    A Software Solution to Eliminate Ringing?
    71
    10.1k
      What I have in mind is that when the GCode involves a change in direction between adjacent printing moves, RRF will insert a joining move between them. This joining move would be a quadratic or cubic in shape, and would deviate from the path specified in the GCode by no more than a user-set deviation parameter. So an internal corner would be cut by no more than this amount. Different motors would be executing trajectories of different shapes during this joining move.
      botundefined DigitalVisionundefined 2 Replies Last reply Reply Quote 3
      • botundefined
        bot @dc42
        @dc42 @DigitalVision
        Why don't we use an approach that has already been implemented and proven in Klipper firmware? It sounds similar.
        Described here: https://onehossshay.wordpress.com/2011/09/24/improving_grbl_cornering_algorithm/
        First let’s assume that at a junction of two line segments, we only look at centripetal acceleration to simply things. In other words, we assume the tangential velocity is zero and the velocity through it is constant. At the junction, let’s place a circle with a radius R such that both lines are tangent to the circle. The circular segment joining the lines represents the path for constant centripetal acceleration: junction = sqrt (a max R) [See URL for correct forumlas]. Where the maximum junction velocity v junction is the fastest speed the CNC can go through the junction without exceeding the CNC’s maximum allowable acceleration a max.
        This circular segment creates a virtual deviation from the path delta, which is defined as the distance from the junction to the edge of the circular segment. This delta parameter is defined by the user as a setting, which indirectly sets the radius of the circle, and hence limits the junction velocity by the centripetal acceleration. Think of the this as widening a race track. If a race car is driving on a track only as wide as a car, it’ll have to slow down almost to a complete stop to turn corners. If we widen the track a bit, the car can start to use the track to go into the turn. The wider it is, the faster through the corner it can go.
        A note on the Klipper implementation:
        However, in Klipper, junction speeds are configured by specifying the desired speed that a 90° corner should have (the “square corner velocity”), and the junction speeds for other angles are derived from that.
        More info on the Klipper firmware: https://www.klipper3d.org/Kinematics.html
        *not actually a robot
        DigitalVisionundefined 1 Reply Last reply Reply Quote 0
        • DigitalVisionundefined
          DigitalVision @bot
          @bot said in A Software Solution to Eliminate Ringing?:
          This approach is certainly the easiest one, especially in a firmware that already supports arcs, but the problem is that this method doesn't preserve a continuous curvature. There is an abrupt change in curvature going from the smooth line to the circle, something that would yield an instantaneous position change with spring-damper compensation.
          In road and railroad construction you never build curves like that for the same reason. You would have to turn your steering wheel instantaneously to a new position to follow such a path. What civil engineers do instead is add a transition curve (a spiral shape) that creates a gradual increase in curvature.
          With a polynomial spline (like @dc42 suggests) we can create a curve that has a gradual curvature.
          • botundefined
            bot @DigitalVision
            @DigitalVision interesting. Thanks for the explanation.
            That makes sense. Instead of the G1 curvature, it might be G2 or G3?
            I'm not as smart as you two when it comes to these algorithms, so I'll keep to myself now. I just get worried when there is talk of the firmware injecting intentional deviation into the stream. I'll have to wait and see results, I guess!
            [Edit: Just to clarify, the Klipper method does not actually deviate from the path -- it is only a virtual deviation to calculate the speed change possible.]
              DigitalVision @dc42
              @dc42 said in A Software Solution to Eliminate Ringing?:
              In order to satisfy a smooth curvature (G2 continuity) at both the start end end of such a joining segment, I you either need a higher order polynomial than quadratic or cubic or you need to piecewise combine multiple polynomials. An easy way to think about it is that a cubic polynomial only has one point where the second derivative is zero and you need two. For a single polynomial to describe a symmetric transition curve, I think you need a 4th degree (quartic) polynomial, and for a generic transition between two arbitrary points the degree increases to 5 (quintic?).
