    Poor print quality with RRF3 - especially 3.2.2.
    159
    12.7k
    • alankilianundefined
      alankilian
      This is a HUGE discovery!
      I don't know much about the many-board DUET3 ecosystem, but I'll give some uninformed advice anyway. 🙂
      I've read that there are power-on timing (something) going on with some of the boards in the Duet3 ecosystem.
      Having written firmware for about 40 years, I'm going to guess (and it's ONLY a guess) that:
      • Something in one board or another isn't initialized on power-up
      • Order of starting of RTOS tasks is unpredictable.
      • Exactly how the several boards discover and talk to each other is not predictable.
      Resulting in different internal states "somewhere" that is greatly affecting printer settings.
      Now, how to tell? I'm not sure.
      If @dc42 had a "secret" way to dump RAM from the boards, you could power-on and dump RAM several times and see where the differences are.
      Or if there were a way to dump a lot of settings, you could also do that several times.
      If I were the developer on this project, I would be jumping for joy that you have a reproducible failure/success test now.
      If I were a user of this, I'd be not so happy to be "the one" with the exciting probelm. 😞
      deckingmanundefined 1 Reply Last reply Reply Quote 1
        deckingman @alankilian
        @alankilian As I said, I know that my judgement has been impaired by 19 months of firmware issues, so I couldn't possible comment.
          alankilian
          How are you with electrical engineering?
          I'm thinking about your endstops.
          You've got a REALLY stiff pullup from +5V (EXT-IN) to an I/O pin on the processor running at 3.3 Volts.
          The LED will drag that down to about 3 Volts.
          I'm wondering out loud if when you power-cycle, if the 5Volt supply is keeping the processor somewhat alive by powering up through the I/O static protection diodes.
          I'm also wondering if these two problems (Homing not working and printing changing after power-cycle) are somehow related through this resistor.
          I'm just hoping to help free-thinkers get new ideas on what's going on.
          I'll dig a little through schematics and see what I can find.
          If you feel like experimenting (I know. You've been asked WAY WAY too many times to experiment) maybe remove that resistor/LED and turn on the built-in pullup to see if at least your homing is fixed.
            deckingman @pkos
            @pkos I can make the gcode available if it's generally considered as being a worthwhile exercise. Parts are sliced completely normally. The magic with the UV (extruder gantry) and the AB (load balancing gantry) is done post slicer by adding UV and AB moves to the ends of the XY moves. But this is a non-destructive process which creates a new gcode file - the original remains intact. So I could share that file.
            I do however use a 0.5mm nozzle which is less common than the 0.4mm nozzle that others use. I could also share the stl file.
            But due to the seemingly random print to print variability, I'm not sure if would help. Let's see what other people think.
            Thanks for the offer............
              @alankilian I think it will be best if we keep these two issues separated into their respective threads.
              But ref the pull up resistor value - that's as advised by the man himself - dc42. He told me how to wire it and what value resistor to use. I guess as he helped design the board, and he writes the firmware, he should know 🙂
              • jens55undefined
                jens55
                Going through your last set of pictures, it seems to me that the corners are lifting a bit. This would explain some of the sketchy bits in the first 10 to 20 layers in the corners.
                Obviously it doesn't explain anything about the higher up shite 😞
                WTH is up with the random zits ????
                If it wasn't such a big effort, I would suggest a nozzle cam and recording the entire print. It would certainly reveal the zits issue but I am not sure if it would be helpful with the other problems.
                  deckingman @jens55
                  @jens55 said in Poor print quality with RRF3 - especially 3.2.2.:
                  The corner lifting thing might have just been due to me knocking the parts off the build plate before they had cooled. I certainly didn't notice anything untoward happening during the print. The first layer looked fine as it was going down. Dunno....
                  No idea. There are no random zits when it it's printing well - only when everything else to do with the print is going pear shaped (almost literally).
                  Sods law would dictate that if I fitted a camera, I'd never see those random zits again. 🙂
                  Besides, these days, with only my (diminishing) pension income, I don't have any spare cash to splash.
                  • gloomyandyundefined
                    gloomyandy
                    Hmm interesting but very frustrating.
                    I wonder if there is any correlation with bad prints and room temperature? It's been pretty cold here (in the UK) the last few days and I know my workshop space is much colder first thing and will get warmer as the day goes on. Does the temperature vary much where your printer is?
                    Phaedruxundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @gloomyandy
                      @gloomyandy said in Poor print quality with RRF3 - especially 3.2.2.:
                      Maybe, but I think he has it fairly well enclosed, so I suspect should be quite stable.
                      • arhiundefined
                        arhi @deckingman
                        @deckingman said in Poor print quality with RRF3 - especially 3.2.2.:
                        My experience tells that every time you have a zit on a "decent printer" you had a hiccup ... either at least one of the motors "forgot" to turn or at least one of the motor drivers didn't receive the step pulse... in most cases, the whole firmware "freezes" for some milliseconds and zit happens. Maybe printing tight curves and cylinders would make the problem more prominent?
                        not something easily observed without high fps video..
