    Voron 0 + Duet 3 Mini
    25
    3.0k
    • fmaundefined
      fma @PaulHew
      @paulhew I don't own a Duet 3 Mini yet, so didn't look for a mount. But I was thinking to make holes in the rear panel, and mount the Duet with spacers...
      Frédéric
        Phaedrux Moderator @PaulHew
        @paulhew said in Voron 0 + Duet 3 Mini:
        @fma Is there an available mount for the Mini that fits on the 15x15
        I looked in voron users but I cannot find one.
        P.
        It has the same hole spacing as the Maestro, so if there is a mount for that it should work.
        PaulHewundefined 2 Replies Last reply Reply Quote 0
        • PaulHewundefined
          PaulHew @Phaedrux
          @phaedrux Friend just designed one for me.
          He is good with F360
          Just need to buy the board. 🙂
          zaptaundefined 1 Reply Last reply Reply Quote 1
          • PaulHewundefined
            PaulHew @Phaedrux
            @phaedrux Sorry, my manners. That is good info, thank you. I will look for it so I can share.
            • zaptaundefined
              zapta @PaulHew
              That's a skill that worth the learning time IMO.
              • DanJuniorundefined
                DanJunior
                I'm just wondering,if someone has a config.g to get the required esteps as reference. I'm just configuring my V0.1.
                  Phaedrux Moderator @DanJunior
                  @danjunior Which extruder exactly?
                  PaulHewundefined 1 Reply Last reply Reply Quote 0
                  • PaulHewundefined
                    PaulHew @Phaedrux
                    @phaedrux The V0.1 is a DirectDrive unit, BMG internals and the LDO Pancake stepper.
                    Mine V0.1 is offline at the moment as I am going to have to rebuild the DD unit 😞
                    even at 350ma it cooked again.
                    The rating is suitable for High Temp applications..... So I and possibly like others think that it is suitable for an enclosure, which it is
                    What I did not realise that the motor will heat itself up also, more than any of the OMC's I have been running with no problems @80% of their rating.
                    Slightly disappointed that this info is not displayed clearly when looking at general info on the motor......
                    • oliofundefined
                      oliof @PaulHew
                      @paulhew depending on your microsteps, it'll be 345 or 690 steps/mm on the LDO pancake stepper meant for the Orbiter.
                      • keyz182undefined
                        keyz182
                        This is what I have on my V0.1 + Duet 3 Mini 5+, with OMC steppers. No guarantees it's correct, still tuning in and adjusting, but it's printing things reasonably so should be a good starting point at least. Also, critique welcome 😛
                        ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 16:03:31 GMT+0100 (British Summer Time)
                        G90                                                   ; send absolute coordinates...
                        M83                                                   ; ...but relative extruder moves
                        M550 P"voronzero"                                        ; set printer name
                        M669 K1                                               ; select CoreXY mode
                        M569 P0.1 S0                                          ; physical drive 0.1 goes backwards
                        M569 P0.2 S0                                          ; physical drive 0.2 goes backwards
                        M569 P0.4 S0                                          ; physical drive 0.4 goes backwards
                        M569 P0.3 S1                                          ; physical drive 0.3 goes forwards
                        M584 X0.1 Y0.2 Z0.4 E0.3                              ; set drive mapping
                        M350 X16 Y16 Z16 E16 I1                               ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z400.00 E1370.00                    ; set steps per mm
                        M566 X1080.00 Y1080.00 Z90.00 E150.00                   ; set maximum instantaneous speed changes (mm/min)
                        M203 X30000.00 Y30000.00 Z1200.00 E9000.00            ; set maximum speeds (mm/min)
                        M201 X4000.00 Y4000.00 Z450.00 E6000.00               ; set accelerations (mm/s^2)
                        M906 X1250 Y1250 Z400 E800 I25                        ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                               ; Set idle timeout
                        M208 X0 Y0 Z0 S1                                      ; set axis minima
                        M208 X120 Y120 Z120 S0                                ; set axis maxima
                        M574 X2 S1 P"io3.in"                                  ; configure active-high endstop for high end on X via pin io3.in
                        M574 Y2 S1 P"io5.in"                                  ; configure active-high endstop for high end on Y via pin io5.in
                        M574 Z1 S1 P"io6.in"                                  ; configure active-high endstop for low end on Z via pin io6.in
                        M558 P0 H5 F120 T3000                                 ; disable Z probe but set dive height, probe speed and travel speed