              Another important property that we want for a smoothing method is to allow for constant arc-length speed. I.e. the print head should be able to move through a circle made up of line segments at constant extrusion speed. This means that ideally you want the curve to be parametrized based on arc length. For a circular arc this is trivial, but it's not so easy for a polynomial curve shape. That's the reason I suggested a second inverse-arc-length approximating polynomial.
              In the extension though, if you implement say a spline of 3rd order polynomials to support joining moves you've basically done 90 % of the job of supporting a general spline motion profile. And going all the way has some very nice properties. The slicer could now output perfect arc and elliptical shapes, and replicate more generic curve shapes out of most CAD software perfectly. I believe this is where the industry is going for advanced CNC control paths.
                DigitalVision @bot
                That's right. In the end, we actually need C2 continuity, but if you start with G2 you can reparametrize it to achieve C2.
                You bring up some good questions. The intentional deviation may sound controversial, but it's actually the reality already. I don't know of any high-end professional CNC machine that doesn't do this (since it significantly increases the motion speed), and that's generally an application with much tighter tolerance requirements. In the case of joining line segments and doing spring-damper compensation the outcome is actually a more faithful reconstruction of the original curve.
                You could make a valid argument that the smoothing should be done by the slicer instead of the firmware. I don't have a strong opinion either way. I think the reality is that a lot of the way our current pipelines are constructed just kind of happened and making a local change is much easier than driving a change across softwares. For example there is no good reason a slicer should need to know what your filament diameter is.
                If smoothing were implemented in firmware, I would expect it to be controlled by a cordial error tolerance parameter that you could set to zero to disable the behavior.
                Thanks, that makes sense.
                theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                • botundefined
                  bot
                  I've been modifying PrusaSlicer for the past few months as a way to slowly learn and get used to how it works under the hood. My end goal is to make sure the slicer and firmware are playing nicely together. If you want to try and put some of this smart stuff into PrusaSlicer, maybe just for testing, I'd be glad to lend a hand with the tedious bits or pointing you around the codebase as best as I can.
                  I do get worried at the thought of the firmware having more calculation overhead. Once we solve the "jerk" problem, and we can round corners faster, then we solve the ringing problem, we'll quickly encounter the next problem: too many segments too fast.
                  • CCS86undefined
                    CCS86
                    Great thread!
                    I am very interested to see this progress.
                    • theruttmeisterundefined
                      theruttmeister @DigitalVision
                      The only argument I can see for accepting implementation in the slicer is if the processing overhead is so huge that it cannot be done in firmware.
                      Adding it to the firmware keeps the firmware slicer agnostic.
                      It also means people using RRF for non-FFF projects can use the functionality.
                      And just like bed-leveling, its a per-machine setting. If you are running a printfarm, its a nightmare to have to deal with machine specific slicing profiles.
                      Very true. I think that's mostly due to legacy slicing function. I know there's no firmware reason to keep working like that.
                      Isolate, substitute, verify.
                      PCRundefined 1 Reply Last reply Reply Quote 1
                        DigitalVision
                        A short update.
                        I managed to get some hours to spend on this today, so I rewrote the test code from before mostly from scratch and turned it into a G-code filter. I can now take a regular slicer output file, pass it through the filter and feed the result to the printer. This makes it easier to do realistic testing. The code only really supports linear paths to far, so curves with high tessellation counts will end up looking terrible, but it should work OK for calibration cubes and similar objects. In the process of rewriting it I also implemented some improved machine limits so I won’t have to worry about it trying to move the Z-axis on my cartesian printer at 120 mm/sec.
                        Here are some quick-and-dirty results.
                        speed: 80 mm/s, accel: 10 m/s² (10,000 mm/s²), jerk: 2 km/s³ (2,000,000 mm/s³)
                        I'm actually pretty happy with that given that this is a 490 g heavy end effector on 375 mm diagonals. For reference, here's what it looks like without any spring-damper compensation:
                        speed: 80 mm/s, accel: 5 m/s² (5,000 mm/s²)
                        Pushing it a bit faster.
