Error when setting up independent motor bed levelling on CoreXY
1.4k
    equanimity8
    Hi all,
    I'm working on a CoreXY that uses piezo to home and bed level. The setup consists of three motors in total but since I ran out of drivers I want to connect two motors to the Z driver and one to the E1 driver, effectively performing bed leveling using two independent motors.
    I followed the documentation and read previous threads on the topic but I'm getting an error even though the setup seems logical to me, thus I think I'm skipping a step somewhere and that's what's throwing me off.
    Both when I try to AutoHome and run G32 I get the error
    g32
    Error: G0/G1: insufficient axes homed
    My config.g is:
    ;Independent motors leveling
    M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
    M671 X105:105 Y0:150 S1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    M574 X1 Y1 Z0 S0
    ;M558 P1 I1 R0.4 F300 X0 Y0 Z0
    M558 P8 H10 I1 R1 F600 X0 Y0 Z1
    G31 X0 Y0 Z-0.25 P600
    my bed.g is:
    G28 ; home
    G30 P0 X105 Y0 Z-99999 ; probe near a leadscrew, half way along Y axis
    G30 P1 X105 Y150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
    and my homeall.g is:
    ;Home X and Y
    G91 ; relative positioning
    G1 Z5 F420 S2 ; Lower bed 5mm to ensure it is below the switch trigger height
    M913 X100 Y100 ; set X Y motors to 50% of their normal current for homing
    G1 S1 X-375 Y-305 F600 ; course home X or Y
    G1 S1 X-375 F600 ; course home X
    G1 S1 Y-305 F600 ; course home Y
    G1 X5 Y5 F600 ; move away from the endstops
    G1 S1 X-10 F200 ; fine home X
    G1 S1 Y-10 F200 ; fine home Y
    G1 X5 Y5 F600 ; go to origin
    M913 X100 Y100 ; set X Y motors to 100% of their normal current
    ;Home Z
    G90 ; absolute positioning
    G1 X30 Y30 F600 ; go to first probe point
    G1 Z5 F420 ; lift Z relative to current position
    ;Load height map
    G29 S1
    Best!
    undefined 1 Reply Last reply 11 Oct 2020, 18:01 Reply Quote 0
      mrehorstdmd
      @equanimity8 How can you move the bed in Z and tram it in 3 dimensions with only two independent adjustments?
      When the two Z driver connected motors get out of sync, and they will, how will they be driven back into sync?
      If the homing routine drove the bed to the bottom of the printer and a little beyond so that the the physical endstops are hit, and the endstops are positioned so that when they are hit the bed is trammed, at least along whichever axis the two Z drive connected motors are aligned with, you could then bring the bed back to the home position and run the auto tramming that would finish tramming. But, if you're going to do that, why not just set all three endstops at the bottom of the Z axis so that the bed is completely trammed and do away with the auto tramming entirely? Every time the printer powers up, run the bed down to the end of the Z axis and then bring it back up to home.
      Or belt the three Z axis screws to one motor. They'll never get out of sync and the bed will never tilt. You won't have to run it to the bottom of the Z axis every time you power up.
        equanimity8
        I don't kid myself that proper tramming is possible with my setup and I don't aim for it. In any case, I realise that this approach is more of a clutch than a solution. Admittedly, I have no previous experience with such setups but I was hoping that the two motors wired to the same driver wouldn't get out of sync.
        I don't have any physical endstops on Z, so far I have only used the piezo for finding zero.
        I didn't mention it because I thought it was irrelevant but each motor drives a belt rather than a leadscrew. Previously, I did have a triple leadscrew setup connected to a single motor but I couldn't get rid of some artifacts due to them not being perfectly straight thus I decided to give belts a go.
        undefined 1 Reply Last reply 11 Oct 2020, 15:15 Reply Quote 0
          mrehorstdmd @equanimity8
          @equanimity8 So you know it can't work the way you're trying to do it. Why continue trying to do it that way?
          If the construction of the printer is reasonably solid, and there is a good leveling system, you won't need autotramming at all. I use two belts to lift the bed in my corexy machine framed with 4040 t-slot. The bed sits on three screws arranged as a kinematic mount. I frequently transport the printer in my car or in a truck and when I get where I'm going, I power up the machine and start printing without any adjustments. It never goes out of tram. The mount is so solid I can remove the bed from the machine and put it back without retramming. The two belts that lift the bed are driven by a single motor with a long shaft and two pulleys.
