    12864 display (ST7920) on Duet 3 Mini5+
    31
    3.7k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @pixelpieper
      @pixelpieper
      Reducing 1Hz does the trick...👍
      M918 P1 E-4 F1999999 works....
      (UTC+1)
      pixelpieperundefined alankilianundefined 2 Replies Last reply Reply Quote 0
      • pixelpieperundefined
        pixelpieper @DIY-O-Sphere
        @diy-o-sphere I would change it by more - maybe half the default. Otherwise this might break again with small environmental changes in temperature or humidity or just over time...
        Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
        Voron V0.250 / Duet 2 Maestro
        • alankilianundefined
          alankilian @DIY-O-Sphere
          @diy-o-sphere Do you have the data sheet for your LCD module?
          I looked at several and found the maximum SPI clock to be between 800,000 Hz and 2,500,000 Hz so it looks like the modules are quite different from one another.
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
            DIY-O-Sphere @alankilian
            @alankilian
            No. It is a cheap clone which I had bought when I had started with the Ramps,
            But it worked propper for years on the Maestro (2Mhz)
            The circuit is still sitting on the breadboard, the "cable spaghetti" is certainly not very helpful.
            (UTC+1)
              DIY-O-Sphere @DIY-O-Sphere
              Can you please take a short look at the wiring diagram?
              The LCD works fine now, but I can't get the SD card reader to work.
              My best guess is, it has someting to do with SPI2_CS0 on the output.
              I already tried connecting to SPI2_CD and SPI2_CS3, but no success.
              (I don't use the external SD Card, but I would like to have the wiring right.)
              (UTC+1)
                dc42 administrators @DIY-O-Sphere
                @DIY-O-Sphere, are you really saying that the LCD works if you use F1999999 in the M918 command, but not if you use F2000000 ? That sounds most unlikely.
                Three comments:
                1. The level shifter IC should be 74HCT08, not 74HC08.
                2. You should ground the unused 1A and 1B inputs of the 74HCT08, or connect them to +5V.
                3. The Duet 3 Mini has a card detect input, SPI2_CD in your diagram. You should connect that to the card detect output of your LCD if it has one. It's probably EXP2 pin 7 on your LCD. Caution, you must not apply 5V to SPI2_CD. So check that EXP2 pin 7 is connected to ground when the SD card is inserted, and is floating when it is not. If the LCD doesn't support the card detect output, ground the SPI2_CD pin instead.
                HTH David
                  DIY-O-Sphere @dc42
                  @dc42 said in 12864 display (ST7920) on Duet 3 Mini5+:
                  It's a typo IC is 74HCT08
                  I will do this later in a soldered pcb board
                  The Duet 3 Mini has a card detect input, SPI2_CD in your diagram. You should connect ............
                  You are briliant
                  It is not shown in the diagram but it is present. (The Maestro didn't have the connector).
                  When the card is inserted it changes from 0.4V to 0V. I think that should be fine.
                  I have currently connected SPI2_CD to ground and it works.
                  Thanks a lot.
                  I still have one final question.
                  I have an accelerometer that I want to connect to the PanelDue connector.
                  Will this work in combination with the LCD sd card reader (same SPI bus)?
                  I will not run both at the same time.
                  (UTC+1)
                    @diy-o-sphere the accelerometer is normally connected to the temperature daughter board connector. I think it should be possible to use the PanelDue connector instead, but I haven't tested that. It should work OK with the LCD card reader if the cables are short.
                      DIY-O-Sphere @dc42
                      My pIan was, that by using IO.0 only one plug is required.
                      But it's just to play around.
                      I will buy the new toolboard as soon as it is available here.
                      Thanks for the announcement👍
                      I don't feel disadvantaged, quite the opposite.
                      (UTC+1)
                      • PCRundefined
                        PCR
                        Hello i am in the process of making a small Production run based on @DIY-O-Sphere schematic. IT will be Board which will be directly olugged Into the Mini;)
                        Please upvote If you want one!
                        PCRundefined 1 Reply Last reply Reply Quote 6
                        • PCRundefined
                          PCR @PCR
                          @pcr
                          PCRundefined kgolgerundefined 2 Replies Last reply Reply Quote 3
                          • PCRundefined
                            PCR @PCR
                            @pcr
                            The adapters are here and they work. I tested it with the classic Display, the BTT 35 and the BTT 70.
                            Please PN if you want one! You can choose between a plugin type or a "extension" one 😉 For plugin see the image above
                            WhatsApp Image 2021-07-05 at 10.41.58.jpeg WhatsApp Image 2021-07-05 at 10.41.584.jpeg WhatsApp Image 2021-07-05 at 10.41.585.jpeg
                            MatixYoundefined 1 Reply Last reply Reply Quote 3
                            • MatixYoundefined
                              MatixYo @PCR
                              @pcr how much is it?
                              PCRundefined 1 Reply Last reply Reply Quote 0
                              • PCRundefined
                                PCR @MatixYo
                                @matixyo
                                6€ with connectors.
                                4€ untracked shipping. 7€ tracked
                                MatixYoundefined Giannivoxundefined 2 Replies Last reply Reply Quote 0
                                • MatixYoundefined
                                  MatixYo @PCR
                                  @pcr not bad
                                  • Giannivoxundefined
                                    Giannivox @PCR
                                    @pcr Hi, adapters in compatible with mks mini12864 v2.1?
                                    thanks
                                    DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
                                      DIY-O-Sphere @Giannivox
                                      @giannivox
                                      If the LCD has a ST7567 chip, the adapter is not required.
                                      (UTC+1)
                                      • kgolgerundefined
                                        kgolger @PCR
                                        @pcr
                                        Does the adapter also work with a Duet2 Wifi (Ref. 1.04, Firmware 3.3)?
                                          DIY-O-Sphere @kgolger
                                          @kgolger
                                          The input will not match directly by plug. You have to wire them pin by pin.
                                          @PCR also provides a wired version
                                          (UTC+1)
                                            Thanks to the support of @pcr i was able to replace my prototype board.
                                            Finally a clean wiring!
                                            (UTC+1)
                                            tecnoundefined 1 Reply Last reply Reply Quote 1
                                            • DIY-O-Sphereundefined DIY-O-Sphere referenced this topic
