    Announcement: Duet 3 Toolboard revision v1.1
    84
    7.2k
      A Former User @T3P3Tony
      @t3p3tony
      Really great! Now I will get one!
      To further "broaden the audience" to this board you might consider replacing the solder-jumper with a real one in the next iteration, then even the "only-will-burn-myself-with-a-solder-iron-fraction" might consider it 😉
        T3P3Tony administrators @A Former User
        @lbi we looked at that but, as you can see, there is not a lot of space left!
          T3P3Tony administrators @jMaddrell
          @jmaddrell I know we are shipping them out as fast as we get them!
          JayJayundefined 1 Reply Last reply Reply Quote 1
          • Luke'sLaboratoryundefined
            Luke'sLaboratory
            Fantastic choices all-around on the updates!
            Luke
            http://lukeslab.online
            • JayJayundefined
              JayJay @T3P3Tony
              @t3p3tony said in Announcement: Duet 3 Toolboard revision v1.1:
              That doesn't actually answer the question though.
              From going down the list the the majority of EU/UK suppliers are not listing the updated version, it appears the only filastruder are "on the ball" enough to be showing updated information, which is a pretty poor service from EU/UK suppliers.
              I have even had it from a UK Supplier advertising the v1.0 boards but supplying v0.6 boards, so I am loathe to purchase in-case they just want to offload older stock, and not being able to purchase the newest item unless you contact the supplier and specifically request the v1.1 is tiresome.
              • Marcelofs13undefined
                Marcelofs13
                I read that the accelerometer will only with the Duet 3 on standalone mode, not SBC. Any ideia when support for the SBC mode will come?
                  dc42 administrators @Marcelofs13
                  @marcelofs13 said in Announcement: Duet 3 Toolboard revision v1.1:
                  In firmware version 3.4, which is also when input shaping will be supported.
                  • pixelpieperundefined
                    pixelpieper
                    Any chance we can get a STEP for the new Version? I am trying to do a mount for a tight space, would be useful to have a complete 3d model. Guesstimates from the 1.0-Step wont work well as the connectors changed and the new board is slightly larger...
                    Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                    Voron V0.250 / Duet 2 Maestro
                    Nuramoriundefined 1 Reply Last reply Reply Quote 2
                    • Nuramoriundefined
                      Nuramori @pixelpieper
                      @pixelpieper I too am interested in that - both for to revise my extruder design and to also make an illustrated guide to orientation and what the "I" value should be based on it's position. I plan on it being fully graphical so it's very easy to know what's correct. I plan on sharing that here too when I'm done.
                        T3P3Tony administrators @Nuramori
                        Here it is:
                        https://github.com/Duet3D/Duet3-Toolboard-1LC/raw/master/ToolBoard_1LC_v1.1/Duet3_TB_1LC_v1.1_STEP.zip
                        DIY-O-Sphereundefined Nuramoriundefined pixelpieperundefined 3 Replies Last reply Reply Quote 1
                        • DIY-O-Sphereundefined
                          DIY-O-Sphere @T3P3Tony
                          @t3p3tony
                          The dimensions of drawing and 3D differ......
                          Not a big thing but:
                          The two upper holes are 13/38 and 47/38 in PCB vs. 13/39 and 47/39 in 3D....
                          Not talking about slightly shifted plugs....
                          (UTC+1)
                          • Nuramoriundefined
                            Nuramori @T3P3Tony
                            @t3p3tony Thanks!
                              T3P3Tony administrators @DIY-O-Sphere
                              @diy-o-sphere thanks, will fix that! The STEP is correct.
                              Edit: Fixed - it was actually all 4 holes shifted up 1mm as the hole sacing has not changed.
                              • Nuramoriundefined
                                Nuramori
                                @T3P3Tony Here's a PDF I made that should help with what the "I" value should be for the toolboard, based on how it's oriented. Hope it helps.
                                Toolboard accelerometer orientation guide
                                T3P3Tonyundefined 1 Reply Last reply Reply Quote 4
                                  pixelpieper @T3P3Tony
                                  @t3p3tony thanks, now it only has to become available at a European reseller 🙂 A2620F4A-8961-4534-902C-CD61D22FD695.png
                                  JayJayundefined martin7404undefined 2 Replies Last reply Reply Quote 6
                                    @nuramori thanks!
                                    • JayJayundefined
                                      JayJay @pixelpieper
                                      @pixelpieper said in Announcement: Duet 3 Toolboard revision v1.1:
                                      I think its supposed to be a surprise, looks like it's too much to expect a structured and professional approach to distribution and notification of such distribution.
                                      dc42undefined 1 Reply Last reply Reply Quote -3
                                        dc42 administrators @JayJay
                                        @jayjay the problem was that the moment we announced to the user base that we are working on a new version with more features, there was a risk that our resellers would be left with old stock that they can't sell. So we were trying to let stocks of the v1.0 tool board run out before we announced the V1.1. It's not fair on our resellers to leave them with old stock, and our margins are not big enough for us to scrap and write off a large number of older boards in the supply chain.
                                        I guess we could have increased the price of the v1.1, but we didn't want to do that.
                                        pixelpieperundefined JayJayundefined 2 Replies Last reply Reply Quote 3
                                          pixelpieper @dc42
                                          @dc42 Totally understandable. Nevertheless, I would be happy to pay 5-10 euro more for V1.1 to finance someone else getting the same amount off on a V1.0...
                                          • JayJayundefined
                                            JayJay @dc42
                                            @dc42 said in Announcement: Duet 3 Toolboard revision v1.1:
                                            This reply highlights a management issue, you "should" have managed the roll out better and requested that ALL resellers advertised stock at the same time, in this manner EU/UK customers have been penalized and US customers have been placed in a privileged position.
                                            E3D are listing as having no stock on their website but I have the following in writing : "we are still awaiting Duet3D to supply us with stock and expect to have stock mid to late march, please keep an eye on our website"
                                            As for waiting for re-seller to deplete "old stock" how are customers going to feel after buying a v1.0 for a week later to find an updated version only became available after the reseller offloaded their old stock......
                                            dc42undefined elmoretundefined 2 Replies Last reply Reply Quote 0