                        speed: 120 mm/s, accel: 20 m/s² (20,000 mm/s²), jerk: 2 km/s³ (2,000,000 mm/s³)
                        Some extrusion glitches, but not much ringing.
                        I’ll share the code once I’ve written a little documentation on how to use it as I’d love to get some more testing and learnings.
                        CCS86undefined 1 Reply Last reply Reply Quote 6
                        • CCS86undefined
                          CCS86 @DigitalVision
                          @DigitalVision said in A Software Solution to Eliminate Ringing?:
                          A short update.
                          That is a beautiful print!
                          • PCRundefined
                            PCR @theruttmeister
                            @theruttmeister
                            Only a quick thought. I really like the idea of a slicer setting for that.
                            I am using KISSlicer alot with the PreloadVE feature. In the end the machine do not know how the 3D model look. So i think the best approached is a hybrid one!
                              theruttmeister @PCR
                              @PCR
                              Its always going to be hybrid.
                              I would make the case that this specific thing (software compensation for position error) is about getting the printer to actually do what you told it to do. If the printer was more rigid, the function would not be needed. Therefore, it falls into the same category as basic things like steps per mm.
                              And it has applicability for any motion control done with RRF/Duet, not just FFF.
                              Functions like Preload in KISSlicer (not that I have used it), are material specific, not just machine specific. So it has to be in the slicer to work correctly.
                              And its a function that only works for FFF.
                              @PCR said in A Software Solution to Eliminate Ringing?:
                              @theruttmeister
                              For what?
                              If you mean filament diameter, my point was that we could be using a volumetric value, people don't because there's no real advantage to it and we all got into the habit of futzing with the slicer setting to get certain effects... But if most printers had an accurate device for measuring filament diameter as it went into the extruder, it would produce more accurate prints.
                              Not to a degree that I think most people would notice though. Which is why its not a thing.
                                DigitalVision
                                Another update.
                                Before sharing the python code, I wanted to test it on at least one other printer. This time on a cartesian (CoreXY) printer with CPC linear rails. The printer x-axis is made up of one single 15mm rail with a sole runner block holding the hotend and extruder assembly. The rail itself is very rigid. The weak point is instead the x-axis carrier/runner block that has a bit of yield to its roll axis (resulting in ringing along the y axis).
                                In getting the calibration done for this printer I learned a number of new things. First, and very importantly there are actually two modes of ringing. The first one is the one we classicality think of as ringing. It occurs after the printer has decelerates down to a full stop and the end effector oscillates. The photo below illustrates this.
                                The second type of ringing was something I hadn’t considered before. It’s ringing that happens during the acceleration phase. If you look carefully you can see it happening in the simulation in the first figure in https://www.digitalvision.blog/spring-damper-control. The effect may look subtle in that animation, but the result on an actual print is much more substantial. The effect is that the extrusion bead gets stretched and compressed periodically.
                                The effect of this is what I suspect often prevents getting consistent extrusion when printing at high speeds. The extrusion gets ripped apart in the stretching phase. After correcting for this ringing I’ve been able to print consistently even at 150 mm/s with 10 m/s² accelerations, something that I’ve never managed before.
                                When observing ringing on a print, you will often see a compound effect of both of these two modes of ringing, with the acceleration ringing from e.g. the x-axis compounding with the post-deceleration ringing from the y-axis. When the two axes have different natural spring frequencies the two axis parameters can be hard to tease apart. For that reason, I came up with the strategy of isolating one axis at a time by setting the acceleration limits of the other axis to a very low value. E.g. 10 m/s² acceleration on the y axis with 0.5 m/s² acceleration on the x.
