12864 display (ST7920) on Duet 3 Mini5+
31
3.6k
    DIY-O-Sphere
    I have connected a level shifter to the Duet Mini+.
    In principle, the display works, the printer can be operated, but there may be an error in my circuit since strange artefacts are visible.
    I have orientated myself on this.
    But it took some time to work through the thread, because it ends up being a mishmash of different firmware, boards and lcd types.
    I tried to create a mapping table between the maestro and the mini, because the display ran perfectly on the maestro before.
    Since the names and functions of the pins are differently, it was difficult to create the circuit diagram.
    The pins that I could not clearly assign are marked in red. This is where I suspect the issue.
    Edit:
    Wiring schematic updated to the fully functional revision
    (UTC+1)
    undefined 1 Reply Last reply 1 May 2021, 19:24 Reply Quote 0
      DIY-O-Sphere @DIY-O-Sphere
      I now have reduced the frequence in M918 and the artefacts are gone.
      Does that mean that the shifting isn't working?
      (UTC+1)
      undefined 1 Reply Last reply 1 May 2021, 19:29 Reply Quote 0
        pixelpieper @DIY-O-Sphere
        @diy-o-sphere it just means that your level shifting circuit isn’t fast enough for stable operation. If it works with the reduced frequency you are fine.
        Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
        Voron V0.250 / Duet 2 Maestro
        undefined 1 Reply Last reply 1 May 2021, 19:35 Reply Quote 0
          DIY-O-Sphere @pixelpieper
          @pixelpieper
          Reducing 1Hz does the trick...πŸ‘
          M918 P1 E-4 F1999999 works....
          (UTC+1)
          undefined undefined 2 Replies Last reply 1 May 2021, 19:39 Reply Quote 0
            @diy-o-sphere I would change it by more - maybe half the default. Otherwise this might break again with small environmental changes in temperature or humidity or just over time...
              alankilian @DIY-O-Sphere
              @diy-o-sphere Do you have the data sheet for your LCD module?
              I looked at several and found the maximum SPI clock to be between 800,000 Hz and 2,500,000 Hz so it looks like the modules are quite different from one another.
              undefined 1 Reply Last reply 1 May 2021, 19:59 Reply Quote 0
                DIY-O-Sphere @alankilian
                @alankilian
                No. It is a cheap clone which I had bought when I had started with the Ramps,
                But it worked propper for years on the Maestro (2Mhz)
                The circuit is still sitting on the breadboard, the "cable spaghetti" is certainly not very helpful.
                (UTC+1)
                undefined 1 Reply Last reply 4 May 2021, 21:11 Reply Quote 0
                  Can you please take a short look at the wiring diagram?
                  The LCD works fine now, but I can't get the SD card reader to work.
                  My best guess is, it has someting to do with SPI2_CS0 on the output.
                  I already tried connecting to SPI2_CD and SPI2_CS3, but no success.
                  (I don't use the external SD Card, but I would like to have the wiring right.)
                  (UTC+1)
                  undefined 1 Reply Last reply 5 May 2021, 07:52 Reply Quote 0
                    dc42 administrators @DIY-O-Sphere
                    @DIY-O-Sphere, are you really saying that the LCD works if you use F1999999 in the M918 command, but not if you use F2000000 ? That sounds most unlikely.
                    Three comments:
                    1. The level shifter IC should be 74HCT08, not 74HC08.
                    2. You should ground the unused 1A and 1B inputs of the 74HCT08, or connect them to +5V.
                    3. The Duet 3 Mini has a card detect input, SPI2_CD in your diagram. You should connect that to the card detect output of your LCD if it has one. It's probably EXP2 pin 7 on your LCD. Caution, you must not apply 5V to SPI2_CD. So check that EXP2 pin 7 is connected to ground when the SD card is inserted, and is floating when it is not. If the LCD doesn't support the card detect output, ground the SPI2_CD pin instead.
                    HTH David
                    undefined 1 Reply Last reply 5 May 2021, 16:37 Reply Quote 0
                      DIY-O-Sphere @dc42
                      @dc42 said in 12864 display (ST7920) on Duet 3 Mini5+:
                      It's a typo IC is 74HCT08
                      I will do this later in a soldered pcb board
                      The Duet 3 Mini has a card detect input, SPI2_CD in your diagram. You should connect ............
                      You are briliant
                      It is not shown in the diagram but it is present. (The Maestro didn't have the connector).
                      When the card is inserted it changes from 0.4V to 0V. I think that should be fine.
                      I have currently connected SPI2_CD to ground and it works.
                      Thanks a lot.
                      I still have one final question.
                      I have an accelerometer that I want to connect to the PanelDue connector.
                      Will this work in combination with the LCD sd card reader (same SPI bus)?
                      I will not run both at the same time.
                      (UTC+1)
                      undefined 1 Reply Last reply 5 May 2021, 17:23 Reply Quote 0
                        @diy-o-sphere the accelerometer is normally connected to the temperature daughter board connector. I think it should be possible to use the PanelDue connector instead, but I haven't tested that. It should work OK with the LCD card reader if the cables are short.
                        undefined 1 Reply Last reply 5 May 2021, 18:15 Reply Quote 0
                          DIY-O-Sphere @dc42
                          My pIan was, that by using IO.0 only one plug is required.
                          But it's just to play around.
                          I will buy the new toolboard as soon as it is available here.
                          Thanks for the announcementπŸ‘
                          I don't feel disadvantaged, quite the opposite.
                          (UTC+1)
                          • PCRundefined
                            PCR
                            Hello i am in the process of making a small Production run based on @DIY-O-Sphere schematic. IT will be Board which will be directly olugged Into the Mini;)
                            Please upvote If you want one!
                            PCRundefined 1 Reply Last reply 21 Jun 2021, 08:44 Reply Quote 6
                            • PCRundefined
                              PCR @PCR
                              @pcr
                              PCRundefined undefined 2 Replies Last reply 5 Jul 2021, 08:44 Reply Quote 3
                              • PCRundefined
                                PCR @PCR
                                @pcr
                                The adapters are here and they work. I tested it with the classic Display, the BTT 35 and the BTT 70.
                                Please PN if you want one! You can choose between a plugin type or a "extension" one πŸ˜‰ For plugin see the image above
                                WhatsApp Image 2021-07-05 at 10.41.58.jpeg WhatsApp Image 2021-07-05 at 10.41.584.jpeg WhatsApp Image 2021-07-05 at 10.41.585.jpeg
                                undefined 1 Reply Last reply 7 Jul 2021, 18:29 Reply Quote 3
                                  MatixYo @PCR
                                  @pcr how much is it?
                                  PCRundefined 1 Reply Last reply 7 Jul 2021, 18:56 Reply Quote 0
                                  • PCRundefined
                                    PCR @MatixYo
                                    @matixyo
                                    6€ with connectors.
                                    4€ untracked shipping. 7€ tracked
                                    undefined undefined 2 Replies Last reply 9 Jul 2021, 18:34 Reply Quote 0
                                      MatixYo @PCR
                                      @pcr not bad
                                        Giannivox @PCR
                                        @pcr Hi, adapters in compatible with mks mini12864 v2.1?
                                        thanks
                                        undefined 1 Reply Last reply 14 Jul 2021, 13:47 Reply Quote 1
                                          DIY-O-Sphere @Giannivox
                                          @giannivox
                                          If the LCD has a ST7567 chip, the adapter is not required.
                                          (UTC+1)
