    Smart Effector including toolboard-capabilities?
    Smart effector for delta printers
    smart effector future development hardware delta
    19
    113
    12.3k
      Interesting! However, that reduces the printable height somewhat. What is the printable area of your delta, and how much would you lose if the rod spacing was increased to 80mm?
      Dougal1957undefined A Former User? 2 Replies Last reply Reply Quote 0
      • Dougal1957undefined
        Dougal1957 @dc42
        @dc42 said in Smart Effector including toolboard-capabilities?:
        Personaly David I don't think I would lose any build volume at all my bed is 360 Diam I may lose a little bit of Z but not a lot (Our printers are pretty similar apart from mine is a bit wider and upside down and 450 long arms.
        So if you want to try it at this size I can easily test one. as I did the first one.
        Doug
          A Former User @dc42
          I lost 45mm in print height, and coincidentally without even thinking about it or trying, my print height now exactly matches the print area of 320mm as I was slightly longer on my vertical rails anyway.
          • PCRundefined
            PCR
            @dc42 found this too
            https://www.thingiverse.com/thing:4648938
            • bbergerundefined
              bberger
              This topic is interesting!
              Ordered an Orbiter too. I'll want to use it in my Frankenstein Predator.
              Please keep us updated about possible Smart Effector updates - looking forward to this ❤
                We do plan to produce a combined Smart Effector and tool board, however we need to get another hardware project completed first.
                • o_lampeundefined
                  o_lampe @dc42
                  It's clear to me that the Orbiter could not be used with a Smart Effector made to the current dimensions. We would need to increase the rod spacing to at least 80mm in order to accommodate the various parts of the extruder. We are looking into this, however it would make it unsuitable for the smaller delta printers.
                  Hi dc42,
                  I just stumbled across this thread and wanted to guide you back to 2016 , when we discussed the cycloidal direct drive. (I still have it laying around)
                  I've made an 45 degree adapter for it, that suited the smart effector pretty well.
                  Another way to mount it, was the split motor/gearbox idea.
                  I could try to reuse my motor and design a BMG-drive for the Smart effector?
                  • apakundefined
                    apak
                    photo_2021-02-10_13-36-27.jpg photo_2021-02-10_02-36-04.jpg photo_2021-02-10_14-25-38.jpg photo_2021-02-09_23-54-32.jpg photo_2021-02-07_12-20-48.jpg
                    video_2021-02-11_00-13-44(1).mp4
                    We are doing some prototyping, with a regular orbiter, changing some aspects of the body.
                    It actually is a pivot extruder, so it can rotare freely within the rod arms...
                    It´s not my doing, just a friend´s I am helping him to achive it
                    Hergonowayundefined 1 Reply Last reply Reply Quote 3
                      Looks good!
                      We do have plans to produce a combined Smart Effector and tool board. The main decision we need to take is how large to make it.
                      apakundefined opentoideasundefined 2 Replies Last reply Reply Quote 2
                      • apakundefined
                        apak @dc42
                        @dc42 We are just two 3d printing fans....just doing it as a hobbie...no bussiness attached
                        • Lorincz Robertundefined
                          Lorincz Robert @dc42
                          @dc42 Hi, I'm the designer of the Orbiter extruder.
                          For delta printers you need the version with flipped gears like this one:
                          https://www.thingiverse.com/thing:4609940
                          The filament path is closer to the middle of the extruder so has a better clearance towards the rods.
                          I designed an adapter to fit this version you can find it here:
                          The result is not the best but it works.
                          The upcoming V2 will be more optimized in size and would fit better to delta printers. But I have not tried it yet.
                          dc42undefined 1 Reply Last reply Reply Quote 3
                            dc42 administrators @Lorincz Robert
                            @Lorincz-Robert , thanks. Looking forward to the V2!
                              Lorincz Robert
                              here is a teaser video of V2:
                              https://www.youtube.com/watch?v=hpvJZ1BHheM&t=2s
                              garyd9undefined 1 Reply Last reply Reply Quote 3
                              • garyd9undefined
                                garyd9 @Lorincz Robert
                                @Lorincz-Robert said in Smart Effector including toolboard-capabilities?:
                                Watching the video in the context of this thread (which is specific to the smart effector and delta printers), my impression is that the filament path doesn't seem any closer to the center of the extruder (compared to the "CR" version of the orbiter.) If the offset is the nearly the same, the same type of adapter that moves the extruder high up above the effector will have to be used... At that point, many people will prefer a full size "flying" extruder floating 40 to 50mm over the effector.
                                I'm also concerned about the low suggested 'jerk' suggested for the orbiter. Low jerk negatively impacts pressure advance, and more pressure advance would be needed when there's a long filament path between the extruder and effector.
                                • Hergonowayundefined
                                  Hergonoway @apak
                                  @apak this looks very promising, is there any way to follow your progress on this project? like a thingiverse page or a forum thread?
                                  Delta goes BrrrRRRRrrrrrRRRRrrr
                                  • apakundefined
                                    apak
                                    @Hergonoway It´s not my doing...I am just a part of it as I "consultant". The guy doing it might do some tweaks, but He is planning on a whole differnt design for a direct extrusion for smarteffector. He is up to date with this thread so He might post something
                                      We'll hold fire on designing a combined Tool Board/Smart Effector until we know what rod spacing we need to use to accommodate an extruder mounted directly on it. I think it will be around 80mm, but we really need to know extruder dimensions to be sure.
                                      • mrac1undefined
                                        mrac1
                                        This design work's pretty good an the rod spacing is 64 mm. Do you need the step file?
                                        garyd9undefined Hergonowayundefined 2 Replies Last reply Reply Quote 0
                                        • garyd9undefined
                                          garyd9 @mrac1
                                          @mrac1 said in Smart Effector including toolboard-capabilities?:
                                          That would be nice. That doesn't look quite like the orbiter - is it something you designed? Any information you can provide to replicate would be very useful.
                                          I'm desperate to replace the nimble I'm using on my smart effector. I'm actually considering going back to a titan extruder, pancake motor, and piezo all hanging from a non-smart effector.
                                          mrac1undefined 1 Reply Last reply Reply Quote 0
                                            Hergonoway @mrac1
                                            @mrac1 I'd be glad if you could provide the step file. I'd like to try something with the dc42's 80mm assumption base on your model.
                                            I've got 2 questions:
                                            • why did you choose this ball stud placement? Wouldn't it been easier to "just" offset the ball studs from the smart effector set horizontally to reach the desired clearance? Maybe it's just for the design aspect, or because of the top heater connector but I have to ask 🙂
                                            • what's your feedback with this 2x4010 blowers configuration? Main issue with a smart effector and a mosquito is the vertical clearance to play with while keeping a good airflow distribution.
                                            mrac1undefined garyd9undefined 2 Replies Last reply Reply Quote 1
