    Announcement: Duet 3 Toolboard revision v1.1
    84
    7.4k
    • matt3oundefined
      matt3o @T3P3Tony
      @t3p3tony sorry if I am a little out of the loop but it's hard to stay up to date with all the changes... is the toolboard issue where the motor was missing steps fixed?
        jay_s_uk @matt3o
        @matt3o yes. They were the result of CAN communication issues and we're fixed in 3.2.2
          dc42 administrators @jay_s_uk
          @jay_s_uk said in Announcement: Duet 3 Toolboard revision v1.1:
          There was also another less common case, which was fixed in firmware 3.3beta3.
          • jMaddrellundefined
            jMaddrell
            Is there a list of what resellers will have these in the UK/EU?
              A Former User @T3P3Tony
              @t3p3tony
              Really great! Now I will get one!
              To further "broaden the audience" to this board you might consider replacing the solder-jumper with a real one in the next iteration, then even the "only-will-burn-myself-with-a-solder-iron-fraction" might consider it 😉
                T3P3Tony administrators @A Former User
                @lbi we looked at that but, as you can see, there is not a lot of space left!
                  T3P3Tony administrators @jMaddrell
                  @jmaddrell I know we are shipping them out as fast as we get them!
                  JayJayundefined 1 Reply Last reply Reply Quote 1
                  • Luke'sLaboratoryundefined
                    Luke'sLaboratory
                    Fantastic choices all-around on the updates!
                    Luke
                    http://lukeslab.online
                    • JayJayundefined
                      JayJay @T3P3Tony
                      @t3p3tony said in Announcement: Duet 3 Toolboard revision v1.1:
                      That doesn't actually answer the question though.
                      From going down the list the the majority of EU/UK suppliers are not listing the updated version, it appears the only filastruder are "on the ball" enough to be showing updated information, which is a pretty poor service from EU/UK suppliers.
                      I have even had it from a UK Supplier advertising the v1.0 boards but supplying v0.6 boards, so I am loathe to purchase in-case they just want to offload older stock, and not being able to purchase the newest item unless you contact the supplier and specifically request the v1.1 is tiresome.
                      • Marcelofs13undefined
                        Marcelofs13
                        I read that the accelerometer will only with the Duet 3 on standalone mode, not SBC. Any ideia when support for the SBC mode will come?
                          dc42 administrators @Marcelofs13
                          @marcelofs13 said in Announcement: Duet 3 Toolboard revision v1.1:
                          In firmware version 3.4, which is also when input shaping will be supported.
                          • pixelpieperundefined
                            pixelpieper
                            Any chance we can get a STEP for the new Version? I am trying to do a mount for a tight space, would be useful to have a complete 3d model. Guesstimates from the 1.0-Step wont work well as the connectors changed and the new board is slightly larger...
                            Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                            Voron V0.250 / Duet 2 Maestro
                            Nuramoriundefined 1 Reply Last reply Reply Quote 2
                            • Nuramoriundefined
                              Nuramori @pixelpieper
                              @pixelpieper I too am interested in that - both for to revise my extruder design and to also make an illustrated guide to orientation and what the "I" value should be based on it's position. I plan on it being fully graphical so it's very easy to know what's correct. I plan on sharing that here too when I'm done.
                                T3P3Tony administrators @Nuramori
                                Here it is:
                                https://github.com/Duet3D/Duet3-Toolboard-1LC/raw/master/ToolBoard_1LC_v1.1/Duet3_TB_1LC_v1.1_STEP.zip
                                DIY-O-Sphereundefined Nuramoriundefined pixelpieperundefined 3 Replies Last reply Reply Quote 1
                                • DIY-O-Sphereundefined
                                  DIY-O-Sphere @T3P3Tony
                                  @t3p3tony
                                  The dimensions of drawing and 3D differ......
                                  Not a big thing but:
                                  The two upper holes are 13/38 and 47/38 in PCB vs. 13/39 and 47/39 in 3D....
                                  Not talking about slightly shifted plugs....
                                  (UTC+1)
                                  • Nuramoriundefined
                                    Nuramori @T3P3Tony
                                    @t3p3tony Thanks!
                                      T3P3Tony administrators @DIY-O-Sphere
                                      @diy-o-sphere thanks, will fix that! The STEP is correct.
                                      Edit: Fixed - it was actually all 4 holes shifted up 1mm as the hole sacing has not changed.
                                      • Nuramoriundefined
                                        Nuramori
                                        @T3P3Tony Here's a PDF I made that should help with what the "I" value should be for the toolboard, based on how it's oriented. Hope it helps.
                                        Toolboard accelerometer orientation guide
                                        T3P3Tonyundefined 1 Reply Last reply Reply Quote 4
                                          pixelpieper @T3P3Tony
                                          @t3p3tony thanks, now it only has to become available at a European reseller 🙂 A2620F4A-8961-4534-902C-CD61D22FD695.png
                                          JayJayundefined martin7404undefined 2 Replies Last reply Reply Quote 6
                                            @nuramori thanks!