                                My final issue with calibrating this printer was that I was unable to find a single setting that eliminated the ringing on both the left and right side of the print. The left side had a ringing frequency of ~52 Hz with the right side closer to 60 Hz. It seems like the ringing had different frequencies when moving in the positive y direction vs the negative. Thinking a bit about this I came up with a model that makes sense. The print head is not perfectly balanced under the axis with the center of gravity being offset to one side. This effectively means that gravity is applying pre-tension on the spring biasing the spring effect towards one direction. To test this hypothesis I implemented an asymmetric spring model and plugging in 52 and 60 Hz respectively for the two axes did the trick.
                                  DigitalVision
                                  Here's the python test code if anyone wants to give this a shot.
                                  https://github.com/OskarLinde/dynamic-motion
                                  The link contains some preliminary instructions for how to use and calibrate the method. You need at least RRF 2.03 since without the M566 P1 jerk policy the G-Code doesn't execute reliably. I was able to run this on an unmodified firmware for simple objects, but found that I could increase the discretization points and run more complex objects if I made a minor firmware change: I disabled the motion planner (look_ahead) if the current move speeds were below the current instantaneous velocity change settings. With this, the extrusion issues in the 120 mm/s print went away. Oh, I also implemented pressure advance correction the script since the firmware one doesn't work with the type of G-Code the script outputs.
                                  While there are many limitations as described above I'd love to get some testing of this approach: Were you able to get it to work? Were you able to see any improvements in ringing or improvements in print speeds? What type of printer and what calibration values did you land on?
                                  1 Reply Last reply Reply Quote 4
                                  • sebkritikelundefined
                                    sebkritikel
                                    Despite the fact my machine is half disassembled, and the fact I recently swapped out extruder motors without much 'calibration' this has been pretty cool to work with. I don't think I have anything workable yet, but still neat to play with. Once I get my machine put back together, hopefully I'll be able able to work through the parameters more methodically.
                                    A quick note - I'm thinking the z_max (in mm) parameter is a bit wonky, initially I did some thin wall prints that were 100mm tall, and could only see variation (both in Craftware for previewing) and in the print for the first 20mm or so - even if I set z_max to 100. When I set it to 20mm (for a 20mm tall print) it also looks like the variation occurs in the first 5-8mm or so.
                                    Ok, testing was done on an IDEX machine (only with T0). Fairly heavy Y gantry that carries the T0 and T1 print heads, plus X and U steppers. A quite large print bed, so I modified the python files to eliminate changes to the Z axis (had some issues during my first few tests). I get some significant defects due to the bed oscillating on layer changes. Some potentially useful information from the config.g
                                    M92 X100.00 Y96.00 Z1280.00 U100.00 E415.00        ; Set steps per mm
                                    M566 X1000.00 Y1000.00 Z500.00 U1000.00 E36000.00         ; Set maximum instantaneous speed changes (mm/min)
                                    M566 P1
                                    M203 X18000.00 Y18000.00 Z1320.00 U18000.00 E3000.00     ; Set maximum speeds (mm/min
                                    M201 X4000.00 Y4000.00 Z450.00 U4000.00 E3000.00         ; Set accelerations (mm/s^2)
                                    M906 X1800.00 Y2400.00 Z2400.00 U1800.00 E1960.00:500.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                    The unmodified print file: JP_talltestPart2.gcode
                                    Short video of unmodified print - https://www.youtube.com/watch?v=3PDYEEwW7_I
                                    First I ran a print of the above file - shown as "F" in pictures below ("F" for front of build plate haha). Printed with HIPS at somewhat high temperatures, no part cooling, 100mm/s. In the FRONT view, the printhead moves left to right along the X axis. In the Right view, the nozzle moves left to right along the Y axis... etc. DAA, PA, etc, all were turned off for the reference print. The reference print is stacked on top of the modified gcode print. For "Fx" I ran the script targeting x f_n, ranging from 5 to 75 across Z=20 (see note above). Yes, the X axis did a good amount of shaking.