          Of course, you do need to tram the bed for the first time. For that I use the manual bed leveling assistant and a piece of paper. The process takes all of 2 minutes, even if you're extra careful.
          My printer has an optical Z=0 endstop with a fine adjusting differential screw. There are no bed sensors on the extruder carriage, so no wiring going to them. Even the X endstop is mounted on the printer's frame so I don't need wires for it running to the extruder carriage. I wrote the homex.g file so that it homes Y first, then X and it has worked with perfect reliability for a couple years.
            equanimity8
            @mrehorstdmd Thanks for your thoughts. I'm familiar with your work and I value your opinion. The reason I'm trying to go with it in this way is that I wanted to experiment with belts instead of leadscrews on Z - I have certain parts on my hands and I'm trying to validate my premise using them, that's not meant to be a long-term solution.
            I'm still vexed by this error though, thus I welcome suggestions.
              sebkritikel @equanimity8
              @equanimity8 said in Error when setting up independent motor bed levelling on CoreXY:
              Hi all,
              g32
              My config.g is:
              M574 X1 Y1 Z0 S0
              my bed.g is:
              G28 ; home
              ;Home X and Y
              ;Home Z
              ;Load height map
              G29 S1
              Best!
              A small step, but can you place M400 directly before any M913 commands? I do see that you have both set to XC100 and Y100, perhaps while trouble shooting.
              https://forum.duet3d.com/topic/15952/release-3-01-rc10/62?_=1602439079914
              Could you also try using "home all" with G29 S1 commented out as a test?
              Also, which firmware version are you running?
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
                equanimity8
                @sebkritikel Thanks for your suggestions! I have fixed the mistake you found in row 4 of homeall.g it and it has made no difference (it was working correctly like that before) - it's not something I have changed while trying to make the conversion happen. The way homeall.g looks is the exact way I used it before, I have made changes to only to bed.g and config.g but I added homeall.g too for completeness' sake. Further, I tried to execute homeall.g with and without M400 before M913 as well as with G29 S1 commented out and not and there is no change in behaviour.
                Other than that I run RRF 2.05.1. Not sure how I missed to mention that (facepalm).
                  It's tilt correction with 2 motors rather than actual leveling, but that's fine.
                  Can you post your full config.g and the results of M122 and M98 P"config.g"?
                  Definitely have M400 before M913
                  I don't see anything in your bed.g that would cause that insufficient axes homed error on 2.05.
                  What do you mean by autohome?
                    equanimity8
                    @Phaedrux I concur, tilt correction is a more accurate term.
                    The console output when I run M122 and M98 P"config.g" in succession:
                    10/12/2020, 8:00:19 AM M98 P"config.g"
                    10/12/2020, 8:00:07 AM M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                    Board ID: 08DDM-9FAM2-LW4SD-6J9DL-3S46L-K0XHW
                    Used output buffers: 1 of 24 (6 max)
                    Static ram: 25712
                    Dynamic ram: 93080 of which 476 recycled
                    Exception stack ram used: 272
                    Never used ram: 11532
                    Tasks: NETWORK(ready,676) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 00:00:43 ago, cause: power up
                    Last software reset at 2020-10-11 22:12, reason: User, spinning module GCodes, available RAM 11156 bytes (slot 2)
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 21.3, current 25.9, max 26.5
                    Supply voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
                    Date/time: 2020-10-12 08:00:06
                    Cache data hit count 107691558
                    Slowest loop: 5.54ms; fastest: 0.06ms
                    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                    === DDARing ===
                    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 15.73ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    - WiFi -
                    Network state is running
                    WiFi firmware version 1.23
                    WiFi MAC address 2c:3a:e8:0b:1c:bb
                    WiFi Vcc 3.34, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 23440
                    WiFi IP address 192.168.137.156
                    WiFi signal strength -53dBm, reconnections 1, sleep mode modem
                    Also my full config.g:
                    M667 S1 ; Select CoreXY mode
                    M550 PPrinter Extrusions ;machine name
                    M552 S1 ;start wifi module
                    M569 P0 S1 ; Drive 0
                    M569 P1 S1 ; Drive 1
                    M569 P2 S0 ; Drive 2
                    M569 P3 S1 ; Drive 3
                    M569 P4 S0 ; Drive 4
                    M92 X80 Y80 Z80 E456 ; Set steps per mm
                    M566 X900 Y900 Z1 E120 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X9000 Y9000 Z720 E1200 ; Set maximum speeds (mm/min)
                    M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
                    M906 X1200 Y1200 Z2200 E1100 I0 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S0 ; Set idle timeout
                    M208 X210 Y150 Z150 S0 ; Set axis maxima
                    M574 X1 Y1 Z0 S0
                    M140 H-1 ; Disable heated bed
                    M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                    M106 P0 H-1 ; set fan 1 to be gcode controlled
                    M106 P2 S1 I0 T45 H1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M563 P0 D0 H1 ; Define tool 0
                    By AutoHome I mean the Home All button in the Dashboard tab. I apologise, I got my RRF and Marlin terms mixed up.
