    hbot homes correctly but prints mirrored ,
    8.8k
      Doing up a diagram like this can be very helpful in getting the offsets all straight. Piece of grid paper works well if you're not a paint wiz.
      There's also some useful info here:
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
      https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
      This page will also be useful for getting the hang of RRF3:
      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
      And of course the Gcode wiki that will tell you how each gcode works:
      https://duet3d.dozuki.com/Wiki/Gcode#main
      • peter247undefined
        peter247 @tracar
        @tracar
        Which heater pin are you using ?.
        Mine is heater 7 , so this should help you .
        ; Z-Probe config.g
        M558 P9 C"^zprobe.in" H2 F100 T8000 A5		; set Z probe type to bltouch and the dive height + speeds
        M950 S0 C"exp.heater7"							; create servo pin 0 for BLTouch
        G31 P500 X-45 Y-6 Z2.98                        	; set Z probe trigger value, offset and trigger height
        M557 X55:295 Y55:295 S80                     	; define mesh grid .. 30 , 60 , 80
        Lines 5 and 6 set to your own offsets and mesh grid
        This works with any heater
        ; deployprobe.g
        ; called to deploy a physical Z probe
        M280 P0 S10 ; deploy BLTouch
        ; retractprobe.g
        ; called to retract a physical Z probe
        M280 P0 S90 ; retract BLTouch
        • tracarundefined
          tracar
          yes H7_pwm on the end of the expansion board
          can not get a response from the bltouch
          ; Self-Test
          M280 P0 S120 ; Send PWM channel 7 the S10 (angle) command, inverted signal
            Phaedrux Moderator @tracar
            @tracar said in hbot homes correctly but prints mirrored ,:
            And that's using this in your config,g?
            If that's what you have in config, and it's wired to the right pin, check the wiring continuity.
            • tracarundefined
              tracar
              this is the current config
              M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
              M557 X50:400 Y50:500 S50 ; define mesh grid
              and
              ; deployprobe.g
              M280 P7 S10 ; deploy BLTouch
              does not work
              continuity of wiring is fine
              peter247undefined 1 Reply Last reply Reply Quote 0
              • peter247undefined
                peter247 @tracar
                @tracar
                BIG HINT ,This works with any heater
                ; deployprobe.g
                ; retractprobe.g
                • tracarundefined
                  tracar
                  i have already changed the p0 and still non responsive
                  • peter247undefined
                    peter247 @tracar
                    @tracar , what pin are you using .
                    • tracarundefined
                      tracar
                      H7_pwm on the expansion board
                      and zprobe in
                      • peter247undefined
                        peter247 @tracar
                        @tracar Pin 31 ?
                        tracarundefined 1 Reply Last reply Reply Quote 0
                        • tracarundefined
                          tracar @peter247
                          @peter247 yes
                          peter247undefined 3 Replies Last reply Reply Quote 0
                          • peter247undefined
                            peter247 @tracar
                            This post is deleted!
                            • peter247undefined
                              peter247 @tracar
                              • peter247undefined
                                peter247 @tracar
                                @tracar
                                I can't see anything wrong with the set ups .
                                if you had a Maestro that needs to be set up differently , but you are running a duet 2 wifi , so that doesn't wash .
                                Can only think it's wiring ?
                                • tracarundefined
                                  tracar
                                  it works if i downgrade firmware
                                  • peter247undefined
                                    peter247 @tracar
                                    @tracar
                                    what is your full zprobe config
                                    have you removed the M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                    • tracarundefined
                                      tracar @peter247
                                      @peter247
                                      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
                                      M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
                                      • peter247undefined
                                        peter247 @tracar
                                        @tracar
                                        comment out M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                        Notes - RepRapFirmware 3
                                        The F parameter is no longer supported. Use M950 to set the frequency in the M950 command that you use to define the heater .
                                        The I2 parameter is no longer supported, and I3 does the same as I1. You can use M950 to invert the output.
                                        You can no longer disable a heater using M307 A-1 C-1 D-1. To use the pin for something else, don't create a heater on that pin.
                                        • tracarundefined
                                          tracar
                                          wiring is all good, as i said it works if i downgrade the firmware,
                                          something in the settings..............
                                            Can you put up your full config.g?
                                            peter247undefined tracarundefined 2 Replies Last reply Reply Quote 0