                                    Video - https://www.youtube.com/watch?v=6TJ2uW1rX_E
                                    File - x-5-75.gcode
                                    import move
                                    # EXAMPLE CONFIGURATION, PLEASE EDIT BEFORE USING
                                    class motion_parameters:
                                        dynamic_model = [
                                            move.spring_damper_parameters(f_n = 0, zeta = 0), # x
                                            move.spring_damper_parameters(f_n = 0, zeta = 0), # y
                                            #move.asymmetric_spring_damper_parameters(f_n_negative = 52.5, f_n_positive = 56.9, zeta = 0.02), # y
                                            move.spring_damper_parameters(f_n = 0, zeta = 0.0), # z
                                            move.pressure_advance_parameters(k = 0.00)     # e
                                        max_speed = 300
                                        accel = 12000
                                        jerk = 2000000
                                        non_motion_max_speed = 300 # i.e. extrusion-only moves
                                        non_motion_accel = 12000
                                        non_motion_jerk  = 2000000
                                        axis_limits = [
                                            move.axis_limits(speed = 300), # x
                                            move.axis_limits(speed = 300, accel=500), # y
                                            move.axis_limits(speed = 22, accel = 1200, jerk = 1000), # z
                                            None, #e
                                    # adjust a parameter dynamically based on the z height
                                    def calibration_adjustment(z):
                                        # example
                                        value_min = 5
                                        value_max = 75
                                        z_max = 20     # mm
                                        value = z / z_max * (value_max - value_min) + value_min
                                        #motion_parameters.dynamic_model[0].zeta = value  # adjust x zeta
                                        #motion_parameters.dynamic_model[1].zeta = value  # adjust y zeta
                                        motion_parameters.dynamic_model[0].f_n = value   # adjust x f_n
                                        #motion_parameters.dynamic_model[1].f_n = value   # adjust y f_n
                                        #motion_parameters.dynamic_model[1].f_n_negative = value   # adjust y f_n
                                        #motion_parameters.dynamic_model[1].f_n_positive = value   # adjust y f_n
                                        #motion_parameters.dynamic_model[3].k = value     # adjust pressure advance
                                    # adjust these to adjust the linear interpolation and coarseness of the generated output
                                    # reducing the tolerances will increase the size of the output file (and more likely cause the printer motion planner to choke)
                                    class curve_parameters:
                                        tolerances = [
                                            0.002, # x (2µm)
                                            0.002, # y (2µm)
                                            0.050, # z (50µm)
                                            0.100, # e (0.1mm) # low tolerance to prevent pressure advance from adding nodes at the potential detriment of the xy spring-damper control
                                        min_dt = 1/200
                                    def disable_acceleration_control():
                                        print('M566 P1') # RRF Jerk Policy 1
                                        print('M572 D0 S0') #  dis.able pressure advance
                                        #print('M201 X100000 Y100000 Z100000 E100000') # disable acceleration
                                        print('M201 X100000 Y100000 E100000') # disable acceleration
                                        #print('M205 X10000 Y10000 Z10000 E10000') # infinite instantaneous velocity change
                                        print('M205 X10000 Y10000 E10000') # infinite instantaneous velocity change
                                    def restore_acceleration_control():
                                        print('M201 X4000 Y4000 Z1200 E3000') # reset acceleration
                                        #print('M205 X10 Y10 Z10 E10000') # reset instantaneous velocity change
                                        print('M205 X10 Y10 E10000') # reset instantaneous velocity change
                                    For the image below, same notes - targeted Y axis. I read your warning on going below 20Hz and promptly ignored it hahahahaha
                                    Video - https://www.youtube.com/watch?v=Yc9EpRiLeGE
                                    y-5-75.gcode
                                    import move
                                        dynamic_model = [
                                        max_speed = 300
                                        accel = 12000
                                        jerk = 2000000
                                        axis_limits = [
                                            move.axis_limits(speed = 300, accel=500), # x
                                            move.axis_limits(speed = 300), # y
                                            None, #e
                                        # example
                                        value_min = 5
                                        value_max = 75
                                        z_max = 20     # mm
                                        #motion_parameters.dynamic_model[0].f_n = value   # adjust x f_n
                                        tolerances = [
                                            0.002, # x (2µm)
                                            0.002, # y (2µm)
                                            0.050, # z (50µm)
                                        min_dt = 1/200
                                    Fun to watch and futz with (I did many more prints prior to this), but unfortunately nothing conclusive. What I did do was measure the ringing in the reference print on each side, and then ran the print again only targeting those values (no value hunting). I threw in X=25Hz, and (the reason escapes me now) Y=30Hz. The amplitude of the vibrations are much lower (read: surface is smoother) than the reference print (I also ran a print swapping the X and Y values, where in the inverted prints the results were not as good). Unfortunately the picture doesn't quite paint a clear picture.
