    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    32.1k
    • SputnikOC3dundefined
      SputnikOC3d @gloomyandy
      @gloomyandy ... Yes - we do have some test cases setup.
      I have 2 Duet2 wifi's running various LDO .9* and 1.8* steppers
      I have a voron 2.4 build in the works that will possibly be fitted with a Mini 5_ Duet 3 w/ Pi4
      We also have a test Caribou 320 with Mini 5+ - w/ LDO .9* steppers on X / Y / E [ OP's machine ]
      Another Bear with linear rails w/ Mini 5+ - w/ LIN .9* steppers on X Y E - working ins spreadcycle but skipping steps and klunking on higher than 180 mm/s moves
      Then a Voron 2.4 w/ full sized main board duet and .9* OMC Stepper online on all axis
      Then another Voron 2.4 with SKR and 2209's and 1.8* LDO Motors
      So lots of things being compared ... This with this exhibits that or none of this etc ..
      Thru the process of elimination its seems to be either LDO .9* motors or RRF3 FW.
        SputnikOC3d @T3P3Tony
        @t3p3tony - any potential ideas to help get this resolved. If not - pretty sure I'll just send my Mini 5+ back in for a refund to Filastruder.
        Someone needs to put some type of effort also into getting Trinamic engaged to help sort these issues its across the spectrum with several other boards - at least with those one can swap out drivers.
        Never thought Id be sending back a Duet in order to get a china board ... for different drivers.
        • carcamerarigundefined
          carcamerarig
          For the time being I’ve pulled the LDO .9’s and replaced with LDO 1.8’s. The thumping / missed steps was across all travel and print moves, in stealthchop switching and forced spreadcycle, fast or slow .45mm/s to 180mm/s. I believe Ian is on the case, someone spoke to LDO and Caribou have an evaluation board that will make some tests on .9’s.
          It would be nice considering the staggering amount of time people have graciously put into this if the right people could keep the thread updated please.
          Thanks J
            Nothing new to report at the moment but yes, we are on the case.
              droftarts administrators
              I'm getting hold of Wantai, LDO (thanks @carcamerarig) and E3D 0.9° motors to test. I have a range of Duet boards to test on, and a stepper motor analyser coming. Unfortunately it's not going to be a quick fix; I'll probably need to write a report to send to Trinamic and/or LDO with my findings.
              If people can post their sys folder and a file that causes them issues, preferably together in a zip file (you can upload zip files to the forum, so long as you put .txt on the end, or host them elsewhere and post a link), and comment what board and motors they have, that may make this task a little quicker.
              If anyone has any observations, or spots other conversations about this issue, even on other firmwares, please post and I'll follow it up.
                carcamerarig
                Little update...
                Im still having the banging / thumping issues with 1.8 motors causing layer shifts.
                Y runs from left to right in this image
                Sat with it for 1.5hrs listening and watching, there are still what im calling micro bumps where for instance on the infill pattern both X and Y are very jerky and its this causing the micro thumps but on a few travel moves there is a distinct bang and this mid move stop for a few ms's then the moves continues. This is the layer shift point, nice and sane print / travel speeds as faster print moves are worse.
                File download sliced in PS
                in between the .9's and 1.8 motors, I noticed the Y motor holder had a crack in it, I believe caused by these bangs ( I was actually hopeful that it was a mechanical fault causing the whole issue but sadly still persists after fitting the replacement holder) And if im honest the infill movements do seem like the bearing blocks have square bearings inside but after numerous times of disconnecting the belts to check the carriages run butter smooth ( I have also repacked them for clarity).
                So this isn't unique to the .9's in my case both in hybrid mode or forced spreadcycle, any suggestions on things to try / test? Run in standalone mode? 3.2 fw? This latest config is running in M569 V0 mode. Is it possible I have a faulty board?
                Config
                ; General preferences 											Duplicate lines and comment out unused
                G90																; Send absolute coordinates...
