hbot homes correctly but prints mirrored ,
yes H7_pwm on the end of the expansion board
can not get a response from the bltouch
; Self-Test
M280 P0 S120 ; Send PWM channel 7 the S10 (angle) command, inverted signal -
@tracar said in hbot homes correctly but prints mirrored ,:
And that's using this in your config,g?
M558 P9 C"^zprobe.in" H2 F100 T8000 A5 ; set Z probe type to bltouch and the dive height + speeds
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouchIf that's what you have in config, and it's wired to the right pin, check the wiring continuity.
this is the current config
M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
M557 X50:400 Y50:500 S50 ; define mesh gridand
; deployprobe.g
; called to deploy a physical Z probe
M280 P7 S10 ; deploy BLTouch
does not workcontinuity of wiring is fine
BIG HINT ,This works with any heater
; deployprobe.g ; called to deploy a physical Z probe ; M280 P0 S10 ; deploy BLTouch ; retractprobe.g ; called to retract a physical Z probe ; M280 P0 S90 ; retract BLTouch -
i have already changed the p0 and still non responsive
@tracar , what pin are you using .
H7_pwm on the expansion board
and zprobe in -
@tracar Pin 31 ?
@peter247 yes
This post is deleted! -
I can't see anything wrong with the set ups .
if you had a Maestro that needs to be set up differently , but you are running a duet 2 wifi , so that doesn't wash .
Can only think it's wiring ?
it works if i downgrade firmware
what is your full zprobe config
have you removed the M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points -
comment out M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
Notes - RepRapFirmware 3
The F parameter is no longer supported. Use M950 to set the frequency in the M950 command that you use to define the heater .
The I2 parameter is no longer supported, and I3 does the same as I1. You can use M950 to invert the output.
You can no longer disable a heater using M307 A-1 C-1 D-1. To use the pin for something else, don't create a heater on that pin.
wiring is all good, as i said it works if i downgrade the firmware,
something in the settings.............. -
Can you put up your full config.g?
have you commented out M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
