    Yeyy First print
    894
      jay_s_uk @tecno
      @tecno what do you have for the M308 line for the hotend?
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @jay_s_uk
        @jay_s_uk
        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
        M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
        M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
        M307 H1 B0 R3.567 C155.0 D5.77 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit B0 S1.00
        • PaulHewundefined
          PaulHew
          @tecno You could try changing your B value to 3950
          From what I have read, that particular type of probe is not very reliable.
          I tend to use E3D thermistors and at a push TLabs.
          P.
          • tecnoundefined
            tecno @PaulHew
            @paulhew
            Hi Paul,
            I am all ears for good tips.
            E3D have 3 different Semitec 104GT + PT100 + PT1000
            Assuming PT100 is a good choice?
              droftarts administrators @tecno
              @tecno PT100 needs a daughterboard. PT1000 is a good choice though. See https://duet3d.dozuki.com/Wiki/Temperature_sensors
              • tecnoundefined
                tecno @droftarts
                @droftarts
                Hello Ian,
                Then PT1000 it is, ordering now from Kent i Denmark.
                  @tecno To be honest, a proper E3D thermistor, with the correct settings, is fine too. Thermistors are repeatable, not accurate, good resolution. PT1000 are repeatable, accurate, slightly lower resolution. Either way you'll need to work out the reported temperature that works for you filament (speed is also a factor), and even your current HT-NTC100K should be fine. Try printing a temperature tower. Something like https://www.thingiverse.com/thing:2729076
                  • tecnoundefined
                    tecno
                    Managed to make my first print yesterday evening by replacing nozzle to brass on Dragon. The suppied nozzle is not OK.
                    Good tool to have.
                    tecnoundefined 1 Reply Last reply Reply Quote 2
                    • tecnoundefined
                      tecno @tecno
                      On purpose !!!!
                      Just to play a little hardboll no G29 S1 = Print went south west as suspected 😉
                      The picture in message is acceptable with loaded heightmap
                      • tecnoundefined
                        tecno
                        Last parts printed for the mechanical upgrade on my Chiron, Y axis linear guides.
