    hbot homes correctly but prints mirrored ,
    8.1k
    • peter247undefined
      peter247 @tracar
      @tracar
      Which heater pin are you using ?.
      Mine is heater 7 , so this should help you .
      ; Z-Probe config.g
      M558 P9 C"^zprobe.in" H2 F100 T8000 A5		; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"exp.heater7"							; create servo pin 0 for BLTouch
      G31 P500 X-45 Y-6 Z2.98                        	; set Z probe trigger value, offset and trigger height
      M557 X55:295 Y55:295 S80                     	; define mesh grid .. 30 , 60 , 80
      Lines 5 and 6 set to your own offsets and mesh grid
      This works with any heater
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
      • tracarundefined
        tracar
        yes H7_pwm on the end of the expansion board
        can not get a response from the bltouch
        ; Self-Test
        M280 P0 S120 ; Send PWM channel 7 the S10 (angle) command, inverted signal
          Phaedrux Moderator @tracar
          @tracar said in hbot homes correctly but prints mirrored ,:
          And that's using this in your config,g?
          If that's what you have in config, and it's wired to the right pin, check the wiring continuity.
          • tracarundefined
            tracar
            this is the current config
            M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
            M557 X50:400 Y50:500 S50 ; define mesh grid
            and
            ; deployprobe.g
            M280 P7 S10 ; deploy BLTouch
            does not work
            continuity of wiring is fine
            peter247undefined 1 Reply Last reply Reply Quote 0
            • peter247undefined
              peter247 @tracar
              @tracar
              BIG HINT ,This works with any heater
              ; deployprobe.g
              ; retractprobe.g
              • tracarundefined
                tracar
                i have already changed the p0 and still non responsive
                • peter247undefined
                  peter247 @tracar
                  @tracar , what pin are you using .
                  • tracarundefined
                    tracar
                    H7_pwm on the expansion board
                    and zprobe in
                    • peter247undefined
                      peter247 @tracar
                      @tracar Pin 31 ?
                      tracarundefined 1 Reply Last reply Reply Quote 0
                      • tracarundefined
                        tracar @peter247
                        @peter247 yes
                        peter247undefined 3 Replies Last reply Reply Quote 0
                        • peter247undefined
                          peter247 @tracar
                          This post is deleted!
                          • peter247undefined
                            peter247 @tracar
                            • peter247undefined
                              peter247 @tracar
                              @tracar
                              I can't see anything wrong with the set ups .
                              if you had a Maestro that needs to be set up differently , but you are running a duet 2 wifi , so that doesn't wash .
                              Can only think it's wiring ?
                              • tracarundefined
                                tracar
                                it works if i downgrade firmware
                                • peter247undefined
                                  peter247 @tracar
                                  @tracar
                                  what is your full zprobe config
                                  have you removed the M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                  • tracarundefined
                                    tracar @peter247
                                    @peter247
                                    M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                    G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
                                    M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
                                    • peter247undefined
                                      peter247 @tracar
                                      @tracar
                                      comment out M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                      Notes - RepRapFirmware 3
                                      The F parameter is no longer supported. Use M950 to set the frequency in the M950 command that you use to define the heater .
                                      The I2 parameter is no longer supported, and I3 does the same as I1. You can use M950 to invert the output.
                                      You can no longer disable a heater using M307 A-1 C-1 D-1. To use the pin for something else, don't create a heater on that pin.
                                      • tracarundefined
                                        tracar
                                        wiring is all good, as i said it works if i downgrade the firmware,
                                        something in the settings..............
                                          Can you put up your full config.g?
                                          peter247undefined tracarundefined 2 Replies Last reply Reply Quote 0
                                          • peter247undefined
                                            peter247 @Phaedrux
