    Enclosed printer water cooled motors
    37
    4.0k
      A Former User @deckingman
      @deckingman said in Enclosed printer water cooled motors:
      Good idea. I'm thinking of doing exactly the same with a printer I'm planning. But I'm also toying with the idea of building a conveyor type, "infinite Y" build platform. I don't think anyone has done that inside a heated chamber - could be my next challenge........
      I know not everyone uses Facbook, but I just saw a guy post on there who had built a belt Y axis printer from a re-purposed running machine.
      For one in a heated chamber I think the main challenge would be to safely get the print to transition from the chamber to the atmosphere and still keep the heat in the chamber.
      • Vetiundefined
        Veti
        the voron ldo motors are rated to 180C. (130 chamber)
        https://www.filastruder.com/products/ldo-stepper-motors-all-types
        deckingmanundefined aprzundefined 2 Replies Last reply Reply Quote 0
          deckingman @Veti
          @Veti said in Enclosed printer water cooled motors:
          LDO - that was the make I was trying to think of. Are you sure about the spec? I could be wrong but I thought the winding temp was 130 deg C meaning a chamber temp of 80 deg C.
          • Vetiundefined
            Veti @deckingman
            check the link. there are 4 high temperature motors with a winding temp of 180C
            deckingmanundefined roiki11undefined 2 Replies Last reply Reply Quote 0
              deckingman @A Former User
              @CaLviNx said in Enclosed printer water cooled motors:
              I know not everyone uses Facbook,..............
              That's me - I don't "do" any social media, including Facbook or even Facebook 🙂 .
                deckingman @Veti
                OK cool - I stand corrected.
                • roiki11undefined
                  roiki11 @Veti
                  @Veti
                  That's the insulation class temperature. Without knowing the magnetic materials inside the motor it's hard to tell what's the curie point where the motors completely demagnetize. Most magnets also start losing power above 80C so it's best to keep their temperarures as low as possible.
                  • mrehorstdmdundefined
                    mrehorstdmd
                    What specific kind of failure does applying a heatsink or water jacket prevent?
                    Does a heatsink or water jacket cool the rotor where the magnets are located and separated from the stators by an air gap?
                    roiki11undefined 1 Reply Last reply Reply Quote 0
                    • roiki11undefined
                      roiki11 @mrehorstdmd
                      @mrehorstdmd
                      They prevent the loss of magnetism that happens in ferromagnets when temperature rises above their max working temperature point, until it reaches its curie temperature and completely demagnetizes.
                      Most motor magnets have the working temperature limit somewhere in the 80-160 range. Its never really stated properly and I wouldn't trust Chinese motors to use the proper materials.
                        The spelling was intentional....
                        • aprzundefined
                          aprz @Veti
                          @Veti I've looked at the dyze cooling blocks but they only cover a small surface area of the motor. I saw this https://www.researchgate.net/figure/a-Stepper-motor-cooling-shroud-installed-on-a-NEMA-17-stepper-motor-b-Computational_fig7_311666362 and i thought instead of running air through that heat shroud, run water and cool it further with a peltier. I think it looks promising as a better method of keeping the motors evenly cool.
                          • aprzundefined
                            aprz @Rushmere3D
                            @Rushmere3D I've seen that video of his when i was searching for watercooling. His method of cooling is similar to dyze he really did a great job.
                            • roiki11undefined
                              roiki11 @aprz
                              @1997alex said in Enclosed printer water cooled motors:
                              Cincinnati uses them in their SAAM HT and they seem to work fine.
                              • aprzundefined
                                aprz @Veti
                                @Veti I ended getting 0.9 degree moons stepper motors and i'm hoping they can withstand the heat. A member on prusa forum did multiple test with moons motors and LDO motors and the moons out performed the LDO motors.
                                https://forum.prusaprinters.org/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../stepper-motor-upgrades-to-eliminate-vfa-s-vertical-fine-artifacts/
                                • jens55undefined
                                  jens55 @aprz
                                  I think his advise is dangerous and irresponsible but maybe that's just me .......
                                  aprzundefined 1 Reply Last reply Reply Quote 0
                                  • aprzundefined
                                    aprz @jens55
                                    @jens55 hahaha, i suppose.
                                    • Vetiundefined
                                      Veti @aprz
                                      yes i have read that article. heated chamber was not one criteria there though 🙂
                                        mrehorstdmd
                                        Does the rotor generate its own heat or does it get all its heat from the stators?
                                        Does applying a heatsink or water jacket to the motor's stators cool the rotor which is separated from the stators by an air gap?
                                        theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                                        • theruttmeisterundefined
                                          theruttmeister @mrehorstdmd
                                          @mrehorstdmd
                                          Yes.
                                          Resistive losses will convert some of the magnetic flux into heat.
                                          But generally things like the insulation and the lubricant in the bearings are the limiting factors (the solder if there is any now I think about it).
                                          Most steppers are soft iron for both rotor and stators, iirc, which has a curie temp waaaaay above anything you are going to see.
                                          Water cooling is going to protect at least 1 of the bearings and probably the wiring. Its not the most efficient way of doing things, but it works.
                                          The next issue, if you are trying to get really hot is belt life. Gates only rate them to 80c iirc.
                                          Isolate, substitute, verify.
                                          JamesMundefined 1 Reply Last reply Reply Quote 0
                                          • JamesMundefined
                                            JamesM @theruttmeister
                                            @theruttmeister Gates offers high temperature belts rated to 135C
                                            https://www.filastruder.com/products/gates-2gt-belts-high-temperature-epdm
