8 stepper drivers.
                                  We've also reduced the number of general purpose I/O connectors from 6 to 5. There are still an additional 2 input-only connectors; so each stepper driver can have an associated endstop switch, Z probe or filament monitor.
                                  The biggest change we've made is to add CAN bus support. This places the new board firmly in the Duet 3 family, and it will allow the Mini 5+ to communicate with existing and forthcoming Duet 3 expansion boards. Expansion will be limited compared to the Duet 3 MB6HC because of the less powerful processor and reduced amount of RAM - in particular, the maximum supported number of CAN-connected stepper drivers will be
                                  reduced - but (for example) it will be possible to connect several Duet 3 tool boards to a Mini 5+.
                                  cabal2000undefined pixelpieperundefined DIY-O-Sphereundefined littlehobbyshopundefined 4 Replies Last reply Reply Quote 2
                                    cabal2000 @dc42
                                    @dc42 Sounds great!! Any news on beta testing?
                                    • pixelpieperundefined
                                      pixelpieper @dc42
                                      @dc42 I would have had a use for 8 steppers, but hey, if I can get it working through tool boards that’s fine for me as well, I think I actually prefer that. Will the expansion in that case be pin compatible with the maestro two stepper expansion?
                                      Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                                      Voron V0.250 / Duet 2 Maestro
                                        dc42 administrators @pixelpieper
                                        @pixelpieper said in Duet 3 Mini 5+ : Initial announcement:
                                        It's not pin-compatible. One reason is the the Maestro expansion board had no stall detection outputs
                                        pixelpieperundefined 1 Reply Last reply Reply Quote 1
                                        • peter247undefined
                                          peter247
                                          So what is the advantages over the duet wifi 2 ?
                                          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                                            pixelpieper @dc42
                                            @dc42 fair enough, makes sense! Thanks for the update and super quick response. Really excited for this new iteration!
