Yeyy First print
@tecno, oh well, don't fret, we have all been there. Time to do some tweaking
This BMG has been acting badly, now with NO pressure applied filament is not running smoothly.
Sounds like the gear is wobbling so filament is is type of jerking. Will contact Bondtech tomorrow.
@tecno that of you don't have the correct thermistor settings in your config so the temperature you think you're at isn't the temperature you have
Good morning from a very rainy day
Have been trying to find info on this thermistor, maybe I got it with E3DV6 but shure.
Cheers
Bengt -
@tecno don't think thats an E3D one as they use specific colours for their wires
Correct, my bad memory
It is HT-NTC100K
So do I have to make any changes to my config? -
@tecno what do you have for the M308 line for the hotend?
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S120 ; set temperature limit for heater 0 to 120CM308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
M307 H1 B0 R3.567 C155.0 D5.77 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit B0 S1.00
M143 H1 S280 ; set temperature limit for heater 1 to 280C -
@tecno You could try changing your B value to 3950
From what I have read, that particular type of probe is not very reliable.I tend to use E3D thermistors and at a push TLabs.
P.
Hi Paul,
I am all ears for good tips.
E3D have 3 different Semitec 104GT + PT100 + PT1000Assuming PT100 is a good choice?
@tecno PT100 needs a daughterboard. PT1000 is a good choice though. See https://duet3d.dozuki.com/Wiki/Temperature_sensors
@tecno To be honest, a proper E3D thermistor, with the correct settings, is fine too. Thermistors are repeatable, not accurate, good resolution. PT1000 are repeatable, accurate, slightly lower resolution. Either way you'll need to work out the reported temperature that works for you filament (speed is also a factor), and even your current HT-NTC100K should be fine. Try printing a temperature tower. Something like https://www.thingiverse.com/thing:2729076
Managed to make my first print yesterday evening by replacing nozzle to brass on Dragon. The suppied nozzle is not OK.
Good tool to have.
On purpose !!!!
Just to play a little hardboll no G29 S1 = Print went south west as suspected
The picture in message is acceptable with loaded heightmap
Last parts printed for the mechanical upgrade on my Chiron, Y axis linear guides.
