    What firmware version are you using?
    47
    3.6k
    • fcwiltundefined
      fcwilt @Frederik
      @Frederik said in What firmware version are you using?:
      at the moment iยดm really happy with the new 3.3beta1. Especially the new Function to Tune Heaters connected to Toolboards ๐Ÿ™‚
      You're a brave man - I guess it comes from having a great name. ๐Ÿ˜‰
      Frederikundefined 1 Reply Last reply Reply Quote 1
      • Frederikundefined
        Frederik @fcwilt
        @fcwilt ๐Ÿ™‚
        • zaptaundefined
          zapta
          I am on 3.1.1 (2020-05-19b2).
          Does duet3d have any recommendation on what version we should use if want long term support without having to upgrade to each new release?
          • oliofundefined
            oliof
            there is no LTS release. The recommendation so far always was to use the latest stable release (i.e. 3.2.2 right now). In practice, if you are on a release that works for you, there is no need to update. Unless there is (-:
            • martin7404undefined
              martin7404
              On a modified China corexy I run 2.05 and on new Muldex build yesterday 3.11, today 3.2 and at the moment rolling back as far 3.2 have major issues with tool change on my IDEX
              Muldex IDEX Duet2+Duex5
              Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
              Sapphire Pro with Duet2, with closed-loop motors
              custom high temp E3D tool changer with Duet2+Duex
                Phaedrux Moderator @zapta
                @zapta said in What firmware version are you using?:
                Ride the wave!
                • zaptaundefined
                  zapta @Phaedrux
                  @Phaedrux said in What firmware version are you using?:
                  Ride the wave!
                  My printer is pretty stable and useful these days so my focus shifted from the printer itself to what I am creating with it.
                    @zapta well understood. Keep an eye on the release notes to see if anything is relevant to you. Now that rrf3 is maturing more features and improvements are on the way.
                    • o_lampeundefined
                      o_lampe @martin7404
                      @martin7404 said in What firmware version are you using?:
                      Is there a separate thread about it?
                      I got pushed to upgrade from 2.05 to 3.2.
                      But now that I'm in the process of building my own tool changer, I am concerned reading this note from you...
                        martin7404
                        Most probably it is some mistake in panel due manual operation, that made me change from - to + tool offset. It seems it is ok now
                        • oliverracingundefined
                          oliverracing
                          Currently running 2.05 on both my machines, but plan on switching to whatever is latest at the time when changing the kinematics of the portable printer (currently polar swing-arm but it's a bit flexy, changing it to corexy).
                          Main printer is hooked up to looks of external stuff and using outputs for things that they probably shouldn't be so will have to rethink before upgrading as that's a big job and it's currently working!
                          • GeneRisiundefined
                            GeneRisi
                            How well does the RRF3 firmware run on the Duet2? It has less compute power than the Duet3, so, while I know it is possible, does it handle conditional gcode well, or is it underpowered?
                            Phaedruxundefined NeoDueundefined 2 Replies Last reply Reply Quote 0
                              Phaedrux Moderator @GeneRisi
                              @GeneRisi said in What firmware version are you using?:
                              It runs it perfectly fine. There are no limitations or draw backs running RRF3 on the Duet2 series boards. Even the Maestro.
                              • Diamondbackundefined
                                Diamondback
                                Yep I can confirm that, been running RRF3 since it came out on my Duet 2 Wifi and there is nothing negative about it. Works perfectly fine and all the goodies are so worth the switch. ๐Ÿ™‚
                                • NeoDueundefined
                                  NeoDue @GeneRisi
                                  @generisi I can confirm that it runs perfectly fine and fast as well.
                                  I had the "Operation 3 failed" Wifi problem (https://forum.duet3d.com/topic/21562/firmware-bundle-3-2-2-released/) when upgrading from 3.2.0 to 3.2.2 though.
                                  • RyanPundefined
                                    RyanP
                                    2.05 on all machines. Too much on my plate. But one day I will simply do all machines.
                                    CR10S, August 2018
                                    Anycubic Photon S December 2019
                                    Ender 5 Feb 2020
                                    Ender 5 Plus May 2020
                                    Anycubic Photon Mono X Nov 2020
                                    https://3dimensiongames.com/
                                    • EducatingSavvasundefined
                                      EducatingSavvas @Phaedrux
                                      @phaedrux I tried the latest beta version but found the addition of a P parameter to define a spindle tool in the M3 command problematic - so went back to 3.2. I got it working but suspect using/gearing up for multiple tools (tang knife, laser, plotting-pen and spindle) will be over complicated by this. Possibly having to to use separate post processors for each tool, instead of using the tool number in the tool database to determine the tool I am using.
                                        dc42 administrators @EducatingSavvas
                                        @educatingsavvas said in What firmware version are you using?:
                                        You only need the P parameter if you are in CNC mode and you want to control a spindle that is not the one used by the active tool.
                                        EducatingSavvasundefined 1 Reply Last reply Reply Quote 0
                                          EducatingSavvas @dc42
                                          @dc42 Does that mean if R in M950 and P in M563 are the same number during CNC mode, I would not need to write P# when using an M3 command? Should any spindle defining commands be in the tfree#.g tpre#.g and tpost#.g? That is to say I load the spindle separately from config.g file?
                                          I think the confusion with CNC is that you have the spindle and the bits, or tangential knife and blades are referred and all are referred to as tools. And that on a CNC mills the tool database in often part of a complicated control system, while for flat-bed panel CNC machine the tool database in part of the CAM software.
                                            Yes.
                                            There is no need to do that. In config.g, define all your spindles, then for each tool specify which spindle it uses in its M563 command.
                                            EducatingSavvasundefined 1 Reply Last reply Reply Quote 1
