    Announcement: Duet 3 Toolboard revision v1.1
    84
    8.2k
    • zaptaundefined
      zapta @T3P3Tony
      @t3p3tony said in Announcement: Duet 3 Toolboard revision v1.1:
      @lbi we looked at that but, as you can see, there is not a lot of space left!
      Every board has two sides. ๐Ÿ˜‰
        T3P3Tony administrators @zapta
        @zapta true. in this case we need to keep the board manufacturable at a reasonable cost and also thin enough to fit on a hermera tool on a toolchanger ๐Ÿ™‚
        • pixelpieperundefined
          pixelpieper @martin7404
          @martin7404 its a 3d-accelerometer, you can adjust the orientation in software.
          Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
          Voron V0.250 / Duet 2 Maestro
          • zaptaundefined
            zapta @T3P3Tony
            @t3p3tony, that's correct, good engineering is about striking the right balance.
            BTW, I appreciate the density of your designs. I presume this one is also with Kicad. I played with much simpler design and know how much effort it takes.
              A Former User @T3P3Tony
              @t3p3tony
              A small wish (and with please ๐Ÿ™‚ ) :
              In the next iteration, maybe already the next board-run(?), please consider reviewing if you can add in also the through-hole-solderpads for the stepper-motor-out
              (guess I am one of the few that are no "crimp-ist", push-in would be favourite, otherwise will stick to screw-in-terminals ๐Ÿ™‚ )
              Best regards
                Push in is very nice, but expensive compared to crimp connectors, and quite large - I haven't seen any with less than 2.5mm pitch and they tend to be quite high.
                  A Former User @dc42
                  @dc42 said in Announcement: Duet 3 Toolboard revision v1.1:
                  Thanks so much for answering! Yep most I found in some webshops were too expensive/big/... for now, but I just wanna try something other then crimping, maybe I stick with solder-in-screwin-terminals in the end... Guess I am on some sort of a quest there ๐Ÿ™‚ if you provide me the 4 additional motor-throughhole-solderpads, I will see what I get and will post it in the forum ๐Ÿ™‚ I guess my talent for crimping is just not really there ๐Ÿ™‚
                    @lbi do you have a proper crimp tool?
                    I hate crimping, but once done it makes disconnecting and reconnecting wires much quicker than using screw terminals.
                    • fotomasundefined
                      fotomas
                      Are there any parts for crimping bundled with the toolboard (like duetboard)?
                        T3P3Tony administrators @fotomas
                        @fotomas yes there is a connector pack with the board
                        • martin7404undefined
                          martin7404 @fotomas
                          @fotomas I did received mine from dold
                          And it working great.
                          For now I tested only accelerometer as far I am building new large 3d printer. It took 15 minutes to crimp wiring, solder the 120 ohm bridge and run.
                          Muldex IDEX Duet2+Duex5
                          Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                          Sapphire Pro with Duet2, with closed-loop motors
                          custom high temp E3D tool changer with Duet2+Duex
                            A Former User @dc42
                            At least I am not alone in the universe with that issue ๐Ÿ˜Š ๐Ÿ˜€ yeah of course you have a point, I know I can force myself to do it, just the outcome is appropriate to my feeling while doing it, I can borrow a tool at work, but some of them work even better when "crimped" by hand with a tiny plier... Ah for now I crimp, it is alright. Just would be great in the future to have the possiblity maybe to even order them with no connnectors soldered and buy either a screw-in or a crimp-connector kit and just solder it there, and for that the 4 through-hole-pads for the motor are missing. I know this would be / is for advanced users... but my solder-skills are actually not as bad as my crimp-skills are. Didnยดt want to bother all of you. It is allright. Keep up your work!
                            Best regards
                            • DIY-O-Sphereundefined
                              DIY-O-Sphere
                              @T3P3Tony
                              Is there a rough estimate when the product will be available again in germany ?
                              (UTC+1)
                                dc42 administrators @DIY-O-Sphere
                                @diy-o-sphere there is another batch currently undergoing testing, so I don't think it will be long.
                                • khenderickundefined
                                  khenderick
                                  Nice work, great to see that you listen to customer feedback.
                                  Some feedback/questions from my end:
                                  • I do like the crimped connectors, but nice to see that the holes are still there for people preferring screw terminals. A suggestion for a future revision would be to align these holes so that one solid row of screw terminals can be mounted instead of separate sets. This makes the terminals a lot more sturdy and one would be less likely to damage pads or connectors if using too much force fastening the wires.
                                  • As a v1.0 owner, I'm a tad sad to see I'm missing out on all the accelerator fun.
                                    Therefore the question whether I (being familiar with patching hardware, soldering and epoxy) would somehow be able to retro-fit an accelerometer to the v1.0 hardware. I was thinking about some daughter board holding the accelerometer and some passives and then connecting it to some pads/traces.
                                    • If possible, any docs on what to do, or schematics to look at?
                                    • In either case, it might be a good idea for a future revision to break out every (unused) signal/pin to testpoints so patch boards can be made.
                                  dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                    dc42 administrators @khenderick
                                    @khenderick we decided not to attempt to add an accelerometer to a v1.0 tool board when prototyping, because it is difficult. First, you need to access pads of the SAMC21 MCU that are under the chip. Second, you need to connect a level shifting IC between the MCU (which runs at 5V) and the accelerometer (which runs at 3.3V).
                                    If you decided to attempt the modification yourself then you would also need to build custom firmware, because some of the pin allocations were changed between version 1.0 and 1.1 in order to free up pins for the accelerometer.
                                      droftarts administrators @khenderick
                                      @khenderick Schematics are here, if you choose the hacking option:
                                      v1.0: https://github.com/Duet3D/Duet3-Toolboard-1LC/blob/master/ToolBoard_1LC_v1.0/Duet3_TB_1LC_Schematic_v1.0.pdf
                                      v1.1: https://github.com/Duet3D/Duet3-Toolboard-1LC/blob/master/ToolBoard_1LC_v1.1/Duet3_TB_1LC_Schematic_v1.1.pdf
                                      You don't have to miss out; you can connect the accelerometer to a SAMMY C21 board (and connect that to the Toolboard CAN) or direct to the mainboard.
                                      dc42undefined khenderickundefined 2 Replies Last reply Reply Quote 0
                                        dc42 administrators @droftarts
                                        The v1.1 tool board schematic linked to above isn't quite right, because the board are modified during production:
                                        • the INT output of the accelerometer is no longer connected to PA19 of the microcontroller;
                                        • INT is instead connected through a silicon diode to PA00.
                                        PCRundefined 1 Reply Last reply Reply Quote 0
                                        • PCRundefined
                                          PCR @dc42
                                          @dc42 I saw that one guy on twitter made a back toolboard 1.1 ๐Ÿ˜‰ Where did he get the gerber files from?
                                          Best
                                          T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                            T3P3Tony administrators @PCR
                                            @pcr he did not get the gerbers ๐Ÿ˜‰
