    Duet 3 Mini 5+ : Initial announcement
    288
    31.0k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @T3P3Tony
      @T3P3Tony
      I know...that was an option I was thinking about.
      I will build the machine in autum. If I'm able to realise a working tool lock mechanism driven by a servo, the Mini 5+ is still an option.
      Locking at the IO Pin table it should be possible to drive additional servos.
      (UTC+1)
        T3P3Tony administrators @DIY-O-Sphere
        @DIY-O-Sphere you can drive small hobby servos from the IO conenctors
        • cabal2000undefined
          cabal2000 @T3P3Tony
          @T3P3Tony Fantastic!!! Will the new board be available for pre-order same as Maestro?
          • piperswundefined
            pipersw
            Have you some thermal picture like for duet3d ?
              I am pleased to report that the first prototypes of the Duet 3 Mini 5+ are working well. However, we've made a few changes to the specification for the second prototype boards, mainly to improve versatility, but with an eye to controlling cost too.
              We have reduced the stepper driver support from 5+3 to 5+2. This has allowed us to eliminate 3 chips and to improve the speed and efficiency of stall detection. We think that few users buying a mid-priced board would need 8 stepper drivers.
              We've also reduced the number of general purpose I/O connectors from 6 to 5. There are still an additional 2 input-only connectors; so each stepper driver can have an associated endstop switch, Z probe or filament monitor.
              The biggest change we've made is to add CAN bus support. This places the new board firmly in the Duet 3 family, and it will allow the Mini 5+ to communicate with existing and forthcoming Duet 3 expansion boards. Expansion will be limited compared to the Duet 3 MB6HC because of the less powerful processor and reduced amount of RAM - in particular, the maximum supported number of CAN-connected stepper drivers will be
              reduced - but (for example) it will be possible to connect several Duet 3 tool boards to a Mini 5+.
              cabal2000undefined pixelpieperundefined DIY-O-Sphereundefined littlehobbyshopundefined 4 Replies Last reply Reply Quote 2
                cabal2000 @dc42
                @dc42 Sounds great!! Any news on beta testing?
                • pixelpieperundefined
                  pixelpieper @dc42
                  @dc42 I would have had a use for 8 steppers, but hey, if I can get it working through tool boards that’s fine for me as well, I think I actually prefer that. Will the expansion in that case be pin compatible with the maestro two stepper expansion?
                  Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                  Voron V0.250 / Duet 2 Maestro
                    dc42 administrators @pixelpieper
                    @pixelpieper said in Duet 3 Mini 5+ : Initial announcement:
                    It's not pin-compatible. One reason is the the Maestro expansion board had no stall detection outputs
                    pixelpieperundefined 1 Reply Last reply Reply Quote 1
                    • peter247undefined
                      peter247
                      So what is the advantages over the duet wifi 2 ?
                      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                        pixelpieper @dc42
                        @dc42 fair enough, makes sense! Thanks for the update and super quick response. Really excited for this new iteration!
                          dc42 administrators @peter247
                          @peter247 said in Duet 3 Mini 5+ : Initial announcement:
                          • More modern stepper drivers, supporting stealthChop and interpolation to x256 from any input microstepping
                          • Lower cost expansion if you just need 1 or 2 more stepper drivers
                          • Interface for Raspberry Pi or other single-board computer
                          • Double the flash memory and RAM, facilitating more firmware expansion in the future
                          • Expansion via CAN
                          • Support for mini-12864 displays as well as PanelDue
                          • Barrier strip VIN and bed connectors instead of terminal blocks
                          • Supports 4 fans instead of 3, two of them optionally with tachos
                          • Lower cost (we hope!)
                          Disadvantages compared to Duet WiFi:
                          • Not expandable to more than 7 drivers, 3 heaters and 4 fans without using the CAN bus
                          • Not compatible with more than two external stepper drivers, except via CAN
                          • Lower maximum motor current
                          • Fan cooling required at lower motor currents than for Duet 2
                          • Only one 2-channel temperature daughter board supported instead of two
                          peter247undefined 1 Reply Last reply Reply Quote 1
                          • antlestxpundefined
                            antlestxp
                            is it strange that I am eagerly looking forward to replace my perfectly functional maestro?
                            cabal2000undefined 1 Reply Last reply Reply Quote 1
                            • peter247undefined
                              peter247 @dc42
                              @dc42 said in Duet 3 Mini 5+ : Initial announcement:
                              Expansion via CAN
                              Expansion is more limited, it does not support the CAN-FD bus
                              Can you use the CAN tool board on it ?.
                                it supports CAN-FD so yes it will support our Duet 3 tool boards
                                peter247undefined 1 Reply Last reply Reply Quote 0
                                  cabal2000 @antlestxp
                                  @antlestxp Nope, I am with you brother!! can't wait.
                                  • peter247undefined
                                    peter247 @T3P3Tony
                                    @T3P3Tony
                                    The biggest change we've made is to add CAN bus support , now that as become useful .
                                    • wescundefined
                                      wesc
                                      Deal killer for me. Oh well. I was excited for this board. It was going to be the recommended board for CroXY.
                                      CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
                                      Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • Vetiundefined
                                        Veti @wesc
                                        @wesc
                                        with the addition of the canbus, you can add extension board with additional steppers like this
                                        https://www.duet3d.com/Duet3Expansion3HC
                                          DIY-O-Sphere @dc42
                                          Perfect!
                                          That gives many new options for adaption. Even upgrading the main board to a 6HC, as one can leve the CAN based expansion boards untouched...or reuse them.
                                          That makes it also easyer for beginners...
                                          Start with a Mini++ and expand the hardware step by step to the level of experience...
                                          The appetite comes while eating....
                                          (UTC+1)
                                            dc42 administrators @wesc
                                            @wesc said in Duet 3 Mini 5+ : Initial announcement:
                                            How were you using 8 motors? Dual X, dual Y, triple Z and one extruder perhaps? If so then you could put a Tool Board on the print carriage, which would provide the 8th stepper driver and greatly reduce the number of wires going to the print carriage.