                    undefined 1 Reply Last reply 12 Oct 2020, 11:33 Reply Quote 0
                      Can you manually send each line of your homeall.g in the gcode console from an unhomed state and see where you get the error message?
                        You have a M584 command after M350 and M906 commands, which is not recommended. M584 must come before any M350 or M906 commands. https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                        After that is fixed, definitely try running each line of homeall.g through the console to see where the issue is.
                          equanimity8
                          I've put the ;Independent motors leveling section right after the drivers assigning part of config.g and it has made no difference. As a side note, is there a resource I can follow about the recommended sequence of gcode and/or what are good practices when setting up firmware (kind of like M400 before M913 which was discussed above)?
                          I get the error on the "G1 Z5 F420 S2" line.
                          undefined undefined 2 Replies Last reply 12 Oct 2020, 16:30 Reply Quote 0
                            I think the M913 and M584 both have notes in the Duet GCODE Wiki saying what other commands to look out for (M913 is a little less clear when it comes to the note on M400). Many other commands have notes/dependencies for other commands.
                            That... doesn't make sense why it would fail there? For kicks, could you try changing the S2 to H2 instead? For your application, and being on 2.05.1, S2 and H2 should function the same.
                              equanimity8
                              No change.
                              fcwiltundefined 1 Reply Last reply 12 Oct 2020, 19:57 Reply Quote 0
                              • fcwiltundefined
                                fcwilt @equanimity8
                                No change.
                                As a test reboot your printer and enter that command (G1 Z5 H2 F420) in the DWC Console, just to be sure it is generating the "not homed" error.
                                  Phaedrux Moderator @equanimity8
                                  Every gcode is documented here: https://duet3d.dozuki.com/Wiki/Gcode#main
                                  It's a good idea to check the relevant gcodes when trouble shooting.
                                  How is your config.g laid out now? Can you post it again? The M584 should be above the M350.
                                  The homing file you've posted is from the /system folder right?
                                    equanimity8
                                    @fcwilt When I start with (G1 Z5 H2 F420) as per your suggestions I get a little but further, namely to G1 X5 Y5 F600 (line 8 in homeall.g) and I get the same error (Error: G0/G1: insufficient axes homed).
                                    @Phaedrux The current config.g:
                                    M569 P2 S0 ; Drive 2 goes forwards
                                    M569 P4 S0 ; Drive 4 goes forwards
                                    M574 X1 Y1 Z0 S0
                                    Everything that I've pasted is indeed from the System tab under File Management in DWC.
                                    fcwiltundefined 1 Reply Last reply 12 Oct 2020, 21:32 Reply Quote 0
                                      It really seems like your endstops are not actually working.
                                      Can you confirm what firmware version is installed with M115?
                                      And then can you confirm that the status of the endstops changes when you click them by checking with M119?
                                      Earlier when you send M98 P"config.g" it didn't seem to echo anything back. Can you try again? There should be at least some response.
                                        equanimity8
                                        The result of M115:
                                        M115
                                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b
                                        M119 correctly reports X and Y endstops (first/bottom is homed; then/middle is not; last/top is not for X and Y but I was tapping the nozzle to trigger the piezo):
                                        M119
                                        Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
                                        M119
                                        Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
                                        M119
                                        Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped
                                        No echo on M98 P"config.g" only green background on the message.
                                          I guess your config.g is stripped down enough that some of the usual things like showing HTTP and FTP enabled etc aren't present, so there's nothing getting echoed.
                                          Can you try adding M117 "Loading Config" to the end of config.g and when you save and reboot and send M98 P"config.g" again it should at least echo that.
                                          Ok it looks like endstops are reporting correctly.
                                          5 out of 34
