    Drastic improvements with BL Touch disabled
    49
    4.2k
    • RyanPundefined
      RyanP @RyanP
      Im taking a break from it. I have other working machines and need to take a break from it. Get back to it tomorrow.
      CR10S, August 2018
      Anycubic Photon S December 2019
      Ender 5 Feb 2020
      Ender 5 Plus May 2020
      Anycubic Photon Mono X Nov 2020
      https://3dimensiongames.com/
        Your probe results look consistent in one spot, which is good, but they also seem to vary with XY position a bit still. Dipping off to the back side by the looks of the map?
        The fact that your adjustments and re-alignments are making a difference is a good sign though.
        RyanPundefined 1 Reply Last reply Reply Quote 0
        • RyanPundefined
          RyanP @Phaedrux
          @phaedrux
          Well, I don't even know where to begin. As I previously posted on Saturday, I had gotten close to fixing my issue with my bed and probing, but was going to walk away for a few days (canadian long weekend).
          I've come back to this machine now with a clear mind and a few ideas.
          I turn the machine on and warm it up. This machine is using the Duet 2 Maestro, and 2.05 firmware.
          I hit the home button:
          Print head moves X and Y to their endstops, then to the center of the bed. The BL Touch probe is deployed properly, touches the glass surface twice and reports back the correct z-offset and moves the head up to the expected position:
          But as soon as it stops its motion the head position for the Z-axis turns from 11.77 to this:
          Now the machine is locked up and I cannot move the head with the DWC controls or macros.
          I'm starting to think that the Maestro board is pooched, but I really have no idea. I have a backup Duet 2 Wifi board here that I can replace the Maestro with, but I would rather know for sure.
          CR10S, August 2018
          Ender 5 Feb 2020
          droftartsundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
            droftarts administrators @RyanP
            @ryanp post your homeall.g file?
            • RyanPundefined
              RyanP @droftarts
              @droftarts
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 18 2020 18:08:45 GMT-0500 (Eastern Standard Time)
              G1 H2 Z5 F9000        ; lift Z relative to current position
              G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X20 Y20 F3000      ; go back a few mm
              G1 H1 X-240 Y-240 F1000  ; move slowly to X and Y axis endstops once more (second pass)
              G90                     ; absolute positioning
              G1 X110 Y80 F9000 	; go to center of bed  ; go to first bed probe point and home Z
              G30                     ; home Z by probing the bed
              G1 Z5 F9000            ; lift Z relative to current position
              G29 S1                  ; absolute positioning
              CR10S, August 2018
              Ender 5 Feb 2020
                I wonder if it's a problem from loading the heightmap. Can you try deleting the heightmap.csv file and recreating it fresh?
                • RyanPundefined
                  RyanP @Phaedrux
                  @phaedrux
                  Will do.
                  CR10S, August 2018
                  Ender 5 Feb 2020
                  • o_lampeundefined
                    o_lampe @RyanP
                    @ryanp said in Drastic improvements with BL Touch disabled:
                    Did you go through 'known bugs' related to RRF 2.0x? Maybe there were unsolved issues with BLtouch?
                    I have checked an old SD-card image from RRF2.05 and there are retractprobe.g and unretractprobe.g in the /sys folder. I remember, they messed up my homing routine, because they contained some BS....
                    I didn't know, that 'G30' always calls them, if present...
                    • RyanPundefined
                      RyanP
                      @Phaedrux @o_lampe
                      deleting the text in the height map did solve the latest issue.
                      But now I am having problems with the Maestro board connecting to the network. If I turn the unit off, then back on, many times now it won't connect. I have to turn it off, unplug it, plug it back in and turn it on...and even thats 50/50.
                      All my wifi units work. So Im going to swap the cable, as well as review the access point it is connected to. But I have a pretty extensive knowledge of home networking from my home audio and automation days, and am confident regarding my network.
                      Like I mentioned, I have a backup Duet 2 Wifi board that I can use if I think something has
                      CR10S, August 2018
                      Ender 5 Feb 2020
                      RyanPundefined 1 Reply Last reply Reply Quote 1
                      • RyanPundefined
                        RyanP @RyanP
                        @Phaedrux @o_lampe @droftarts @Hornetrider @engikeneer @deckingman
                        I have fixed my problem. I took apart the printer last weekend and re-assembled it. Moving some of the extrusions around (like rotating your tires) and re-squared everything up. Found one spot that seemed a but off so I positioned it with a small gap and tightened things up with a metal 90 degree corner.
                        I also noticed that my bed.g file looked like this
                        M561 				; clear any bed transform
                        G29 S2				; Clear bed height map
                        ; Probe 2-points
                        M401 				; Deploy probe - deployprobe.g
                        G30 P0 X90 Y115 Z-9999 		; Center Left
                        G30 P1 X125 Y115 Z-9999 S2 	; Center Right
                        M402
                        But there is only one 7 axis on this printer. So I deleted everything expect the M561 command.
                        Between those two things, my printing is back to normal. I wanted to thank everyone for their suggestions.
                        CR10S, August 2018
                        Ender 5 Feb 2020
                        • DonStaufferundefined
                          DonStauffer @RyanP
                          @ryanp Check the reliability of the wiring from your BLTouch. I found 2 only occasionally intermittent wiring problems that caused me no end of problems. The intermittent nature of the problems had me confused for a very long time. What clued me in was that for a while, the probe started failing to probe at one corner of the bed, every time. That said to me it was the wiring being moved. Sure enough, that was the big problem.