                                    Video - https://www.youtube.com/watch?v=P6JSEvgVD6A
                                    File - x-25-y-30.gcode
                                    import move
                                        dynamic_model = [
                                            move.spring_damper_parameters(f_n = 25, zeta = 0), # x
                                            move.spring_damper_parameters(f_n = 30, zeta = 0), # y
                                        max_speed = 300
                                        accel = 12000
                                        jerk = 2000000
                                        axis_limits = [
                                            None, #e
                                        # example
                                        value_min = 5
                                        value_max = 75
                                        z_max = 20     # mm
                                        tolerances = [
                                            0.002, # x (2µm)
                                            0.002, # y (2µm)
                                            0.050, # z (50µm)
                                        min_dt = 1/200
                                    Large(ish?) IDEX - 6HC, 1HCL
                                    Stratasys Dimension 1200es to 6HC Conversion
                                    DigitalVisionundefined 1 Reply Last reply Reply Quote 1
                                      DigitalVision @sebkritikel
                                      @sebkritikel said in A Software Solution to Eliminate Ringing?:
                                      Thanks for testing! These are very interesting results.
                                      I don't think the parameter is broken – it's more the consequence to the correction magnitude of increasing f_n. The higher the number the smaller the correction, asymptotically approaching zero. The correction magnitude is proportional one over the square of the f_n number, so at say 50 Hz you will get 4x less correction than at 25 Hz, and at 5 Hz (your lowest number, the correction is 100x higher.
                                      Looking at your g-code, your slicer is not spiralizing the contour, so I think your modifications are ok. You should be able to achieve the same effect by reducing the accel setting in the z axis limits though.
                                      File - x-5-75.gcode
                                      On the front view, you definitely see a significant improvement around one third up corresponding to roughly 25~30 Hz. I don't quite understand what's happening on the back side though. I think maybe the lack of cooling keeps the filament from achieving good adherence to the layer below.
                                          axis_limits = [
                                      With such a low jerk value, I'm surprised you have issues with the z axis.
                                      y-5-75.gcode
                                      You should definitely increase the low end of the range from 5Hz to something higher (15 Hz maybe?). The poor extrusion at the bottom is making reading these quite hard. Another thing that helps is plugging in the ~28 Hz value from the X-axis calibration above here to minimize the cross-talk. That being said, you can definitely see a phase transitioning happening in the range of 25-50 % of the height. I've generally been successful picking the middle point of the phase transition.
                                      I think this is a good start. It always took me a few iterations to get it tuned, you should zoom in on the parameters a bit more (e.g try 20–35 Hz). Zeta can also be critical to calibrate (depending on your printer). It's also possible that doing 12000 mm/s² acceleration is aiming too high and you start hitting non-linear spring behaviors. My CoreXY printer has ringing in the range of 52-60 Hz which is almost exactly 2x of your values. Since that means 4x as much spring compensation I'd not be surprised if you need to back off on the acceleration setting.