                        Now, this issue with random behavior reminds me of a situation with RapMan some 10 years ago, right around mid-January printed started acting weird, crashing head into sides, trying to move at some weird speeds, and all kinds of crappy behaviors .. It started happening to a bunch of ppl at the same time without any changes... I finally measured some kilovolts on the nozzle and we solved the problem by attaching wet towels to the printer to increase humidity so that static electricity drops to acceptable levels... I don't think this has anything to do with your machine but since ideas are not pouring.. did you check if your nozzle is properly grounded?
                          @deckingman were you able to capture a M122 (B1, etc) before and after the good and bad prints?
                            deckingman @Phaedrux
                            @Phaedrux said in Poor print quality with RRF3 - especially 3.2.2.:
                            Nope. Do you think would help? TBH, I have more than enough of these little cases (they are for a Dig-Uno ESPbased addressable LED controller) that I'm reluctant to waste any more filament (and time, and energy) unless I have a good reason to do so.
                              @deckingman I won't ask you to waste the filament on more testing, but if you do any more prints, yes, getting a diagnostic report before and after would potentially be helpful. Particularly if you try the 3.3 beta. Otherwise we're just looking at photos of good or bad prints and speculating.
                              Thanks for your efforts in troubleshooting. I don't think anyone should be dismissing any problem reports, regardless of how "niche" the printer may be. The Duet excels at reaching into as many niches as possible. A big part of the appeal is the versatility afterall.
                              The Duet3 and Canbus and the SBC are all very new to the ecosystem and all provide challenges and inconveniences to the early adopters, but we're trying to improve things and achieve the reliability users expect. Unfortunately it wasn't a seamless out of the gate experience, and unfortunately it's taking time to get right. But issues are being found and addressed and limitations are being removed. And that wouldn't be possible without people like you pushing the envelope, finding the gaps, reporting the problems, and working through it so things can be improved.
                              We do appreciate the time and effort you've put in then and now.
                              deckingmanundefined 1 Reply Last reply Reply Quote 2
                                deckingman @gloomyandy
                                Ahh, now it's funny you should say that. The printer sits inside dust proof booth inside my garage. The garage is integral to the house, and is fitted with an insulated panel door (one of the best investments I ever made). there is also a small radiator connected to the house heating system and a freezer which helps to keep the place warm.
                                As it happens, as part of my ongoing home automation project (well I have to pass the time in lockdown somehow), I've made and fitted an ESP based garage door controller. As the ESP device had a few spare pins, I fitted a DHT22 sensor in the box as well, because why not?
                                So, I happen to have a record of the garage temperature (and humidity) over the last 24 hours. Now the sensor is up high, close to the garage door motor so it reads about 4 or 5 degrees higher than at "printer height".
                                But here is a snip from the ambient conditions tab of the Home Assistant dashboard on my PC.
                                The garage temperature and humidity are the purple lines. Min temp was 20.2, max was 26.7 but you can knock 4 or 5 degrees off that for the reasons given above. On the other hand, the printer sits inside a dust proof "booth" (about the size of double wardrobe) so the ambient inside there is little higher. Humidity is fairly constant (min 30, max 36).
                                So I can categorically say (and prove) that there were no wild excursions of ambient temperature or humidity.
                                I'll bet you didn't expect that sort of answer did you? 🙂
                                I'll also wager that some smart ar*s is going to say "what about barometric pressure" 🙂
                                droftartsundefined akstrfnundefined 2 Replies Last reply Reply Quote 1
                                  droftarts administrators @deckingman
                                  @deckingman what about barometric... oh, never mind.
                                    ............... I don't think anyone should be dismissing any problem reports, regardless of how "niche" the printer may be. The Duet excels at reaching into as many niches as possible. A big part of the appeal is the versatility afterall.
                                    There are a number of people who should take note of that comment above - from the Duet team. Too often have other users pointed the finger at me and implied or outwardly stated that it's all my fault for having a complex machine. You know who you are..................
                                    ............... We do appreciate the time and effort you've put in then and now.
                                    It hasn't felt like it over the last 12 months. But I'm not a vindictive person. We could crack these issue together, but I can't do it alone.
                                      gloomyandy
                                      @deckingman I think your garage is warmer than my house most of the time!
                                      I think that all of the bad prints you have had so far have been the "first print" for the day. Is that correct? Probably too small a sample set to draw conclusions but interesting.
                                      • akstrfnundefined
                                        akstrfn @deckingman
                                        What about cosmic ray radiation 😛
                                        I always find it hilarious when frequent forum members ask you to check some basic thing knowing well how crazy you are with your machine.
                                        Phaedruxundefined deckingmanundefined jens55undefined 3 Replies Last reply Reply Quote 0
                                          Probably. That's what comes from many holidays on various Greek Islands and having a daughter who lives in Australia. One gets used to the heat. You should try my lounge when the wood burner has been going for an hour two!
                                          That is actually true. Can't get my head around what that might be significant. I suspect it's purely coincidental. Of maybe the printer is like me - can't get going in the mornings until at least the third coffee......
                                            Phaedrux Moderator @akstrfn
                                            @akstrfn said in Poor print quality with RRF3 - especially 3.2.2.:
                                            Cmon now. He's wise and skillful, but not omnipotent. Even the best among us have been caught out by the simple things. Thorough troubleshooting shouldn't be taken as a slight.
                                            akstrfnundefined 1 Reply Last reply Reply Quote 4
