Independently leveled Z axis Issue
Thanks @fcwilt, think you finally helped me realize my issue. Only four points makes the map much easier to understand.
When I first ran the mesh the left back corner was really low. I have a glass plate on top of a sheet magnet. I am only using glass because I wanted to verify the bed was flat.
I'm clipping down the bed in the back center left and front center right. I moved both clips to center right and reran the mesh and the low corner goes away!
Upon further inspection of the magnetic sheet shows small cracks where it starts to turn blue in the first map. I think these crack are causing the issue. I'll remove the magnet an put the glass directly on the bed tomorrow and give it a try.
@3DPrintingWorld In your bed.g do you have it do multiple probes per point ? If so how do you accomplish that ?
@mrenz999 Thanks.
The is an extreme version of what my height map looked like.
Is this what the frame of your printer looks like?
Yes thats the one
Except I have 3 z motors. 2 on the right side and 1 on the left
@mrenz999 said in Independently leveled Z axis Issue:
Read up about the A and S parameters of M558.
If A = 10 and S=0.01 the process will probe each point up to 10 times trying to get two consecutive readings with 0.01.
If it fails to do that it will average all 10 readings.
@fcwilt Perfect. Thank you. Does it matter where in the M558 I put that ?
Yes thats the one
And the linear guides are on the underside of the top most frame pieces?
No just add them to your current M558 command.
Sorry but I cannot tell where they are from that picture - I may be looking right at them and just not seeing them.
So where are the left and right linear guides mounted?
@fcwilt So the left one is in the middle of the bed on the X axis. The 2 on the right are at the corners of the bed frame. The bed frame sits on the attachment to the linear guide mounts
Sorry I was not clear - I meant the Y axis guides - the ones running front to back on each side.
@fcwilt gotcha. The are underneath
I created a macro that heats the bed, calls out the mesh, homes, does the mesh, saves the mesh, then turns the bed off. I started at 10:10, then S= was my max travel minus 10. Plus you have to add/subtract your probe to nozzle offset.
M140 S60
M557 X10:365 Y10:290 S300:270
G28
G29 S0
G29 S3
M140 S0 -
Great.
Did you print out those "tools" designed to help align the frame pieces?
I didn't have such tools and after seeing my 4 point height map I realized that my left and right Y axis guides were not in the same plane meaning the frame pieces were not in the same plane.
I closely examined the left and right frame pieces where they joined the four vertical pieces at the top and found that they were at slightly different heights, with the left piece being low in the rear and right piece being high in the front.
We are talking fractions of a mm but it was enough to generate a "twisted" height map - though not as bad as yours.
Perhaps you are having the same problem.
Looks like one of your bearings is not attached?
@fcwilt Perhaps. I did print the tool but things move so I will recheck them.
Is there a way to add the a and s parameter to your bed.g when doing the leveling so it does multiple probes ? -
@3DPrintingWorld said in Independently leveled Z axis Issue:
M140 S60
G28
G29 S0
G29 S3
M140 S0Why the G29 S3? The G29 S0 creates the height map and loads it.
@3DPrintingWorld I pulled screws out of all of them and started a retighten. Trying to see if something came loose.
Is there a way to add the a and s parameter to your bed.g when doing the leveling so it does multiple probes ?Yes but is there some reason you cannot modify the existing M558?