                M83																; ...but relative extruder moves
                M564 H0															; Permits ALL Axis movement prior to or without ANY Homing require [ over-rides default of no movement until all homed ]
                ; Network														Networked of sbc
                ;M550 P"Duet3"													; Set machine name
                ;M552 S1														; Enable network
                ;*** Access point is configured manually via M587
                ;M586 P0 S1														; Enable HTTP
                ;M586 P1 S0														; Disable FTP
                ;M586 P2 S0														; Disable Telnet
                M575 P1 S1 B57600												; Panel Due
                ; Drive Mappings
                M569 P0.0 S0 V0												; Drive 0 goes forwards: X Axis
                M569 P0.1 S0 V0												; Drive 1 goes backwards: Y Axis
                M569 P0.2 S0 V0											; Drive 2 goes backwards: Z Axis
                M569 P0.3 S0 V0												; Drive 3 goes forwards: E Axis
                M569 P0.4 S0 V0											; Drive 4 goes backwards: Z Axis (at E1)
                ; Motor remapping for dual Z and axis Limits
                M584 X0 Y1 Z2:4 E3												; two Z motors connected to driver outputs Z and E1
                M671 X-37:287 Y0:0 S4											; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                ; Micrpstepping and Speed
                M350 X32 Y32 E16 Z16 I1											; Configure microstepping with interpolation
                M92 X200.00 Y200.00 Z400.00 E830.00								; Set steps per mm
                ; Speeds, Acceleration and Jerk
                M566 X240 Y240 Z24 E1200 P1									    ; Set maximum instantaneous speed changes (mm/min) aka Jerk
                M203 X9000 Y9000 Z720 E4000									; Set maximum speeds (mm/min)
                M201 X2000 Y2000 Z200 E4000								; Set accelerations (mm/s^2)
                M204 P1250 T1700												; set print and travel accelerations (mm(s^2)
                ; Motor currents
                M906 X800 Y850 Z600 E792 I30								; Set motor currents (mA) and motor idle factor in percent
                M84 S30															; Set idle timeout
                ; Printer geometry
                M208 X0:250 Y-4:215 Z-0.5:415									; X carriage moves from 0 to 250, Y bed goes from 0 to 210
                M564 H0															; allow unhomed movement
                ; Endstops for each Axis
                M574 X1 S3								 	; Set endstops controlled by motor load detection
                M574 Y1 S3                               	; Set endstops controlled by motor load detection
                ; Stallgaurd Sensitivy
                M915 X S-5 F0 H200 R0		                ; Set X axis Sensitivity
                M915 Y S-1 F0 H200 R0		                ; Set y axis Sensitivity
                ; Input Shaper
                ;M593 F61.85														; Input Shaping
                ; Z-Probe Super Pinda
                M574 X1 S3														; configure sensorless endstop for low end on X
                M574 Y1 S3														; configure sensorless endstop for low end on Y
                M574 Z1 S2														; Set endstops controlled by probe
                M558 P5 C"^io3.in" I1 H1 F500 T4800 A30 S0.004					; Super Pinda
                ; Probing Mesh Grid and Sheets
                M557 X24:221 Y10:195 P8											; Define mesh grid for probing
                G31 P1000 X23 Y5 Z1.91											; Textured Sheet
                ;G31 P1000 X23 Y5 Z1.280										; PEI
                ; Heatbed Heaters and Thermistor Bed
                M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8		; Set thermistor + ADC parameters for heater 0 Bed
                M950 H0 C"out0" T0 Q10											; Creates Bed Heater
                M307 H0 R0.273 C345.3 D10.89 S1.00 V23.8						; Bed PID new version !!saved In config-override!!
                M140 H0															; Bed uses Heater 0
                M143 H0 S120													; Set temperature limit for heater 0 to 120C Bed
                ; HotEnd Heaters and Thermistor HotEnd
                M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7		;define E0 temperature sensor Slice HT
                M950 H1 C"out1" T1												; Create HotEnd Heater
                M307 H1 R2.383 C178.5:130.6 D5.32 S1.00 V23.9					; Hotend PID new version !!saved In config-override!!
