    Independently leveled Z axis Issue
    7.1k
    • mrenz999undefined
      mrenz999 @3DPrintingWorld
      @3DPrintingWorld In your bed.g do you have it do multiple probes per point ? If so how do you accomplish that ?
      fcwiltundefined 3DPrintingWorldundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @mrenz999
        @mrenz999 Thanks.
        The is an extreme version of what my height map looked like.
        Is this what the frame of your printer looks like?
        • mrenz999undefined
          mrenz999
          Yes thats the one 🙂 Except I have 3 z motors. 2 on the right side and 1 on the left
          • fcwiltundefined
            fcwilt @mrenz999
            @mrenz999 said in Independently leveled Z axis Issue:
            Read up about the A and S parameters of M558.
            If A = 10 and S=0.01 the process will probe each point up to 10 times trying to get two consecutive readings with 0.01.
            If it fails to do that it will average all 10 readings.
            mrenz999undefined 1 Reply Last reply Reply Quote 0
            • mrenz999undefined
              mrenz999 @fcwilt
              @fcwilt Perfect. Thank you. Does it matter where in the M558 I put that ?
              • fcwiltundefined
                fcwilt @mrenz999
                And the linear guides are on the underside of the top most frame pieces?
                • fcwiltundefined
                  fcwilt @mrenz999
                  No just add them to your current M558 command.
                  • mrenz999undefined
                    mrenz999 @fcwilt
                    • fcwiltundefined
                      fcwilt @mrenz999
                      @mrenz999
                      Sorry but I cannot tell where they are from that picture - I may be looking right at them and just not seeing them.
                      So where are the left and right linear guides mounted?
                      • mrenz999undefined
                        mrenz999 @fcwilt
                        @fcwilt So the left one is in the middle of the bed on the X axis. The 2 on the right are at the corners of the bed frame. The bed frame sits on the attachment to the linear guide mounts
                        • fcwiltundefined
                          fcwilt @mrenz999
                          Sorry I was not clear - I meant the Y axis guides - the ones running front to back on each side.
                          • mrenz999undefined
                            mrenz999 @fcwilt
                            @fcwilt gotcha. The are underneath
                            • 3DPrintingWorldundefined
                              3DPrintingWorld @mrenz999
                              I created a macro that heats the bed, calls out the mesh, homes, does the mesh, saves the mesh, then turns the bed off. I started at 10:10, then S= was my max travel minus 10. Plus you have to add/subtract your probe to nozzle offset.
                              M140 S60
                              M557 X10:365 Y10:290 S300:270
                              G28
                              G29 S0
                              G29 S3
                              M140 S0
                              • fcwiltundefined
                                fcwilt @mrenz999
                                @mrenz999
                                Great.
                                Did you print out those "tools" designed to help align the frame pieces?
                                I didn't have such tools and after seeing my 4 point height map I realized that my left and right Y axis guides were not in the same plane meaning the frame pieces were not in the same plane.
                                I closely examined the left and right frame pieces where they joined the four vertical pieces at the top and found that they were at slightly different heights, with the left piece being low in the rear and right piece being high in the front.
                                We are talking fractions of a mm but it was enough to generate a "twisted" height map - though not as bad as yours.
                                Perhaps you are having the same problem.
                                  @mrenz999
                                  Looks like one of your bearings is not attached?
                                  ![0_1615255538626_bearing.png](Uploading 100%)
                                  • mrenz999undefined
                                    mrenz999 @fcwilt
                                    @fcwilt Perhaps. I did print the tool but things move so I will recheck them.
                                    Is there a way to add the a and s parameter to your bed.g when doing the leveling so it does multiple probes ?
                                    • fcwiltundefined
                                      fcwilt @3DPrintingWorld
                                      @3DPrintingWorld said in Independently leveled Z axis Issue:
                                      M140 S60
                                      G28
                                      G29 S0
                                      G29 S3
                                      M140 S0
                                      Why the G29 S3? The G29 S0 creates the height map and loads it.
                                      3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
                                      • mrenz999undefined
                                        @3DPrintingWorld I pulled screws out of all of them and started a retighten. Trying to see if something came loose.
                                        • fcwiltundefined
                                          fcwilt @mrenz999
                                          Yes but is there some reason you cannot modify the existing M558?
                                            Ok, that makes sense.
