    hbot homes correctly but prints mirrored ,
    8.8k
    • tracarundefined
      tracar
      wiring is all good, as i said it works if i downgrade the firmware,
      something in the settings..............
      peter247undefined 1 Reply Last reply Reply Quote 0
        Can you put up your full config.g?
        peter247undefined tracarundefined 2 Replies Last reply Reply Quote 0
        • peter247undefined
          peter247 @Phaedrux
          This post is deleted!
          • peter247undefined
            peter247 @tracar
            @tracar
            have you commented out M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
              Phaedrux Moderator @peter247
              @peter247 said in hbot homes correctly but prints mirrored ,:
              M307 H7 A-1 C-1 D-1
              Will just be ignored in RRF3.
              If you send M98 P"config.g" do you get any errors echoed back?
              tracarundefined 1 Reply Last reply Reply Quote 0
              • tracarundefined
                tracar @Phaedrux
                @Phaedrux
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 25 2020 08:01:23 GMT-0600 (Mountain Daylight Time)
                G31 X0 Y0 Z0 P25
                M550 P"Duet2" ; set printer name
                M669 K1 ; select CoreXY mode
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P5 S0 T5 R1 ; physical drive y goes forwards
                M569 P6 S1 T5 R1 ; physical drive x goes forwards
                M569 P7 S1 T5 R1 ; physical drive z goes forwards
                M569 P8 S1 T5 R1 ; physical drive z2 goes forwards
                M569 P3 S1 ; physical drive extruder goes forwards
                M584 X6 Y5 Z7:8 E3 ; set drive mapping
                M92 X200.00 Y200.00 Z200.00 E138.23 ; set steps per mm
                M203 X25000.00 Y25000.00 Z2500.00 E2400.00 ; set maximum speeds (mm/min)
                M906 X300 Y300 Z300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X440 Y535 Z900 S0 ; set axis maxima
                M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
                M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
                M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
                ;M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
                M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
                • tracarundefined
                  tracar @Phaedrux
                  @Phaedrux said in hbot homes correctly but prints mirrored ,:
                  M98 P"config.g"
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                    Phaedrux Moderator @tracar
                    Try enabling the pullup resistor on the servo pin with the ^ before the pin name.
                    M950 S0 C"^exp.heater7" ; create servo pin 0 for BLTouch with pullup
                    • tracarundefined
                      tracar @Phaedrux
                      @Phaedrux
                      nada.
                        Try M950 S0 C"exp.31" ; create servo pin 0 for BLTouch
                        • tracarundefined
                          tracar @Phaedrux
                          @Phaedrux
                          no change
                          • peter247undefined
                            peter247 @tracar
                            @tracar
                            how are you testing that it is working ?
                            tracarundefined 1 Reply Last reply Reply Quote 1
                            • tracarundefined
                              tracar @peter247
                              @peter247
                              make the changes to config file, save ,reset board send command M280 P0 S10
                              peter247undefined 1 Reply Last reply Reply Quote 1
                                Does it do a self test on bootup?
                                • tracarundefined
                                  tracar @Phaedrux
                                  @Phaedrux
                                  yes
                                  • tracarundefined
                                    tracar @tracar
                                    @tracar so annoying lol:
                                    Error
                                    As a new user, you can only post once every 60 second(s) until you have earned 1 reputation - please
                                    • peter247undefined
                                      peter247 @tracar
                                      @tracar
                                      How is the probe when you send it extended or retracted ?
                                      • tracarundefined
                                        tracar @peter247
                                        @peter247
                                        does nothing
                                        • peter247undefined
                                          peter247 @tracar
                                          @tracar
                                          Sorry , I was not clear what I was asking .
                                          When you set M280 P0 S10 , was the probe extended or retracted ?
                                          • tracarundefined
                                            tracar @peter247
                                            @peter247
                                            afyer it does the initial test upon powering up, the pin is always up,
                                            pin up or pin down commands do no change, it remains up