                M143 H1 S285													; Set temperature limit for heater 1 to 285C HotEnd
                M302 S185 R185
                M950 F1 C"out5" Q250											; Creates HOTEND Fan
                M106 P1 T45 S235 H1												; HOTEND Fan Settings
                M950 F0 C"out6" Q100											; Creates PARTS COOLING FAN
                M106 P0 H-1														; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
                M563 P0 D0 H1 F0												; Define tool 0
                G10 P0 X0 Y0 Z0													; Set tool 0 axis offsets
                G10 P0 R0 S0													; Set initial tool 0 active and standby temperatures to 0C
                G91
                G1 X1 Y1 Z1														; calibrate StealthChop values
                G90
                M83
                G4 S2
                M84																; disable motors
                M98 P"0:/macros/02_Functions/StartupFilamentSensorCheck"		; Runout Sensor Logic: Startup with filament = runout sensor active   Startup without filament = autoload active
                ;M92 X200.00 Y200.00 Z400.00 E830.00								; Set steps per mm
                  Phaedrux Moderator @carcamerarig
                  @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                  Always worth trying.
                  carcamerarigundefined 1 Reply Last reply Reply Quote 1
                    carcamerarig @Phaedrux
                    @phaedrux said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                    Is there a debugging mode that could do a hw / fw dump or whatever you call it?
                      @carcamerarig M122 gives a dump of info on the current state. And there is additional logging you can enable but I'm not sure it will capture anything useful in this case.
                      https://duet3d.dozuki.com/Wiki/Logging
                      and
                      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
                      • fulgundefined
                        fulg
                        Just another data point: I am having a similar problem on a CoreXY setup, Mini5+ and 0.9 motors. The printer worked perfectly with a Duet2 but will randomly (and loudly!) skip steps with a Mini5+.
                        I have raised the motor amps and lowered jerk a lot (M566), reduced travel & print speed in the slicer, forced spreadCycle mode all the time on XY but still I get skipping, exactly like @carcamerarig describes (suddenly a loud "thump" and then there is a major layer shift). It is random, sometimes I can finish a small print but usually not.
                        I see this in the M122 dump, could it be related? Write errors, timeouts, failedOps...
                        Driver 0: position 99200, standstill, SG min/max 0/54, read errors 0, write errors 1, ifcnt 59, reads 53605, writes 19, timeouts 184, DMA errors 0, failedOp 0x41
                        Driver 1: position 0, standstill, SG min/max 0/52, read errors 0, write errors 1, ifcnt 59, reads 53758, writes 19, timeouts 31, DMA errors 0, failedOp 0x72
                        Driver 2: position 5755, standstill, SG min/max 0/56, read errors 0, write errors 1, ifcnt 58, reads 53596, writes 18, timeouts 194, DMA errors 0, failedOp 0x6f
                        Driver 3: position 0, standstill, SG min/max 0/56, read errors 0, write errors 1, ifcnt 58, reads 53650, writes 19, timeouts 138, DMA errors 0, failedOp 0x6f
                        Driver 4: position 0, standstill, SG min/max 0/62, read errors 0, write errors 1, ifcnt 41, reads 53792, writes 13, timeouts 3, DMA errors 0, failedOp 0x01
                        Driver 5: position 0, standstill, SG min/max 0/510, read errors 0, write errors 1, ifcnt 55, reads 53598, writes 18, timeouts 192, DMA errors 0, failedOp 0x72
                        Driver 6: position 0, standstill, SG min/max 0/496, read errors 0, write errors 1, ifcnt 55, reads 53787, writes 18, timeouts 3, DMA errors 0, failedOp 0x41
                        I tried upgrading from 3.2.2 to 3.3b2 and that made no difference, skipping is still random.