                                      The thing about photos of shiny filament is that they amplify the curvature changes over the magnitude – you see similar specularities even after reducing the ringing magnitude by a significant factor. You probably want to get your f_n estimates to within 2–5% or so to start seeing more dramatic improvements.
                                      Finding my most similar silver filament, here an "after" print I made on my CoreXY:
                                      80 mm/s, 10,000 mm/s², 2 km/s³ jerk
                                      I didn't have enough filament to finish a "before" shot. This was as far as I got:
                                      (identical printing parameters)
                                      Ignore the horizontal lines in the middle of the silver zone – that's when I fed in the gold filament.
                                      sebkritikelundefined 1 Reply Last reply Reply Quote 1
                                      • oliofundefined
                                        oliof
                                        @DigitalVision does your script support arc moves, i.e. G2/G3 moves? I am asking because I sometimes use ArcWelder as a postprocessor to turn segmented curves back into real curves (mostly to compress the gcode)...
                                          sebkritikel @DigitalVision
                                          @DigitalVision Many thanks for the response! Appreciate all of your comments.
                                          Many thanks for your comments! Great insight all around.
                                          Spiral mode... should have started with that!
                                          Not quite there yet, but narrowing it down some - the after here is taken at f_n X to 21Hz, f_n Y to 30Hz (X picked after running from 19-26, Y a number of times from 15-50).
                                          The Y axis was quite interesting to watch and tune for. When running from 15-100 Hz, you could see the initial set of ripples fan out some, and then a second set begin to develop. Image below is likely from 15-50Hz.
                                          For the iterations above, I dropped accelerations to 8000mm/s^2, and jerk to 1,000,000, but have started dropping each of those lowers. I ran one print at 4000mm/s^2 and something like 80,000 (typo), which naturally took quite long, but looked great.
                                          The acceleration values in my config.g (specifically for X, U, and Y), are not picked for print quality, rather they are derived from stepper motor torque, gantry mass, and any gearing present. Some more investigation and test needed on my end there with respect to acceleration and jerk values.
                                            Just be careful with your hack to let the machine do Z acceleration ramping in that case. It breaks the time-critical assumption baked into the constant velocity segments that get output.
                                            I also found that Slic3r generate a tiny extra-move at one of the corners in spiral mode which is not ideal with the script. Maybe Cura does spirals better.
                                            I curious how you end up with such low frequencies and what's dominating the X-spring in your system. Are your belts fairly loose? How long is the X travel?
                                            The left/right asymmetry is very interesting. You may be seeing a higher frequency of ringing when the printer is accelerating in the negative Y than positive. I had something similar myself but not at all as extreme, which is why I had to implement the asymmetric spring function. Here are my settings:
                                                dynamic_model = [
                                                    move.spring_damper_parameters(f_n = 60.5, zeta = 0), # x
                                                    move.pressure_advance_parameters(k = 0.08)     # e
                                            I found it easiest to calibrate the axes when looking at the acceleration ringing rather than the post-deceleration ringing, and decoupling them required setting a low acceleration (500 in my case) on the other axis.
                                            From your image here it does look like there is possibly a bit of post-deceleration ringing at a low frequency on top (the wavy pattern) that may be creating the interference pattern with a higher frequency acceleration ringing on the bottom. You may need to go even lower/more extreme than 500 mm/s² on the X axis to get a clearer read on Y.
                                            There could also be a non-linear spring response – or you simply need to calibrate zeta. On my delta, I did see a similar phase change pattern, so I picked the middle of the transition zone for f_n and swept zeta from 0-0.5 and picked 0.10. The effect from zeta is much more subtle, but allowed the two phases of the interference pattern to separate when re-running a f_n sweep.
                                            DigitalVisionundefined sebkritikelundefined 2 Replies Last reply Reply Quote 0
