    Yeyy First print
    900
    • jens55undefined
      jens55 @tecno
      @tecno, congratultions, now the REAL work starts (tweaking, tweaking and more tweaking) LOL
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @jens55
        @jens55
        Sorry but it went south 😞
        My Bondtech BMG extruder gave up and started to grind 😞
        • jens55undefined
          jens55 @tecno
          @tecno, oh well, don't fret, we have all been there. Time to do some tweaking 🙂
          • tecnoundefined
            tecno @jens55
            @jens55
            This BMG has been acting badly, now with NO pressure applied filament is not running smoothly.
            Sounds like the gear is wobbling so filament is is type of jerking. Will contact Bondtech tomorrow.
              jay_s_uk @tecno
              @tecno that of you don't have the correct thermistor settings in your config so the temperature you think you're at isn't the temperature you have
              • tecnoundefined
                tecno @jay_s_uk
                @jay_s_uk
                Good morning from a very rainy day 😞
                Have been trying to find info on this thermistor, maybe I got it with E3DV6 but shure.
                Cheers
                Bengt
                  jay_s_uk @tecno
                  @tecno don't think thats an E3D one as they use specific colours for their wires
                  tecnoundefined 1 Reply Last reply Reply Quote 1
                  • tecnoundefined
                    tecno @jay_s_uk
                    @jay_s_uk
                    Correct, my bad memory 😉
                    It is HT-NTC100K
                    So do I have to make any changes to my config?
                      jay_s_uk @tecno
                      @tecno what do you have for the M308 line for the hotend?
                      • tecnoundefined
                        tecno @jay_s_uk
                        @jay_s_uk
                        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                        M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                        M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
                        M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                        M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
                        M307 H1 B0 R3.567 C155.0 D5.77 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit B0 S1.00
                        • PaulHewundefined
                          PaulHew
                          @tecno You could try changing your B value to 3950
                          From what I have read, that particular type of probe is not very reliable.
                          I tend to use E3D thermistors and at a push TLabs.
                          P.
                          • tecnoundefined
                            tecno @PaulHew
                            @paulhew
                            Hi Paul,
                            I am all ears for good tips.
                            E3D have 3 different Semitec 104GT + PT100 + PT1000
                            Assuming PT100 is a good choice?
                              droftarts administrators @tecno
                              @tecno PT100 needs a daughterboard. PT1000 is a good choice though. See https://duet3d.dozuki.com/Wiki/Temperature_sensors
                              • tecnoundefined
                                tecno @droftarts
                                @droftarts
                                Hello Ian,
                                Then PT1000 it is, ordering now from Kent i Denmark.
                                  @tecno To be honest, a proper E3D thermistor, with the correct settings, is fine too. Thermistors are repeatable, not accurate, good resolution. PT1000 are repeatable, accurate, slightly lower resolution. Either way you'll need to work out the reported temperature that works for you filament (speed is also a factor), and even your current HT-NTC100K should be fine. Try printing a temperature tower. Something like https://www.thingiverse.com/thing:2729076
                                  • tecnoundefined
                                    tecno
                                    Managed to make my first print yesterday evening by replacing nozzle to brass on Dragon. The suppied nozzle is not OK.
                                    Good tool to have.
                                    tecnoundefined 1 Reply Last reply Reply Quote 2
                                    • tecnoundefined
                                      tecno @tecno
                                      On purpose !!!!
                                      Just to play a little hardboll no G29 S1 = Print went south west as suspected 😉
                                      The picture in message is acceptable with loaded heightmap
                                      • tecnoundefined
                                        tecno
                                        Last parts printed for the mechanical upgrade on my Chiron, Y axis linear guides.