                        VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
                        SputnikOC3dundefined gloomyandyundefined 2 Replies Last reply Reply Quote 2
                          SputnikOC3d @fulg
                          @fulg - what motors are you running - brand and model # ?
                          Thank you for posting ...
                          fulgundefined 1 Reply Last reply Reply Quote 1
                            carcamerarig
                            What are @fulg 's write errors? I have seen those in my M122 reports in the past.
                            • fulgundefined
                              fulg @SputnikOC3d
                              @sputnikoc3d Motors are 17HM19-2004S bought directly from OMC StepperOnline.
                              It seems not everyone with a Mini5+ and these motors is affected, I am talking with another VORON user who has the same Mini5+ setup with the same motors and he has no issues at any speed, with the "default" M569 parameters (i.e. no need to increase current, force spreadCycle mode or anything special). I believe he has a 0.5 board though (mine is 1.0).
                              He also sees similar errors reported from the drivers in M122 but it works for him so it's probably unrelated. He is also running 3.3b2.
                              Note that I am not using any of the sensorless features, I have real endstops on my machine and do not care about tuning hybrid mode (it was unusable on Maestro, I had to disable it over there too on a different printer).
                              I really wish we can get to the bottom of it because I am contemplating going back to Duet2, this Mini5+ is completely unusable.
                              carcamerarigundefined SputnikOC3dundefined 2 Replies Last reply Reply Quote 1
                                carcamerarig @fulg
                                @fulg said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                                Who is it?
                                fulgundefined 1 Reply Last reply Reply Quote 0
                                • gloomyandyundefined
                                  gloomyandy @fulg
                                  @fulg It is normal to get a single write error when RRF first talks to a TMC driver (after power on/reset etc). Basically the two sides need to get in sync to be able to communicate correctly, as a result of this process the first write from RRF will fail (and be recorded as a write error). Not sure about the timeouts though.
                                  • fulgundefined
                                    fulg @carcamerarig
                                    @carcamerarig very well then, I will drag him into this thread. 🙂
                                    Hello @oc_geek, you have been summoned! I don't know if you can share more details that haven't been shared already. You seem to have found the magic recipe that eludes many of us.
                                    I know we have the same printer, same motors, same LCD, same firmware version, so perhaps you can help...
                                    For now I am trying another workaround, which is to force stealthChop all the time via M569 ... V1. It is a bit too early to call but so far I am further into a print that has always failed before (I need to slowly remove all my other attempts at working around this issue!). The motors are quite a bit noisier in stealthChop (I would have expected the opposite) but they seem not to stall anymore.
                                    EDIT: this turned out to be false and does not help, I don't want to mislead anyone reading this later.
                                    Argoundefined 1 Reply Last reply Reply Quote 0
                                      SputnikOC3d @fulg
                                      @fulg - Thanks so much!
                                      Im in process of building a V2.4 and have the pi - expansion board needed and the Duet 3 Mini 5+ in hand ... I have OMC stepper online motors in a cart waiting to pull trigger and / or the LDO's. Both of those options seem questionable atm.
                                      We too have an associate on the full duet3 main board and V2.4 using stepper online [ omc 1.8* motors and No missing steps issues - yet ]
                                      Baffling to say the least ...
                                        Thanks all for the extra information, please do keep it coming. Can everyone remind me if they are using their Duet 3 Mini 5+ with SBC (and which one, if so) or not? If you are using SBC, if you try printing without SBC, do you still get the thumping and move errors?
                                        fulgundefined carcamerarigundefined 2 Replies Last reply Reply Quote 0
                                        • fulgundefined
                                          fulg @droftarts
                                          @droftarts I knew I should have waited before posting. Forcing stealthChop with M569 V1 does not help, I just had that same random stall, it just progressed quite a bit further than before.
                                          I am running in stand-alone mode.
                                            carcamerarig @droftarts
                                            @droftarts said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                                            Im try to setup standalone now if I can get past this damn wifi issue...