                        M308 S0 P"temp0" Y"thermistor" T100000 B4138          ; configure sensor 0 as thermistor on pin temp0
                        M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
                        M307 H0 B1 S1.00                                      ; enable bang-bang mode for the bed heater and set PWM limit
                        M140 H0                                               ; map heated bed to heater 0
                        M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                        M308 S1 P"temp1" Y"pt1000" R2200                      ; configure sensor 1 as PT1000 on pin temp1
                        M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
                        M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                        M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                        M950 F0 C"out6" Q75                                  ; create fan 0 on pin out6 and set its frequency
                        M106 P0 C"Cooling" H1 T45 B0.5                     ; set fan 0 name and value. Thermostatic control is turned on
                        M950 F1 C"out5" Q75                                  ; create fan 1 on pin out5 and set its frequency
                        M106 P1 C"Part" H-1 B0.5                          ; set fan 1 name and value. Thermostatic control is turned off
                        M563 P0 D0 H1 F0                                      ; define tool 0
                        G10 P0 X0 Y0 Z0                                       ; set tool 0 axis offsets
                        G10 P0 R0 S0                                          ; set initial tool 0 active and standby temperatures to 0C
                        ; Custom settings
                        ; DHT22 Temperature Sensor
                        M308 S10 P"io4.out+io4.in" Y"dht22" A"Chamber Temp"
                        M308 S11 P"S10.1" Y"dhthumidity" A"Chamber Hum[%]"
                        ; Set bed screw positions for true bed leveling
                        M671 X60:5:115 Y5:115:115 P0.5
                        ;  Laser filament monitor with over the top R values
                        M591 D0 P6 C"io1.in" R0:200 E3.0 S1
                        ; ST7567 12864 display
                        M918 P2 E2                                           ; enable ST7567-based 12864 display
                        M150 X2 R32 U255 B32 S3                              ; set all 3 LEDs to white
                        ; M955 P0 C"io0.out+io0.in"
                        M501                                                  ; load saved parameters from non-volatile memory
                        T0                                                    ; select first tool
                        • PaulHewundefined
                          PaulHew @keyz182
                          @keyz182 What OMC have you got on the Extruder?
                          1. I am interested
                          2. I pray you do not suffer my fate where the LDO motor destroyed my DD plastics.
                            I was running 800ma, later to find that was too high and should be about 350ish
                          P.
                          keyz182undefined 1 Reply Last reply Reply Quote 0
                          • keyz182undefined
                            keyz182 @PaulHew
                            @paulhew https://www.omc-stepperonline.com/round-nema-14-bipolar-1-8deg-9-ncm-12-75-oz-in-1-0a-f36x17-5mm-4-wires.html
                            That's the one. Yeah, it's a bit high, as I said, still tuning. Put probably a roll of filament through at that amperage though and so far it looks fine (had the extruder disassembled yesterday).
                            • PaulHewundefined
                              PaulHew @keyz182
                              @keyz182 Thanks for the info.
                              Going to steal some of your config!
                              My LDO even @450ma was hot enough to burn my fingers.
                              Might get one of those steppers, not trusting the LDO at the moment....
                              Thanks again
                              P.
                              • SputnikOC3dundefined
                                SputnikOC3d @zapta
                                @zapta cult of Voron ... lol ABS Mafia
                                • zaptaundefined
                                  zapta @SputnikOC3d
                                  @sputnikoc3d said in Voron 0 + Duet 3 Mini:
                                  I have a box full of V2.4 parts waiting for the Misumi extrusions to be built. 😉
                                  1 Reply Last reply Reply Quote -1
                                    DanJunior
                                    Hi, i´ve already my V0.1 running. It was the mini afterburner. I´ve just calibrated the extruder...started with 400 ... ended up with 780.
                                    Till now there was nothing melted. I´m using the LDO 36STH20-1004. Running with 900mA
                                    What i had now is that my Duet Board doesn´t like to stay without cooling behind the panels. That socks really.
                                    I´ve to design now a cooling fan for it. Really bad on this little thing with no space.
